Question about Fusion FEW12PK Car Subwoofer
AMPLIFIER PROBS HEY IV HAD A FUSION SUB AND AMP FITTED TO MY PREVIOUS CAR BUT WHEN I CAME TO INSTALL IT INTO MY NEW CAR THERES NO POWER GETTING TO THE AMP AND THE WIREING KITS ALL PLUGED IN RIGHT BUT IT SEEMS LIKE THE AMP IS DEAD ANY SUGESTIONS? AND IF ANYBODY IS SELLIN ANY CHEAP AMPS COULD YOU GIV ME A CALL ON 07955967523 THANKS PPL TONY ...
  • Anonymous Jan 13, 2009
    Exactly the same as above
  • 4 Answers
There are only three wires that control whether the amp powers on or not. battery, ground and remote. if any one of those are not hooked up correctly and securely then the amp will not turn on. the ground point needs to be clean to be good. and u might want to make sure none of the wires have a break in them
Posted on Jun 04, 2009
  • 113 Answers
Check all power coming to your amp remote especially
Posted on Aug 09, 2007
I have got the Fusion FJL-1211 Class D Amplifier.When i turn the music up the amp switches off and back on until i reduce the volume and it plays fine.
your overloading the amp and its going into protect mode. turn the bass down on the deck or adjust the controls on the amp itself. get lower power rated sub(s) or more powerful amp since you won't be able to push the sub(s) you have with that one since the sub(s) is/are pulling too much power from the amp.
Aug 18, 2010 | Fusion Car Audio & Video
My sub has all bin wired up proberly the sub works for about 30 secs then the green light goes out and no power to the sub at all
Green light on amp?? Seems like your amp is going into thermal overload. Check your power connections, and make sure there are no shorted wires. Hope this helps.
Apr 21, 2010 | Fusion FEW12PK Car Subwoofer
Subwoofer not getting max bass
try using a ohm meter and if its not making what the factory specs are its most likly it will keep loosing more and more power then stop working which is what ive had happen to me before
Mar 11, 2010 | Fusion RE-PK2120 900W Bass Pack: Amplifier...
Power going to amp and wired correctly but sub wont work
Well if your amp is connected corectly .Your sub, is not connected try open from the box and check it needs to rewired.once's the sub, is conneted properly it should sound.
Jan 05, 2010 | Fusion FEW12PK Car Subwoofer
I have a 2channell FE-402 fusion amp,with a fusion sub,and a set of vibe k-series 69's that have a max power of 525 watts. I tryed wiring the sub with the speakers and the speakers sound fine but the sub...
Hello jackstephens,
It's an either/or situation. The FE-402 can be set up to drive normal speakers in stereo, OR drive a sub when both channels are bridged. When the LP filter is on, it benefits the sub at the expense of the normal speakers. And with the filter off, the subs get the full range of frequencies and try as best they can to reproduce them. You might try running it with the LP on, in stereo with the 6X9's paralleled to one channel (2ohm load), and the sub connected to the other channel (?ohm load).
But my recommendation would be to use the Fusion amp the drive the 6X9's and get a dedicated monoblock for the sub.
Hope this helps.
Jun 06, 2009 | Kicker KX500.2 Car Audio Amplifier
Fusion car amp problem
The amplifier likely has shorted output transistors. Going to a higher rated could easily have caused more significant damage.
Let me know if you have any other questions.
Jul 27, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Fusion sub..
check the impedenc on amp and speakers.if speakers have lower ohm the amp cant push them also can cause damage to amp.how do you have everything wired must be specific.high level inputs,rca,.how is the radio and amp wired together,where are you getting power sup[ply from and how?
chriszambrotta@yahoo.com
Jan 09, 2008 | Fusion FEW12PK Car Subwoofer
Help me!!!! i have fitted this sub & amp but how do i fit a 2nd amp for speakers
youll need distribution blocks for second amp.this is the basic solution though.other things like wire guages,amp power and crossover settings need to be considered.
Aug 02, 2007 | Fusion FEW12PK Car Subwoofer
Fusion FEW12PK Car Subwoofer Logo
258 people viewed this question
Top Fusion Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
matthew walsh
Level 1 Expert
Steve Sweetleaf
Steve Sweetleaf
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
