Question about Olevia LT42HVi 42 in. LCD Television
Auto channel search.
I can't get my olivea to run an auto channel search. I get to the last entry and nothing happens.
I was able to switch off the tv from the back and get this to work again, but it looses it's memory after the tv is off for awhile.
Posted on Aug 26, 2012
    Sergeant:
  • 291 Answers
Check the r/c[remote control] for ' fresh ' batterys.
Do you have " air wave " reception? or cable connection?
air wave reception will scan but cable reception can't scan because the channel is 'fixed' at ch.3 or ch.4.
Posted on Nov 30, 2008
Auto Channel Search, how do you accomplish this.
Use your Insignia remote to select the initial set up procedure and run auto channel search.
Mar 03, 2015 | Insignia Solutions NS-24E200NA14 24" LED...
Toshiba Freeview Tv, Model 19A 615 DB. Re-tuning I pressed Menu, Set-up, Restore Defaults, then Yes to delete previous settings, and OK. Absolutely nothing happens, Help please?
hi,
To Re- tune your TV you have to go to the Auto tuning option in the menu. do the following procedure for auto scan all the available channels.
To tune the free view analogue channels do the following procedure.
1. Press the Menu/setup button on the remote.
2. Select Auto tuning and press enter.
3.Select the country and press enter.
4. Select start and press enter.
The automatic tuning will search for available broadcasts and should store the channels in the correct order. During the search the sound is muted. When all programs have been stored, the normal TV screen will appear.
If you can sent your email address through fixya then i will sent the user manual for Toshiba 19A 615 DB.
ok
Sep 07, 2011 | Televison & Video
I have a 226-s11... When POWER IT on the power
this is my problem too. i was searching for an answer and i tripped across your entry. it happened this week. funny how two people have the same problem. i hope we bith get a solutution quick
Mar 14, 2010 | Televison & Video
How can I get rid of The Weather Channel and Ebay Countdown when I open my Window?
Weather Channel and Ebay Countdown are usually on the startup..If you pertaining when you log on to windows then Weather Channel and Ebay Countdown pops up I have the solution for your problem..
You can edit the start up by clicking on start then run, then type msconfig..System Configuration utility will pops up..Search the entries responsible for the Weather Channel and Ebay Countdown..Uncheck those two entries and click on apply then restart the computer..
Another way is by deleting the start up entries of the two items.. Click on start, then click on run, then type regedit.. Registry editor will appear after doin so..Expand computer then 5 hives will appear..expand HKEY Local Machine look for Software..Expand Software and look for Microsoft..Expand Microsoft then look for Windows..Expand Windows and look for CurrentVersion..Expand CurrentVersion and look for RUN..Highlight RUN and check the entries on the left pane..Look for the entries of weather channel and ebay countdown..delete the two and restart pc..
Feb 01, 2010 | Microsoft Windows Vista Home Premium...
No digital channels after running auto search
Same thing with my vizio vx37l tv. Did you fix the problem bpakja? If so please let me know how.
Sep 30, 2009 | Vizio VX37L Television
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
Channels won't change on tv with remote or manually
hi,you need to auto search first your your t.v set if nothing happen possible defect is the tuner.
Aug 03, 2009 | JVC LT-32P679 32 in. LCD TV
Philips DTR220/05 digital freeview reciever not recieving anymore
If the box is still receiving some channels, then the box is probably not at fault.
If you have done the full "First time Installation" rather than search for new channels, then eithe the aerial, connection or signal is likely to be to blame.
There have been several changes with the Freeview service over the last few months, and there will be more in the run up to analogue switch off.
In some cases, channels have moved, and in other cases the service has been switched off for a short period, low power etc.
Check the aerial on a standard analogue signal, if the quality is poor, then this rules out the box.
Feb 23, 2008 | Televison & Video
'No Signal' on Sony XBR
on the tv remote: press menu, external entry is highlight (yellow) right press on the outer circle then scroll down to video 4 (satellite entry) (it could be on video 3 depending of the satellite assignment entry) when video 4 is highlight (yellow) right press on the outer circle on the screen you will see 1080i if settle on an HD channel hope it will fix your Sony Bravia..
May 30, 2007 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Olevia LT42HVi 42 in. LCD Television Logo
756 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
