Question about Toshiba Satellite A105 Notebook
98 kia sephia
My car wont start the battery is fine it sounds like something is spinning not engaging like it used to could it be my timing skipped or my belt broke?
  • claytonjburg Dec 03, 2008
    it was the timing
  • Mike Butler
    Mike Butler May 11, 2010
    Anythings possible I guess, but when you say something sounds like its spinning, I need to know 2 things. Does it sound like it coming from top of engine area, or down lower to you, and front of engine or back of engine? 2nd Q- Is the engine turning over as in fan turning, belts turning etc.
    Problem Solver:
  • 17 Answers
Send it back to toshiba.
Posted on Dec 02, 2008
Tns relay is making nosie on my 98 kia sephia
Check and replace if it is not working properly all mechanical relays will make noise when they click once to engage current to the load side of the circuit.
Oct 19, 2014 | 1998 Kia Sephia
99 kia sephia wont start
This sounds like an ignition switch issue. It is located on the opposite side of the ignition lock cylinder (the part you put the key into) and can be purchased for about $20-30. If you are handy with a volt/ohm meter, I can give you directions on how to test the 'start' wire to see if it is getting power before you buy a replacement switch.
Jan 28, 2014 | 1999 Kia Sephia
1999 Kia Sephia doesnt start every time??
It sounds like you may have a sticking electric fuel pump. Next time this happens have a spray can of starting fluid in the car and spray it into the intake air hose of the engine, if it starts you have a fuel pump problem or loss of power to the pump from a possible bad relay or control.
Sep 17, 2012 | 1999 Kia Sephia
Hi my kia sephia wont start i had the barrtey checked out and it passed. the starter will click but wont tunr over so i would like to know is there somtthing that i could do to know for sure its the...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It could be because your battery quite weak. Try to perform ’jumpstart’. If this method works, the problem is in your battery ( check your battery replacement record). The life time of branded battery in normal use is 2-3 years
Aug 16, 2010 | 2001 Kia Sephia
2001 kia sephia car wont start just a ticking sound what is wrong
The ticking or clicking sound is coming from your Starter Solenoid because it is not getting enough Voltage from the Battery to engage the Starter Drive. It sounds like you have a dead Battery, try recharging your Battery first to see if it holds a full charge or check your Battery with a Volt Meter, when not running it should show at least 11.5-12.5 Volts, which would be enough power to start your car, any lower than that replace the Battery.
Aug 13, 2010 | 2001 Kia Sephia
I have a 99 Kia Sephia and it will not move in any gear the clutch seems to be engaging and disengaging but the transmission will not spin the wheels in any gear
It sounds like a bad clutch. It is the clutch if you can change gears with the clutch out and the engine running.
Jul 12, 2010 | 1999 Kia Sephia
1999 kia sephia cranks over but wont start, sputters like it wants to now and again and in between sputtering it spins fast without that "thump" of compression it normal has. replaced fuel pump and fuel...
check your timing belt put no 1 cylnder at top dead center timing mark at 0 remove your distrebuter cap and see if the rotor is pointing at number 1 spark plug
if not replace that belt (replacement is at 60k I believe) sounds like the fix good luck CJ ps no. one on compression stroke
May 12, 2010 | 1999 Kia Sephia
2000 kia sephia wont hold a charge alternator or battery?
If you have a volt meter turn on the car and read across positive and negative with volt meteryou should get something like 13.8 volts if your getting something like 12.5 alternator is not doing its job. also have battery tested.
Dec 02, 2009 | 2000 Kia Sephia
My 2001 kia sephia wont start all the time. Just
when this happens you need to check somethings at that time to point you in the right direction, fuel press & spark , also you need to have the cam and crank sensors checked the shop should be able to find the resistance values of what they should be and then ohm yours. But the main thing is rule things out and narrow it down.
Jul 19, 2009 | 2000 Kia Sephia
Starter would not turn over the engine tries but abruptly stops
is your battery fully charged?could be your stateror flywheel has broken teeth on it
Apr 12, 2009 | 1998 Kia Sephia
Toshiba Satellite A105 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
