Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Will not heat up ink.... - Xerox WorkCentre C2424DN All-In-One Laser Printer
  • Rick Kasper May 11, 2010
    Is there a fault code being reported on the screen. A number like 37,002,888.83474 or 09,044,055,08089987 ? That would be very helpful in determing your problem.
    Novelist:
  • Xerox Expert
  • 297 Answers
If it won't heat up the ink you will need to replace the ink loader assembly.
Ink Loader Assembly and Door - Part Number: 200471180
Posted on Jan 17, 2009
What is the difference between cold and hot laminators?
Hot laminators are the most common types of laminators. They use heat (220 to 300 degrees F) to apply the lamination. Hot laminators provide a better quality lamination that is more resistant to wear and tear. This is the preferred method of lamination for materials that are not effected by heat.
Cold laminators use pressure sensitive adhesives to bind the lamination film when the material being laminated is sensitive to heat. Certain inks in standard ink jet printers are known to have the ink melt in the machine. There are other types of printers that use heat sensitive paper. For these types of applications the cold laminator is the best choice.
Jan 28, 2013 | Office Equipment & Supplies
Ink has run out ??? it no longer prints... TSP100 How do we change the ink roller/cartridge or whatever it requires?
TSP100 Thermal Printer work with a thermosensible paper, there is no ink to change, if the print quality is poor you have to
  • check the paper roller, it can be wrong installed.
  • Check the upper cover if not closed properly close it.
  • check the print head or the pressor roller.
Jun 13, 2011 | Star Micronics TSP100 Thermal Printer
I want to know what is inside the printer cartridge
The ink cartridge are of different type and contains ink in different form.
  • Thermal Ink jet Cartridge (HP, Canon) - The cartridge contains a liquid ink, which is heated by a heating plate on the cartridge. A bubble is formed which forces the ink which comes out of the nozzle.
  • Piezoelectric Cartridge (Epson) - The cartridge contains piezoelectric crystal, which when current is applied changes shape and size forcing ink out from the nozzle.
  • Toner (Laser Jet Printer) - A drum contains powdered ink (toner), which is spreads on the paper using negative and positive charges and the heater sticks the ink on the paper.
Regards,
Shrey
Jun 07, 2011 | Computers & Internet
Open heat error
A laser printer uses a "fuser" -- it produces heat, and melts the DRY ink into the paper, to "bond" the paper and the ink.
If you have a "heat error", then the fuser is not working correctly.
Call the local XEROX office, and schedule a service-call for their technician to replace/repair the fuser.
Jan 31, 2011 | Xerox WorkCentre M15 All-In-One Laser...
Difference between electrostatic and inkjet printer
This sounds like a "homework" assignment.
An electrostatic printer puts electrical charges onto a drum.
Then, dry "powder" ink is put onto the drum.
The ink sticks only to the charged points.
A piece of paper is rolled against the drum.
The "fuser" heats the paper, and melts the ink into the paper, permanently "fixing" onto the paper.
An ink-jet printer shoots microscopic drops of wet, heated, ink onto the paper.
The ink dries into the paper.
Jan 27, 2011 | Nikon COOLPRINT Thermal Printer
Thermal head
The "thermal head" heats-up the ink and the paper, in order to "melt" the ink into the paper, and thus "fix" it. When it fails to produce heat, all the printed pages will have ink that can be smudged, when you touch the printed page.
It might be less expensive to REPLACE the printer than it would be to REPAIR the printer.
Dec 20, 2010 | Mitsubishi P-91W Printer
DO I NEED INK REPLACEMENT?
All you need to do is CHANGE THE BATTERIES! This is a thermal printer that does not use ink, BUT...when the batteries are old/weak they will not generate enough voltage to heat the thermal cartridge paper properly, resulting in faint, poorly printed letters.
Jul 14, 2010 | Dymo LetraTag QX50 Thermal Label Printer
My Canon MX300 has a replaced 'refilled' color ink cartridge and the light shows there is a problem - how come this has worked before but now I can't get it to work as before?
Hi and thank you for using fixya:
Please do the followings to fix your problem:
1-reinstall drivers of the computer 2-reset button on printer to let the printer know there are new inks. 3- please make sure you took out the protective film on the bottom of the new ink cartridge
good luck
Apr 19, 2010 | Canon MX300 Office All-In-One Printer
No longer printing - looks like its out of ink - what to do?
A thermal printer doesn't use ink at all. It uses a special heating element to heat the printing surface, which makes a special chemical in it turn black where it gets heated. If the unit doesn't have fresh batteries, the unit may not be able to produce the heat it needs to print. If it has fresh batteries and the correct cartridge, the unit needs to be replaced.
Oct 13, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Copy comes out dirty and ink comes off when touched.
If your copier uses toner and not ink then it sounds like you have a fuser issue. Your fuser heats up and through heat and pressure it causes the toner which is a powder to "fuse" to the paper. If teh toner is smearing off then the fuser will need to be looked at. There is eaither a heating element or a heating lamp that has burned out and will need to be replaced by a tech.
Sep 28, 2009 | Canon Office Equipment & Supplies
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
27 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
