My colors on my display is only saying i have 16bit or 2 bits of color to chose from and my computer calls for 230 i think i may have deleated something
    President:
  • 2,110 Answers
First download Graphics driver for ur motherboard...
Posted on Nov 30, 2008
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
Help Screen says No Signal on Input #2
Adjust the screen resolution down a notch or two in the display preferences. The computer is most likely set at 1280x800 pixels at the High (32bit)color. You may even want to drop the 32bit down to Medium (16bit)
Feb 10, 2010 | Sharp Notevision PG-B10S Multimedia...
Wont let me connect it says display setting to 16-bit,800x600 resolution or higher
That refers to the PC's display settings. Use the Control Panel to set the display settings as suggested; 800x600 pixils, with 16 bits of color or higher.
Jan 25, 2010 | ION Audio VCR 2 PC USB VHS Video to...
My computer says i need to change my color depth, how do i do so?
You can change the color depth by right clicking on the desktop, click on properties, click on settings. You will see something as color quality, you can change it, thats also known as color depth.
Regards,
Shrey
Oct 10, 2009 | Computers & Internet
Color Problem
all of you mentioned are correct. if they cannot work on color setting of your monitor and for the setting of your resolutions it could be the monitor. the monitor cannot support the color bit mode which required for the windows vista it could be a 16bit color mode which only display for not more than 63herts for the Hi color vsynch compare for the 256color if you have a Hi color settings for about more than 63herst vsynch. it cannot display properly. thanks
May 10, 2009 | SVA-USA VR 17 17" Flat Panel LCD Monitor
Restart at 32 bit depth color
Use System Failure Settings to Stop Automatic Restarts.
1. Click Start and Open the Control Panel
2. Go to System.
3. Select Advanced Tab and then go down to Startup and Recovery.
4. Settings then uncheck the Automatically Restart.
Try that and see if you can sort it out from there. Hope this helps!
May 08, 2009 | Nvidia G-Force FX5200 256M DDR 8X AGP...
Graphics
gointo control panal to display or right click goto properties and click, goto colors select 16bit or 32 bit
or
advance setting and look threw the options that best fits your needs.
rod
Feb 03, 2009 | Intel Microstar MS-6526 Pentium 4 ATX...
THE PICTURES AND THE COLORS ON MY COMPUTER LOOKS LIKE DRAWINGS.
dear rdiimeondz,
this shows that the problem is with your video driver or
check this one out.
1. right click on your desktop.select properties.
2.select settings tab.
3.on the colour quality.select the drop down menu if it is set as 16bit change it to 32 bit
and select apply ok.
if still the problem persist then check whether the video driver is properly installed or not.
thanks,
Oct 01, 2008 | Computers & Internet
Analog Monitor problem
The problem in your monitor is SRGB
Use 3 simple steps to rectify this problem
1. Connect your monitor to another CPU
2. Change The Resolution to 800x600 32/24bit
(After 2 Miniuts SRGB will Reset)
3. After 5 Miniuts change the monitor to your CPU
Thank U
Apr 06, 2008 | Computers & Internet
256 color properties
you need to check your display driver it is a correct one.or re-install the display driver again.hope it help
Aug 05, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
