Question about Supersonic FC2245 13 Color TV/DVD Combo Television
Tv runs on 110 but not 12volt
We have Supersonic Model SC2200 13" color TV w/DVD Player. It works fine in the house on 110, but it wont work in the truck on 12 volt
any suggestions.
    President:
  • 2,992 Answers
There is a fuse on the DC power line for AC/DC sets and you can start by making sure it isn't blown. The fuse may be in the cigarette lighter plug itself, or inside the TV. If you find the fuse blown, replace it with one of the same value and try it again. The fuses sometimes do go for no good reason. If there is some internal trouble with the TV, the fuse will go again and you'll know for sure.
Posted on Dec 01, 2008
We have a hightlander Pvr6000 dvd recorder / player. It was working fine and we moved house. Since moving when we plug it in the movies only play in black and white. Before we moved all the movies wer
check colour system settings - NTSC or PAL what is your tv normally using - check DVD PVR6000 has color system on matching TV color system.
Can't find the user manual online as the specific make and model number were not given for the device.
if you google search or yahoo search for
{make} {model number} user manual
{make} put what the make of dvd player is eg highlander
highlander is my guess and my guess of model number is DH-2816 but it is only a guess .
Feb 02, 2018 | Televison & Video
I messed up with the video settings, and now I cannot get a signal. I guess that I am still accessing the menu, but cannot see where to change the settings because there is no picture. Maybe a reset to...
Hello Alfredo. turn on the tv and the DVD player. Use the tv remote and push the input key. When you do that you will see a list of choices. One of them is DVD. Click on it. That said, if that doesn't give you a picture from the dvd, go down through the list one item at a time and you will find it. Joe
Nov 15, 2010 | Supersonic SC-22D DVD Player
My SuperSonic TV combo want reconize my USB drive
Contact the company for a solution. or go to their web site for answers.
Mar 13, 2010 | Supersonic FC2245 13 Color TV/DVD Combo...
Craig dvd player, model CVD327, won't play
no, s video is not required to work. if you hooked up 3 colors to the tv 3 colors. make sure it's on video 1 or aux channel. and as long the dvd player is on and that channel is on, if that does not work, try on another tv that has same connection. if that doesn't work, then we know that dvd player doesn't work.
Oct 17, 2009 | Televison & Video
I simply don't understand how to hook up the DVD
OK simple mind maybe this will help. Cable bos to DVD and DVD to TV. A set of red and white cables are for hearing (audio) ( red is general right and white is left) the holes that you plug them into should also be color coded the only real trick is that they are flowing in the correct direction. They should go out from the cable box in to the DVD and then a set should go out from the DVD and into the TV. The Yellow is for video on some units. Not all units need the yellow. Since it is cable there should be a cable connection from the wall to the cable and the only place that might need the yellow is from the DVD to the TV depending on your model of TV. Mine for example, uses an HDMI cable instead of the yellow plug ins. Hope this helps!!
Jun 15, 2009 | Supersonic SDAT SC-25 DVD/Karaoke Player
ATTACHING AN ALTERNATE dvd PLAYER
attach the euroschart end the tv work av possition
May 20, 2007 | Supersonic SC-999TDVD 13 in. TV/DVD Combo
NO Picture in Color except for PIP
have a tech check your tv the color circuit needs to be looked upon.good luck
Apr 29, 2007 | Akai PT5492S 54" Rear Projection...
DVD Keeps Ejecting
The Supersonic FC-2245 has known DVD issues and thousands were returned for credit. You may not have a solution. They are also being replaced by the FC2835
Nov 22, 2006 | Supersonic FC-2245 13" TV/DVD
Supersonic FC2245 13 Color TV/DVD Combo Television Logo
194 people viewed this question
Top Supersonic Televison & Video Experts
Demonic-2011
Demonic-2011
De ice
De ice
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
