Question about Bose 901 VI Main / Stereo Speaker
How do I connect my bose 901 active equalizer to a onkyo tx-sr506
Please assist! I can not find a way to connect my equalizer to my new onkyo TX-SR506 receiver.
  • Audio1964 Apr 20, 2009
    I have the same issue. Could you be more explicit on the solution ?I have a Denon 3801 and Bose 901 and wat to use the 901 as front speakers. My A/V receivers indeed as Pre-outs and Ext In for all 7.1 channesl.
    Thanks in advance
    Brigadier General:
  • 8,546 Answers
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Write off the Tape Out as an input if you use it to extract the Front L&R channels. DO NOT monitor it or you'll chop the 901's out of the signal path AND kill any digital source audio in the receiver.
Posted on Nov 30, 2009
    Problem Solver:
  • 9 Answers
AV receivers are notoriously incompatable for Bose 901s. The problem is the EQ charges the entire system and could damage the surround processor. Some higher end AV receivers, including some of the newer Onkyo models have pre out power in inputs on main or all seven channels.which you could install your EQ directly between pre amp & power amp without damaging processor. You can also add a two-channel amplifier to the pre out jacks front channels and use your recever's remote to control volume.
Posted on Jan 07, 2009
Code for onkyo tx-sr506
Hi Sebastian, not sure what you are looking for please email me at askOnkyo@us.onkyo.com so that I can be of better assistance, JT
Dec 18, 2015 | Onkyo Audio Players & Recorders
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Feb 06, 2013 | Onkyo TX-SR506 Receiver
Need code for dish network remote control for onkyotx- sr 506
HeyRodney_tu176, my name is Mike Houston of DISH Network and I was going over yourpost and wanted to give you the codes for your Onkyo TX-SR506 7.1 Receiver. The Codes willbe; 660, 642, 662 and 678. I will send a link to help with these steps, http://www.dishnetwork.com/SupportSection/remote-setup.
Apr 11, 2011 | Onkyo TX-SR506 Receiver
I have an onkyo tx-sr506 and the system shuts off as I turn up the volume. It doesn't get very loud (barely audible) before shutting off.
Check speakers for distorted or dead drivers . Disconnect and repair. receiver will blown if not disconnected.
Mar 15, 2010 | Onkyo TX-SR506 Receiver
What is the remote control code to control the TX-SR506 from an ATT Uverse remote
hi i have here a couple of codes for Onkyo you could try them 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140, 2006, 2219, 2220, 2318, 2410
hope this help! goodluck!
Nov 24, 2009 | Onkyo TX-SR506 Receiver
I have a onkyo tx-sr506 receiver that turns it self off
This unit is in protect mode. This means that a problem was detected and the unit has shutdown to prevent further damage. The most common cause of this is failed output transistors. Plan on $20-$40 for parts for this repair.
Dan
Nov 04, 2009 | Onkyo TX-SR506 Receiver
Bose 901
1-record out from receiver to to equalizer in.
2-equalizer out to tape pb in receiver.
Nov 05, 2008 | Bose 901 EQ1915 Home Equalizer
Onkyo tx sr 705 & bose 901
No. Active Equalization is required for the 901's and not to be used with any non-901 speakers.
Sep 13, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
2,463 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
