Question about Sub-Zero 561 / F
SubZero 532 frig lights out
I have a SubZero 532 side-by-side. The refrigerator lights don't work. The bulbs are fine, the freezer lights work, and the compressor kicks in when you close the door switches so I don't think it's those. Any suggestions greatly appreciated.
  • Bocaboy Mar 02, 2009
    I have the same problem, and jiggling the left switch (the light switch) will usually bet the light to come on. I'd like to replace it but don't know how to remove it. Does it just pry out? I don't see any way to get to it from above for the side. My SZ was manufactured in 1988 and is still going strong, except for this problem.
  • joe5347
    joe5347 Nov 10, 2012
    Question about the 2 switches--one is for the light and one is for the fan. Are they identical or not? Is the fan thermostatically controlled?
    An expert whose answer gotĀ voted for 100 times.
  • 56 Answers
There are two door switches one for fan and the other for the lights. With the compressor running, there are two so yu need to make sure it is the refrigerator and not the freezer, open the door and press the right switch and listen for a fan. The left should be your light switch and the problem is generally in the switch, on rare occasions there is a failure of bi-metal safety switch part number 4200850. One very rare occasions you may have a wiring proble.If you go to there is a showroom locator tab on the top right corner, click it and you will go to a locator page which will get you to your local parts didtributor.
Posted on Dec 03, 2008
Sub-zero refrigerator not getting cold - model 532
make sure that the compressor filter is clean -- if it hasn't been cleaned recently, can prevent proper operation.
Jun 06, 2010 | Refrigerators
Frig LED settings and bulb do not work
u might have unpluged something
Feb 13, 2010 | Refrigerators
Light bulb flickers and strange sound
that is just a small problem..try check ur bulb..maybe its loose,tighten it back..then that strange sound maybe came from spark between the bulb and its connection..
Sep 18, 2009 | Whirlpool GS5SHAXN Side by Side...
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
How do I stop mildew from recurring in my SubZero 532 side-by-side refrigerator/freezer?
First, make sure the door seals are in good shape and the unit seals. Then, use a 20% bleach / water solution to sanitize all inner surfaces and seals.
Jul 30, 2009 | Refrigerators
Compressor area above refrigerator is getting very hot
Check Thermostat.
Proper Cleaning/Defrosting of fridge and freezer.
Proper Placing and Distance from wall.
If your hand bear the body temperature of that specific area then its normal.
Contact technician to verify Freon pressure.
Best of Luck,
Jul 26, 2009 | Sub-Zero 690 Side by Side Refrigerator
Refrigerator works but no interior lights new bulbs
I have the repair manual and will be back soon. I am looking over the possibilities.
Apr 30, 2009 | Hotpoint HSS25GFP Side by Side...
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
Frig won't cool, freezer works fine
Defrost unit completely. You're frosting up. Then, avoid leaving the door open, leaving liquids and food uncovered. Clean condenser coils. If it happens again, you need refrigerant.
Jun 09, 2008 | Refrigerators
Refrigerators Logo
2,243 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
