Question about Keurig B100 Coffee Maker
Keurig lights flashing
My keurig won't brew. All the lights are flashing and you can't turn it off or stop it from flashing lights unless you unplug it. I've done that several times and even left it unplugged for 30 minutes, plug it back in and lights start flashing again. I'm at a loss as to what to do.
  • 11 more comments
  • kristenstauf Mar 17, 2009
    same problem...will not prime or brew or make any noise
  • maynard_dani
    maynard_dani May 14, 2012
    Thank you, thank you!! Worked for me when I held down both cup sizes.
  • jamie_smith7
    jamie_smith7 Jun 03, 2012
    Thanks so much this was awesome! Husband almost killed with no coffee this AM! SO HELPFUL!
  • Bryan Lawrence
    Bryan Lawrence Sep 11, 2012
    Holding down the Auto Off and the both cup sizes worked for me.
  • billvaltman
    billvaltman Dec 29, 2012
    Thank you Bryan That worked for me.
  • billvaltman
    Thank you Bryan your answer worked for me
  • hansonpinc
    hansonpinc Apr 07, 2013
    wow...worked for me too, Bryan...thanks for that tidbit!!!
  • Maureen Hutchinson
    Maureen Hutchinson Oct 05, 2013
    Hi. Thanks so much it worked for me too
  • Angela Charpentier
    Angela Charpentier Dec 08, 2013
    Thank you , thank you thank you! Your advice worked like a charm!
  • Raina Nascimento
    Raina Nascimento Dec 19, 2013
    Thanks so much! I thought my machine was a goner! Woohoooooo!!!
  • Beverly Smith Mar 15, 2017
    I held down the auto/on button and the med and large cup. Then I pressed the small cup button three times. To my amazement, the lights stopped flashing and I was able to have my cup of coffee! Thank you!! 3/15/17
  • Karina Johnson
    Karina Johnson Jun 12, 2017
    Keurig told me to just re-set the clock and all 3 issues were fixed (not prompting more water please and clock flashing). Had a power outage which is what created the problem.
  • Diann Tonnesen
    Diann Tonnesen Oct 08, 2017
    That worked great!
    New Friend:
Holding down the Auto Off and the both cup sizes worked for me as well. I rcrvcd my answer from Bryan above in the comments section
Posted on Dec 29, 2012
  • 4 more comments
  •  gretchen
    gretchen Mar 05, 2013
    wow worked great thanks!!! i love my keurig and was very upset when i could figure out what was wrong with it
  •  gretchen
    couldnt
  • c_marie3
    c_marie3 Mar 24, 2013
    Really works! Yay!!
  • El Rou
    El Rou Oct 21, 2013
    Thank you! That worked.
  • Anonymous May 31, 2015
    Thanks...worked as advertised !!
  • Elaine Burr
    Elaine Burr Mar 01, 2017
    That did not work for the K145 brewer model
Just had this happen to me and ended up talking to Customer Service. Apparently, it's a bad thing to unplug them (sm. computer inside) Tho it didn't work for mine, here's their advice. With the handle down, hold down the smallest cup size and the power switch at the same time...release and immediately push the sm. size button 3 times rapidly....if that doesn't work, hold down both cup sizes and the power switch....if that doesn't work, get a new Keurig
Posted on Jan 27, 2011
  • 6 more comments
  • 5Vans Jan 27, 2011
    Correction to this....it's the auto on/off that you hold down NOT the power button
  • Brandon Abbott Nov 13, 2011
    This worked for me. it was Both cup buttons and the Auto button. This shut it off. I then pressed Power, and the unit began to heat. Normal operation now. We'll see if the problem persists.
  • Traceymc Feb 22, 2012
    Thanks...holding down the auto on/off and the small cup size worked like a charm!
    Thanks...holding down the auto on/off and the small cup button worked like a charm!
  • maynard_dani
    Thank you! This worked for me, holding both cup sizes down to turn it off. Then worked fine after powered on again.
  • khilton0619
    khilton0619 Aug 26, 2012
    WooHoo! Thanks 5Vans!! Did EXACTLY what Keurig told you to do and it worked like a charm! Holding auto on/off and small cup at same time and then pressing small cup three times rapidly reset the computer and so far no more lights flashing! Thanks for posting!!
