Question about Panasonic RR-US395 Digital Voice Recorder
Do you know how to turn off the power? Which bottom should I press?
The power turns off automatically after a specified amount of time...but move the "hold" switch to on...that locks it to protect files and also turns unit off
Posted on Dec 29, 2008
I have probl?me code c111 for bizhub 601
let us try out this method lina lina never know that error code will disappear.
1. While pressing the utility/counter bot
1. While pressing the utility/counter bottom, turn ON the power switch SW2.
2. Trouble Reset screen appears.
3. Press the [Trouble Reset] key.
4. Enter Service Mode Stop>0>0>Stop>0>1
5. When CE password has been set, enter it.
6. Service Mode Menu Screen appears
7. Conduct necessary operations and turn OFF the SW2 after completions.ton, turn ON the power switch SW2.
Jan 26, 2016 | Office Equipment & Supplies
Casio Till frozen
Hi. Turn power off on bottom of machine. Hold down the top right button on the keyboard. It doesn't matter which product is programmed there, it must be the top right button. Turn on at bottom. When you see the copyright message, let go of button and press the right part of the subtotal button. when it asks to flag clear, press Yes
Dec 18, 2009 | Casio Parts Cash Register PC Desktop
I want to know how to empty the waste ink
The waste ink tank is on the bottom of the printer.To find and replace or clean it you need to disassembly the hole printer.Also need to reset the waste ink counter.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 18, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I can find nowhere on the tv that has an on off button, just got this tv
Turning the Display On and Off
There is a power switch on the bottom of the display and a power button on top. The power
switch is used to cut off power completely, whereas the power button turns the screen off but
allows the remote to continue working.
To turn the display on:
1. If the power light on the front of the display is off, turn on the power switch on the bottom
of the display.
2. Press the POWER button.
To turn the display off:
1. Press the POWER button.
2. If the display will be unused for an extended period of time, turn off the power switch on the
bottom of the display and disconnect the power.
Allso go here for full manual:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Oct 29, 2009 | Protron PLTV-32 Television
Water won't drain
To determine if your pump works, before attempting access from the bottom of the top drawer or from the bottom of lower drawer: You can manually pump the water out by doing the following:
1- Press the Power button to turn off the display.
2- Press the Lock button and then the start button the same tim. Hold them until the display showing up.
3- If the display is not clear with all the characters, press power button to see clear the display.
4- The first display is bL, then Er,Ld..dd, FU, P1, P2...by pressing the Start button to go by the sequence until P2 (drain). If you miss, be patient to continue press and release the start button to get back to P2.
5 When is is at P2, press Lock button to tun on the drain. When you hear the water flowing to the drain, you could pull the top drain to see how the water is draining.
6- When the water is out, press the lock button again to stop it.
7-When it is done, press the Power button to get out of manual mode.
If this is working, then your water is there because you are running the bottom and your air gap allow back flow to the top drawer and or you are running the top and your air gap allows a back flow to the bottom drawer.
Please let me know if this is not the case.
Jun 26, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Polaroid flm-2011 20 inch lcd television
 I will be happy to help.
  1. Turn tv on.
  2. Press and hold tv button on remote
  3. While holding tv button press and hold power(on/off) button, led light shold go off then back on after a coupke of seconds.
  4. Release both buttons.
  5. Aim remote at tv and press the power(on/off) button every 5 seconds until tv turns off.
  6. When tv turns off press the stop button at bottom of remote, that will lock in the code.
  7. Turn tv back on with remote and test all buttons.
Let me know if this helps and please rate this solution.
Lone99star
Jan 24, 2009 | Televison & Video
Need code
Hi beebeehuf, I will be happy to help.
  1. Turn tv on.
Lone99star
Jan 21, 2009 | iLO 3200 32 in. LCD Television
Power button/light
run a diagnostics
turn off your system
press and hold Fn key ,power on the system, leave Fn key
it will start running a diagnostic
if any error code is generated let me know and also provide me your system's service tag located at the bottom pannel of your system, turn it upside down you will find a bar coded sticker which has a 7 digit alphanumeric number
Jun 05, 2008 | Dell Latitude D600 Notebook
Touchscreen offset
Here's what you do: Turn off the gps. Then, hold the power button for approximately 30 seconds. The calibration screen will appear. Follow the instructions to re-calibrate the touch screen.
Feb 26, 2008 | Garmin StreetPilot C320 GPS Receiver
Panasonic RR-US395 Digital Voice Recorder Logo
110 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
