Question about Eureka 431BX Bagless Upright Vacuum
Motor Fried? Eureka 431BX Vacuuming, and then all of the sudden the motor just stopped. Well idk if it's called the motor; the beater bar still spun, it was just the fan that stopped spinning Here is the whole vacuum in pieces http://i28.photobucket.com/albums/c237/SirFafner/Vacuum001.jpg Bottom Part, beater bar already taken out [Functions Fine] http://i28.photobucket.com/albums/c237/SirFafner/Vacuum002.jpg White Wire connecting to the fan motor [Looks black, i think it's fried, and that's the problem maybe] http://i28.photobucket.com/albums/c237/SirFafner/Vacuum003.jpg The Top of the fan http://i28.photobucket.com/albums/c237/SirFafner/Vacuum004.jpg Grey Wire connecting to fan motor [Opposite side of the white wire, also black, looks fried] http://i28.photobucket.com/albums/c237/SirFafner/Vacuum005.jpg Larger angle of the whole fan motor http://i28.photobucket.com/albums/c237/SirFafner/Vacuum006.jpg Another view of the blackened white wire http://i28.photobucket.com/albums/c237/SirFafner/Vacuum007.jpg Another angle of the whole fan motor http://i28.photobucket.com/albums/c237/SirFafner/Vacuum008.jpg NOTE: this whole thing has been cleaned. Prior to this, the whole inside of the compartment containing the fan motor was filled to the brim with dust. Imagine the most dust that could fit in it, and double that. So yeah, i think the filter failed or something. So basically, i just want to know if it's the wires that are broken, what i could do to replace them if they are, or if it's something else. If anyone needs any more info, please ask. I don't want to buy a whole 'nother vacuum... this one is only about 3 years old
  • Linda Messmer Dec 01, 2008
    My new vacuum has only been used 3x and 2 of those x the motor shuts off after about 1 min.!!!!! The vacuum is clean. I don't have the box to ship it back and it said not to return to store.I would never recommend this cleaner to anyone.
  • sirfafner Dec 02, 2008
    cool, i spent a couple hours, opened the whole motor up, and some wires got disconnected from eachother, maybe the thing was spinning too much? The padding inside was a little worn, so i replaced it, and now the whole vacuum works great. Thanks for the help
Funny you said that,I went today and bought a bissel at Wal-Mart.Sure hope it lasts longer then the Eureka did.I will probably try to take the other one back to the store if I can find the receipt.Thanks so much.
Posted on Dec 02, 2008
  • 65 Answers
Kind of hard to say. these are pretty simplistic vacuums. the beater bar is still spinning because it has a seperate motor. the main motor which creates the suction sounds as if it overheated and just gave out. in most cases a replacement motor would cost you 79.99 usd. if the wires are broken make sure first before going any further. take it apart and inspect them and make sure they are on the motor itself correctly. usually eurekas are coded so they only go on one way but im not completly familiar with this unit. so check that and make sure every connecting point is snug and secure.
Posted on Nov 30, 2008
  • CJ C
    CJ C Dec 02, 2008
    i would just return it to the store. i says not to return to the store because the company *eureka* then looses its sale. as long as you have your reciept you dont need the box. i would just rturn it and if you ar looking for a small vacuum like this unit may i recommend a http://www.walmart.com/catalog/product.d... they are smaller, lighter and bissel is a very good company. their products last.
I purchased a Eureka C4910 last year and have a question that I am hoping you can answer. There are two motor actions with this vacuum, 1) the vacuum suction, and 2) the beater bar. The action of the...
Good day!
Normally when the motor is easily moved back and forth means that it have a proper lubrication,proper alignment and no clogs.
When the motor and the belt is OK the problem could be on electrical wiring and switch.
If found electrical switch burned out you need to replaced it because when the switch is burn the contact of that switch is open even you turn it ON.that's why the motor is not function because the voltage is not pass through the circuit because of open switch.You need to replaced it.
And check some fuses if any and other burned electrical wire.Replaced it also.
Thank you and don't forget to rate my answer.
May 28, 2011 | Eureka C4910 Bagged Upright Vacuum
I have a Eureka 'The Boss Smart Vac'. The beater
Yes, you need to replace the belt. You should actually change this belt every year. Here is a link to the belt you need and the manual which has instructions:
Eureka The Boss Smart Replacement Belts
Owner's Guide (3,666K download)
Dec 09, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka 431BX Bagless Upright Vacuum: i would like to know how to replace and if there is a specific type of belt to use?
Here is a link to the exact belt you need to replace (the belt should be replaced yearly for optimum performance) and a manual you can view which has instructions.
Eureka 431BX Replacement Belt
Owner's Guide (1.1 MB download)
Dec 07, 2009 | Eureka 431BX Bagless Upright Vacuum
Eureka 431BX suction stopped working. Roller still goes. Please help! Everything else is working great.
Even though the brush is spinning, you probably need to replace the belt2_bing.gif because it is stretched. It is probably slipping on the beater bar..
Jim
Nov 30, 2009 | Eureka 431BX Bagless Upright Vacuum
Vacuum won't pick up any dirt - there's no roller marks when vacuuming carpet. Roller does turn and filters are clean.
When you turn the roller, you should feel some resistance from the belt. Remove the base blate that surrounds the beater bar. Check the belt. Take care in removing the beater bar, so you can get it back in the same way it comes out. Clean the beater bar while you have the bottom open. If you remove the beater bar to replace the belt, take the time to inspect the cavity behind the beater bar where the vacuum picks up. That is where vacuums usually stop up. Reassemble the vacuum. If necessary, slip the belt over the motor shaft and then slide the roller undre the belt. Install the beater bar back in the sockets and replace the base plate.
Best regards,
--W/D--
Aug 12, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Change belt on a eureka
With the vacuum unplugged, turn the machine beater side uo. On the plate that surrounds the beater bar, look for release tabs to open the plate. Flip them and set the plate to the side. The beater bar rides in sockets. Remove the bar, install the new belt around the motor shaft, then work the beater back into the sockets. Replace the plate. Test your work by rotating the beater bar by hand, making sure that it is reinstalled correctly.
Best Regards, --WoobieDog--
Jul 10, 2009 | Eureka Vacuums
Slipping belt onto motor shaft pulley
On most vacuums, you:
put the belt on the motor,
slip the beater bar thru the belt,
put the end opposite the belt into the frame,
stretch the belt and put the belt end of the beater bar into the frame.
Hope that helps!
Apr 25, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Beater Bar Does not turn
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
Dec 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Vacuum turns on and suction in hose works, beater bar won't turn
If you hear the motor in the head running and the beater bar isn't rotating, you probably need a drive belt. With the power off, make sure you can rotate the beater bar freely by hand, if it isn't bound up.. then locate and remove the baseplate screws to gain access to the beater bar itself, you'll see a drive belt pulley system and chances are, a broken belt. Replace it with a new one by pulling the beater bar assembly out of the housing and plcing the belt onto the motor shaft pulley as well as the beater bar pulley.. nest the beater bar back into the holder and reinstall the cover. Hope that helps !
Aug 14, 2008 | Eureka Vacuums
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Eureka 431BX Bagless Upright Vacuum Logo
119 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
