Question about Webroot Spy Sweeper (spysweeper) for PC
My spy swepper is not coming on. window with error keeps coming up. I have tried every thing to restart the program. Also I am just learning how the computer works.
  • 53 Answers
Uninstall the program then close all other programs you have running and reinstall
if that dosent work you can install the yahoo tool bar and they have a new free feature is a spyware detector use that and see if you have any spyware if you do have it remove it then
try and reinstall your spy sweeper
Posted on Nov 30, 2008
  • 25 Answers
Easiest solution is to uninstall and reinstall the software
Difficulty uninstalling webroot off my computer
Right-click on the Webroot Spy Sweeper icon on your computer's taskbar. A menu for the program will appear. The taskbar is the bottom bar of your computer. The Webroot Spy Sweeper icon looks like a green bulls eye.Select "Exit" from the Webroot Spy Sweeper menu. Select "Yes" if asked if you wish to shut down the program.Click on the "Start" icon and select "Control Panel."Click on "Add / Remove Programs" if you are using Windows XP. Select "Programs and Features" if you are using Windows Vista or 7.Click on the "Webroot Spy Sweeper" program listing.Click on "Uninstall." A Webroot Spy Sweeper uninstall wizard will open.Select "Uninstall" in the wizard and hit "Next." Follow instructions on screen.Restart the computer if prompted.Click on "Start" and select "All Programs."Right-click on the "Webroot Spy Sweeper" folder and select "Delete."
Jun 14, 2011 | Computers & Internet
Cannot Uninstall Existing Version of Webroot Spy Sweeper
try removeing the program from add or remove programs.
start -> control panel -> add or remove programs.
find the program from the list and click uninstall or change, which ever it may say.
Jul 29, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Normally when my webroot is doing a scan it runs thru the files pretty fast and even if it comes to a large file it only stays there for a few seconds and then proceeds on. However, now it comes to a...
Does that happen with full system scan or only with other types of scans , If that happens with full system scan , that means that your spy sweeper needs to be uninstalled and restart the system and then install it again and restart your system . and try now to sweep . now ! rate please !
Jan 14, 2010 | Webroot Spy Sweeper (spysweeper) for PC
Windows 95 I SPY wont run on Windows XP
Try this
Right click rather than left click whatever it is that you put the cursor on to try to run the "I Spy" program.
Click properties (by the bottom of the popup window)
Click the compatibility tab on the new popup and then select Windows 98.
Then try running the program by right clicking.
Jun 03, 2009 | EA Sports Spore Creature Creator for...
I need to shut down spy sweeper and reinstall - how do I do that?
Restart your computer--> black screen--> after the Bios check (is always the 1st step)--> start pressing the F8 key repeatedly--> Windows boot menu will apear--> use the arrows--> Safe mode
It will look different from you normal Windows (don't worry about this)--> go to Add / remove programs--> Uninstall your spysweeper program--> restart your computer normally--> install your program normally
Nov 11, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Webroot spy ware
You will need to uninstall and install your program
It will look different from you normal Windows (don't worry about this)--> go to Add / remove programs--> Uninstall your spysweeper program--> restart your computer normally--> install your program normally--> check for updates
Nov 07, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Uninstall
Hi Jeli
most effective way to uninstall Spy Sweeper is to go to Control Panel and then select Add and Remove Programs. In this case, you may try to follow the instructions below.
1.right click on the Spy Sweeper icon on the right hand side of the toolbar where the clock is located and select exit
2. press ctrl + alt + delete which will open the Task Manager.
3. Click on the Processes tab. Search for spysweeper.exe. If this process is running click on it then select end process.
Repeat this step to search for and close the process WRSSSDK.exe. After this is done Spy Sweeper should be able to be removed by using Add/Remove Programs
Keep me posted.
Thanks.
Oct 12, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Spy Sweep problem
well what I would suggest you is to go to control panel and then add/remove program and remove spy sweeper and restart the computer
Then reinstall spy sweeper and run the complete scan
Or
visit http://www.google-pack.co.cc click "get essential softwares ..." you get Free! Norton Security San and Spyware Doctor
then check the softwares you need; next is download after that on the next screen click help google.... and start download; then Run and after the downl id done run once again and let it install
This will remove all the spywares from the system and speed up your system
Aug 04, 2008 | Microsoft Windows Vista Ultimate Edition
Spy problems
First Try This:
Try to uninstall Spysweeper and reinstall (Control Panel -> Add Remove Programs)
If it gets nasty reboot in to safe mode (follow these steps):
1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the "Windows XP with networking"
Once you are in safe mode do this:
1. Download the free microsoft app "Autoruns" from http://download.sysinternals.com/Files/Autoruns.zip
2. Extract the .zip file
3. double click the file "autoruns.exe"
4. The program will start autoscanning your computer to see what boots up with it (it will take a few min.... bottom left of screen tells you when it is done)
5. Make sure you are in the "Everything" tab (which loads up by default)
6. Hit CTRL + F (to do a Find)
7. Type "Spy" and hit ENTER
8. The first entry containing the word "Spy" in your startup instructions will be highlighted
9. Look at the "Image Path" column, if it contains anything like "C:\Program Files\Webroot\Spy Sweeper\" uncheck that item
10. Press F3 to see the next item containing the word "Spy"
11. Keep repeating steps 9 & 10 until you get through the entire list
I'm guessing you might find the following:
C:\Program Files\Webroot\Spy Sweeper\SpySweeper.exe
C:\Program Files\Webroot\Spy Sweeper\SSU.EXE
C:\Program Files\Webroot\Spy Sweeper\SpySweeperUI.exe
12. Reboot as normal (spysweeper should not load up)
13. Attempt uninstall, reinstall again
Jan 05, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Webroot Spy Sweeper (spysweeper) for PC Logo
97 people viewed this question
Top Webroot Computers & Internet Experts
Mike
Jerry
Jerry
Are you a Webroot Computer and Internet Expert? Answer questions, earn points and help others