  • Brandi Brown-Hibbert
    Brandi Brown-Hibbert Dec 24, 2012
    Well it worked for me. We had some issues and had to total take the machine apart and clean it. Well when I turned it back on all lights were flashing. Held down auto on/off and pushed small cup and it reset!!!!! Thank you Thank you Thank you
  •  gretchen
    i tried this an it didnt work i dont get it i did it 5 times and still flashing
    New Friend:
Held down both sizes and auto on/off button and it worked! Thanks a bunch
Posted on May 19, 2013
  • 1 more comment
    This worked for me too. Thanks!
  • Anita Beliovsky
    Anita Beliovsky Feb 18, 2017
    both sizes? i held down med and large and auto power worked! thank you!
  • Anonymous Mar 18, 2018
    I did This for the K40 and it worked. I had cleaned the unit and got water where it shouldn’t have been. I let it dry thoroughly and it flashed,,,, great to have it back
    New Friend:
Apparently with a power surge, the pump kicks on and dispenses all of the water in the tank by itself. ALL OF THE WATER! Not too bad if you're at home and catch it but when it's in your office and it happens at night...
Holding down the two cup sizes and the Auto Off button did the trick for me. I had to do it several times until the pump filled the reservoir. Then the first cup to brew took a little longer to start, but it eventually brewed like it was supposed to do.
Posted on Feb 12, 2013
    New Friend:
Thanks sooooo much!! I pressed down on auto on/off button and small cup size at once and it worked.. My coffee pot is no longer going crazy with all the lights blinking
Posted on Nov 25, 2012
I had the same issue and called Keurig. Since I had registered my product, they sent me a new one and I had it in three days. They told me they have had numerous reports about this and there was no solution. All I had to do was send back the kcup holder out of my old pot. I would give them a call - they were extremely helpful.
Posted on Apr 03, 2009
    New Friend:
I pressed the auto on button, the med, and the large cup all at the same time, then I pressed the small cup button three times. Worked like a charm
Posted on Mar 15, 2017
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: KEURIG DOES NOT STAY READY TO BREW. I WILL NOT
Here is a tip that I wrote about how to register your Keurig Coffee Brewer, get manuals, and cleaning or troubleshooting guides.
Keurig Registration, User Manuals, Cleaning, and Troubleshooting
heatman101
Posted on Mar 01, 2011
How do I fix a Keurig V1255 with a flashing LCD display?
Keurig Platinum Reset for the Not Ready Light - YouTube
? 1:21
https://www.youtube.com/watch?v=xjWIQpttTc8
Jun 22, 2010 - Uploaded by Lsailor1
This is a reset method for using on the Keurig Platinum B77 coffee ... Show more ... set to brew in morning ...Missing: v1255
Fix Keurig Vue V700 Not Brew
Nov 14, 2015 | Vue V1255 Professional Brewing System...
All my lights are flashing and they don't want to stop mashene is not working
1. Press the auto off and small cup at the same time. Then Immediately release and re-press the small cup three times.
When it works the only light showing will be the descale light.
2. Press the small cup button then auto off button then release small cup and then auto off, when this works the lights on will be the power button light and the descale light.
ALL OF THE ABOVE DURING THE PROCEDURE MUST BEEN DONE FAST OR RAPIDLY.
3. When both of the above lights are on,(power and descale), unplug for about 3 to 5 seconds... and plug back in. The brewer should come to life and work normally.
Below is the address and Phone number to Keurig warranty service.
Keurig, Incorporated
101 Edgewater Drive
Wakefield, MA 01880
1-866-901-BREW (2739)
Nov 12, 2014 | Keurig B40 Single Cup Home Brewing System...
My keurig is flashing NOT READY and AUTO OFF SET and won't brew or even turn off
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 02, 2011 | Keurig B60 Coffee Maker
My 9 month old machine only spits out water for a second
I called Keurig and they felt that it was likely a blockage at the needles, but despite cleaning them repeatedly, there was no improvement. They are sending me a replacement.
Sep 16, 2009 | Keurig Platinum B70 Coffee Maker
Keurig B100 Coffee Maker Logo
24,276 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
