Question about Vizio L32 32 in. LCD HDTV
Vizio 32 inch now shows mostly only green and red colors
Recently turned on our 18 month old Vizio 32" LCD TV and the predominant colours are now green and red, some tans I guess and blue is gone completely. Of course the manufacturer/Costco warranty is gone now but does anyone know if this is a $200 or less fix our should we just remove and replace this unit?
Thanks!
  • 2 more comments
  • mnky93 Nov 30, 2008
    That didn't do it but thanks for the effort!
  • mikeced Dec 26, 2008
    My Viz went "pop" one day and now shows mostly red and green on the Analog HD input. TV through the HDMI input looks fine, but xbox through the red green blue inputs look bad.
  • fran1479 Feb 05, 2009
    My TV also shows mostly green. When I play Matrix 1 (DVD), there is a scene that is supposed to be pure white background. But it looks so green instead. FYI, mine is about 2 year old.
  • normacastle Feb 09, 2009
    on the dark colors and red it shows a neon green. Also eyes and teeth and around the outside edge. Have done the reset all setting. Have tried vizio tech support and they had me email them pictures of the screen. They still have not emailed back.
  • 395 Answers
Please try to reset all setting and then to see if the problem is solved. 1. Press the Menu on your Remote Control;
2. choose Set up on the OSD;
3. then choose Reset All settings;
4. Press the Exit on your Remote Control to remove the OSD
Posted on Nov 30, 2008
VIZIO Tv E422VA picture showing red or green color on dark areas of screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 29, 2015 | Vizio E422VA 42-inch Widescreen LCD TV -...
The colors are going out in Vizio E320VL. Can I fix this by replacing the main board or is there another solution?
Sounds like a faulty Timing Control board, I had the same problem except yellows showed up green.
Apr 03, 2013 | Vizio E320VL 32 in. HD Ready LCD TV
Hey there, I have a 6 month old vizio 32" LCD 60hz
LCD inverter module may have encountered a failure. Most common is an electrolytic capacitor failing in the power supply. Examine the board to see if any of the caps have a bloated or raised top, they should not be swollen or leaky. If so find the replacement capacitor # on line and replace. You will require a modicum of soldering skills. You indicate the tv is 6 months old.
Return it for warranty service, do not open your tv or you will void your consumer warranty.
Mar 26, 2011 | Vizio L32 32 in. LCD HDTV
HDTV LCD 32 inch is all green. Good definition but all green. Have tried all color adjustments but even turning down the green all the way still leaves a green screen with some red and blue colors in the...
THe most likely cause for this problem is bad connection of the cable connecting the main TV board with the LCD controller. It's called LVDS cable and is hard to miss, usually fat round and black, connecting a board from the chasis with a little board in the top center of the LCD assembly.
I'd open the TV and gently try and reattach the cable to see if that yields any results. You can try it a few times, in fact I'd do it while the TV is open and working so I can better see if adjusting it makes a difference.
There's also a chance that the LCD logic itself got burned and misses on one of the colors. But I don't remember ever seeing that.
Nov 02, 2009 | Vizio VW32L 32 in. LCD HDTV
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
Right half of the screen mostly green and red with vertical strip
It sound like there is a problem with the mainboard. What is the model number of the TV?
Feb 05, 2009 | Vizio GV42L 42 in. LCD Television
Wavy red lines or red pixelation, not sure what it is
Go to Vizio website and buy the extending warranty, you need to have your TV replaced since the problem is with the screen itself.
Dec 15, 2008 | Vizio L32 32 in. LCD HDTV
Vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Apr 22, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
626 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
