Question about GoVideo HT2030 System
Rio HT2030 Cannot get sound from 2ch DVDs (older movies or kids shows) yet newer dvds play just fine. I have messed around and searched for answers to no avail. Seems like a software issue. Help please. JD
  • 2299 Answers
SOURCE: How do I connect my
This is going to depend on your preference. But the easiest way is to go get a fiber-optic cable and hook from the audio out on the tv to the audio in on the Rio. The cables are not that expensive anymore. And they are worth every cent. They are super easy to install and get a lot better sound quality.
Posted on Oct 22, 2010
0 characters
1 Points
The dvd has started playing everything green. We never record and have only played about 25 dvds in it.
Sounds like the settings for the dvd output have been changed. Need to have it re-calibrated.
Apr 08, 2015 | Home Theater Systems
We can't hear spoken audio on our recent dvds (movies), only the music. Some of the the older movies are fine.
Your center channel speaker is not working. In modern 5.1 movies dialogue only comes from the center channel. Older movies were stereo/mono so the dialogue would come from both the front speakers.
See if the speaker wires are intact and not loose. After that to confirm if the speaker is OK or defective exchange the center speaker with one of the working ones.If the center speaker does not produce sound, you will have to replace it. But if it works, that would mean that your center channel amplifier is not working & for that you will need professional help.
Mar 12, 2011 | Samsung Home Theater Systems
Certain dvds lose the surround sound
if you are playing older or burnt dvds then chances are they were recorded using only 2 channel or stereo instead of 5.1,6.1 or 7.1 hope this is your solution
Aug 05, 2009 | Panasonic Home Theater Systems
Black and white picture for DVDs not tv
Make sure you don't have a componet plug in a A\V hole or the other way around.
Mar 15, 2009 | Bose Lifestyle 18 System
Newer DVDs won't play properly
you need to buy a cheap av moulator (about 20.00 at most stores) this will solve the problem radio shack has them and so does wall=mart
Jan 13, 2008 | Panasonic Home Theater System System
Not playing voice but playing music/surround
sounds like you may have a dodgy scart lead.check that none of the pins are loose/damaged. Also check the sound settings on the tv, it may have reset itself to the default sound setting. Or it might just be the audio settings on your dvd player have been adjusted,almost all dvd movies have there own audio adjustments.
Jan 13, 2008 | Home Theater Systems
DVDs with pictures refuse to play. Get 'format unsupported'
the 321 does not support data cds or dvds read the manual. standard DVD or VCD format only.
Nov 23, 2007 | Bose 3 2 1 GSX System
Unable to read/play DVDs
You may have a dirty laser lens on the slider assembly. If you clean this little lens, and the problem still happens, it is an indication that the laser is getting weak and it may be time to start looking around for a new player/recorder. Good Luck
Jul 14, 2007 | Samsung HT-DS610 System
DVDs only play in shades of red
Buy one for 35.00 they all do the same thing, show and play a movie.
Sep 24, 2006 | Philips HTS3410D/37 700W DVD Home Theater...
GoVideo HT2030 System Logo
172 people viewed this question
Top GoVideo Home Theater Systems Experts
Gyula Lacz
Are you a GoVideo Home Theater System Expert? Answer questions, earn points and help others
