Question about Kenwood VR-606 Receiver
VR-606 DTS won't work
I have tryed this many different ways but it seems that my vr-606 needs both optical and coaxal to use dts and I'm trying to use my Playstation 2 or XBOX360 and they only have optical I'm trying to avoid buying a new dvd player
  • kenwoody12 Mar 26, 2008
    My digital audio optical input does not seem to work. Only the Coaxial Digital Audio input works. This seems to be a problem as the Sony PS3 doesn't have a coaxial digital out only an optical one.
    Is there some setting I can change to make my optical input work?
All I can tell you is that "CD/DVD" must be selected as the source when using the optical digital input on the VR-606/616. I don't believe it needs more than one input (optical or coaxial) to output DTS sound, assuming the source is outputting DTS in the first place.
Posted on Aug 25, 2008
The subwoofer output on my Kenwood VR-606 has suddenly stopped working. I have tried the "setup" several times, turning the subwoofer off and back on. Also, when I first power up the system, it emits a low...
It sounds like the problem is not with your VR-606. If you hear a hum from the sub, the problem is more likely to be in the sub's built-in power amplifier. However, it is worth resetting the amplifier to factory presets. To do this, unplug the power cable from the mains supply and reconnect whilst holding down the power on/standby key. If the hum persists, connect any powered speaker to the sub-out socket, power on and listen for the hum. If no hum then suspect the powered sub amp. Turn the sub on with no connection to the Kenwood VR-606. If hum persists, the sub has a problem and will need to be replaced or repaired. By the way, you said there is a low frequency hum through the 'speakers' for about 30 mins. Is that all speakers or just the sub? Hope this helps.
Cheers, Don.
Jul 06, 2014 | Kenwood VR-606 Receiver
Optical Audio Output Formats for PS3
look in your receivers manual or download it using a google search
Dec 23, 2013 | Kenwood VR-606 Receiver
I have a new Samsung 47 in LCD and Kenwood DVD purchased in 2005. I am trying to hook both up to get surround sound from my Kenwood VR-606. My signal is coming from a HD cable box. I'm using HDMI from the...
Without additional equipment it can't be done. As i see your VR-606 pure analog device, and you trying to somehow use 5.1 sound from HD STB that is on HDMI put on RCA connectors of your VR-606. It is impossible without converter from HDMI to Analog audio or something likethis, best way to buy new receiver with HDMI input and TV neither Receiver with HDMI out oportunity. Then you will have your home cinema. In your current setup probably you can play only with stereo from your stb.
Apr 19, 2010 | Kenwood VR-606 Receiver
DTS option shows on the display when playing a DTS movie, but unit will only play in Dolby when trying to select listen mode...I can't select DTS mode
That is a typical function of the movie you are watching..changing the sound mode can "usually" only be done by selecting it on the disc, or by using the audio button on your player depending on the model.
Dec 23, 2009 | Kenwood VR-407 Receiver
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Oct 24, 2009 | Kenwood VR-405 Receiver
Different Audio options from an older receiver
If your receiver has a multichannel input and the player has the multchannel output then that is the only way you can get surround sound from it with source inputs that it cannot decode, such as DTS. The player will then do it alone.
However, in the setup menu of the blu ray player you should be able to change the audio output to downmix to 2ch audio...at least you'll get to watch the movie.
Jun 14, 2009 | Kenwood VR-405 Receiver
My dts is not coming on when I attach it to the dvd with optical
DTS will only come on if you are playing a dts dvd,most of these dvd,s need you to pick dts in the setup menu or sound settings.If you have done this make sure dts out is set to on in your dvd player.
Hope this helps.
CABLE GUY.
Apr 20, 2009 | Kenwood VR-505 Receiver
Dolby Digital Has Stopped Working
i sthe thx dobly digtal button on off or on auto ?
Nov 14, 2007 | Kenwood VR-505 Receiver
Surround sound not working properly
Hi guys,
Make sure that your sound aka dvd or whatever is set for a DTS (5.1) set your dvd at bitstreem and your receiver to automatic detection. When your movie will start you will heard your Receiver Relay//Mosfet clicking and a Red led will say DTS once you get there you will be able to select your Doldy digital surround the real one.
Ps: if you want to reset your VR-309 to default HOLD the POWER button for 5 sec unplug it from the wall hold it for 5sec while unplugged and replug it will be rested to default.
Oct 27, 2007 | Kenwood VR-309
Kenwood VR-606 Receiver Logo
267 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
rigger094
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
