Question about TruTech TT1620 DVD Recorder
I have the trutech dvd/vcr recorder and I have been recording old home videos onto the dvd. I can't format the disk now that is is full. What step am I missing to format my disk so I can play it on other machines???
FINALIZE THE DISC
Posted on Mar 16, 2010
How can I record home VHS videos to a DVD on my Samsung DVD-VR320 DVD Recorder/VCR?
BE CERTAIN OF THE KIND OF DVD DISKS IT SUPPORTS. My experience is that the kind of discs while you would think would not make a difference actually do make a big difference depending on the equipment you are using. I just transferred 15 vhs tapes to DVD and realized that the machine only took a few formats luckily it was the one I was using, but not all formats may be compatible. There is a difference between DVD+R and DVD-R as an example.
Jul 12, 2014 | Samsung DVD-VR320 DVD Recorder/VCR
Tip
How to burn MTS, M2TS Videos to DVD on Windows 7?
You have .mts/m2ts videos on your HD camcorder and want to burn it to the DVD disk? This tutorial will show you how to burn MTS/M2TS Videos to DVD on Windows 7.
Before we go to step-by-step guide, we need to understand a bit of background knowledge about MTS/M2TS. According to Wikipedia, both MTS and M2TS are Sony high definition video file types, which are raw AVCHD videos recorded by AVCHD camcorders such as Sony HDR-SR1 camcorders. And m2ts files usually record onto 8cm mini DVDS or blue-ray DVDS, SD memory cards and Memory Stick, or record onto hard drive camcorder
So, We have to convert MTS/M2TS videos to DVD video formats (MPEG-2)before we burn it to DVD disk. Fortunately, there is Wondershare DVD Converter Ultimate can burn mts/m2ts video to DVD directly. Importing your MTS/M2TS videos into it and insert a blank DVD disk to DVD Rom, with 1 click, it will bring you a DVD that is playable on your home DVD player. Sounds great? Let's go to the step-by-step guide:
How to burn MTS/M2TS videos to DVD
Step1 Download Wondershare DVD Converter Ultimate, install it and running
Step2 loading videos
Load video files that you want to burn into DVD disk.
Step3 Making a DVD menu
You can select DVD menu template on the left bar. Set background image and music from you local hard disk. Then, click "Next" button
Name DVD label and set video quality and DVD disk type. Click "Start" button. Then, you can take cup of coffee and waiting until it done.
Step4 Burn DVD
That is it, 4 steps to burn videos to DVD and enjoy it on your home DVD player.
on Dec 29, 2009 | Cameras
Model LGXBR446 VCR/DVD Recorder, Have to go input on the TV to get the unit to Play, Does not play Automatically when turned on an disk or VCR inserted, Also the color is not correct
I think I know what the "skin tones blue" problem is-you probabaly have the composite video(for the old video-on-one-cord format) connected to the blue of the component video input.(component video is the red/blue green RCA type connectors).
May 31, 2012 | LG XBR446 DVD Recorder/VCR
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can the sansui vcr/dvd combo record vcr tapes to a dvd?
No, the DVD section only plays DVDs, to record VCR tapes to DVD you need a ripping device that digitalize audio and video (convert step) and then transfer to DVD specifications this data to disk (record step). The easiest way to do this is using a USB video capture adapter connected to your PC with a DVD recorder drive installed, the software to do this commonly comes as a bonus in the setup disk of the adapter.
Mar 17, 2011 | Sansui VRDVD4001 DVD Player/VCR
How do I record my vhs tapes to Disk
I have done a lot of dubbing on my machine. First make sure the DVD is formatted. When you put in a new disc it should ask you if you want to initialize. Once that is done, switch to VCR mode. push play on the VCR then push the DUB button on the front of the machine. I hope it helps.
Mar 02, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
Vcr to dvd recording
As i recall, +r's will only format in dvd vr, the unit does not like high speed recording disks. switch to dvd drive - insert blank disk - if no format screen - goto (on remote) setup - onscreen menu - system setup - disc setup - new disk format - hit center button in ring on remote to change to vr or move up to reformat as vr. once disk is formatted, use record speed button on remote to set record speed 1,2,4,6 hr then switch to tape deck with tape in and stopped at begining, on remote hit dubbing, it will ask you confirm dubbing vhs-dvd .... toggle over to yes & hit center button... away you should go... c245 is a copyguarded tape.
Oct 09, 2007 | Sansui VRDVD4005 DVD Player/VCR
TruTech TT1620 DVD Recorder Logo
76 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
