Question about Dell Dimension 3000 PC Desktop
Error message #443 in Firefox
This appeared on Firefox after I went to our RX refill site--wellpointnextrx.com. I had no problem on the site. It just came up afterward. I will not leave for more than a few seconds when I click OK or X. It is not there if I go out of Firefox and change to IE7 but I prefer Firefox---normally. Help!!
You can also go into Tools - Options - Advanced - Encryption - and then click on "View certificates". Find "GeoTrust SSL CA". Click on it and then click edit. Then check the first box that says "Can identify websites". Should take care of the problem.
Posted on May 03, 2011
    Novelist:
  • 157 Answers
Ack! Watch out- I tried to go to the same site using firefox on my machine and the security feature stopped me from doing so by saying that it is a suspicious site with invalid security certificates. The error message is a fake- go ahead and update to the newest firefox (which I love as well) at mozilla.com
Hope this helps,
TJ
Posted on Nov 30, 2008
When I turn firefox on I get xml.freecause.com:443 error
This likely is a problem with an add-on or a tool bar.
Try this: 1.Start Firefox in Safe Mode- Hold shift while starting Firefox. If prompted select Continue in Safe Mode. 2. If Firefox starts in Safe Mode, select Tools>Add Ons 3. Select Extensions on the left side. This will give you a list of your extensions. 4. Pick one extension and click disable. 5. Now close Firefox and open it normally. If you dont get the error, you know which one was giving you trouble. You should remove that extension or check for updates. 6. If you get the error again, start from step 1 and choose a different extension each time.
Notes: A: If somehow you get the errors in Safe Mode you can click cancel on the popups until you are able to continue OR you can set the date back on your computer by a day or two. B: Toolbars that track airline miles and Gamersunite snagbar have been known to cause this error.
I hope this helps.
Sep 25, 2011 | Mozilla Firefox
I get xml.freecase.com:443 pop up window with that message.....and won't go away.....what is up?
It has an obsolete SSL certificate. You can grant a security exception for it, or wait until the webmaster updates the certificate.
I keep getting Xml.freecause.com:443 and can't close it out already uninstalled and reinstalled what do i do
When you reinstalled firefox, did you also remove add-ons and toolbars? If not, try disabling any new plugins or toolbars you have recently installed and then enable them one-by-one to figure out which is causing the error.
Error message xml.freecause.com:443
I have come across similar issues and got it resolved by The Best Pc Doctor Team.
You can also contact them on their toll free number.
www.thebestpcdoctor.com
877 407 9229(Toll free)
This is usually caused by a bad plugin or toolbar you have downloaded. Try disabling any new toolbar or plugin and see if you can narrow down which one is causing the error.
I uninstalled and reinstalled mozilla and I am still see this same error message xml.freecause.com:443
Mozilla installer complaint choose another browser
Reinstall OS then use Mozilla.........OK
Us data toolbar.yahoo.com 443 uses an invalid security certificate.
I started getting the same message/problem when I upgraded Firefox to the latest version. I went to google and searched Firefox - until I found another version 3.5. I installed 3.5 and have had no problem since.
Aug 02, 2010 | Yahoo Mail
While accessing mail i am getting message (error code:ssl_error_rx_record_too_long_
Error code: ssl_error_rx_record_too_long Your SSL website may fail to load and display the error
This usually means the implementation of SSL on your server is not correct. The error is usually caused by a server side problem which the server administrator will need to investigate.
Below are some things we recommend trying.
- Ensure that port 443 is open and enabled on your server. This is the standard port for https communications.
- If SSL is using a non-standard port then FireFox 3 can sometimes give this error. Ensure SSL is running on port 443.
- If using Apache2 check that you are using port 443 for SSL. This can be done by setting the ports.conf file as follows
— clip —
Listen 80
Listen 443 https
— clip —
- Make sure you do not have more than one SSL certificate sharing the same IP. Please ensure that all SSL certificates utilise their own dedicated IP.
- If using Apache2 check your vhost config. Some users have reported changing <VirtualHost> to _default_ resolved the error.
Mar 18, 2010 | MPC Computers ClientPro 125D PC Desktop
Dell Dimension 3000 PC Desktop Logo
338 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
