Question about Hotpoint FFA60 Bottom Freezer Refrigerator
Thermostat... Hi,Where can i locate and find the Thermostat control?
  • 237 Answers
A couple of good sites for seeing the diagrams, etc. is www.repairclinic.com or www.partselect.com. Just put in your make & model or follow the directions and they should lead you to a diagram of where the parts are located in the units.
Posted on Jan 22, 2007
Are there two thermostats for a 2012 Chrysler 200 with a 2 .4ltr engine and where are they located
There are two separate thermostats in your application, a primary and a secondary. The primary and secondary thermostats have different temperature profiles in terms of their opening temperature because they are located on different areas of the engine. The primary thermostat is located on the front of the water plenum in the thermostat housing/coolant inlet. The secondary thermostat is located in the cylinder head under the water plenum. The adapter that you are referring to does exist and I believe it is associated with the secondary thermostat.Here is a link to the first one. https://www.autozone.com/cooling-heating-and-climate-control/thermostat/duralast-thermostat/335455_381037_13514_93207 Here's the second thermostat. https://www.autozone.com/cooling-heating-and-climate-control/thermostat/duralast-thermostat/335477_381036_1620_93207
Nov 23, 2017 | Chrysler Cars & Trucks
F25 error code
The "F25" error code means the control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box.
- The hi-limit thermostat kit Part number: AP3094323
Read more: http://forum.appliancepartspros.com/dryer-repair/54078-whirpool-duet-dryer-error-code-f25.html#ixzz2n2Rmgm7a
Dec 10, 2013 | Whirlpool WED9400S Electric Dryer
Where is the thermostat located on a rheem fury 81v52s ?
Hi, The thermostat on most hot water heaters is part of the gas control unit.
if you disconnect the wiring on an electric unit or the piping on a gas unit the whole controller should screw out. Make sure that the electrical power is off, gas **** is closed and water tank is empty.
Hope this helps.
Rob
Oct 07, 2011 | Rheem Water Heaters
Your engine must be cold before removing the thermostat.
Find the location of your thermostat by following the rubber hose located on bottom of your radiator (passenger side) to the point where it attaches to the engine. Remove the two bolts at that location and you'll find your thermostat nestled in there.
Be sure to place a pail under the car to contain the coolant.
Thermostat Operation:
00047_thermostat.jpgThe automotive thermostat is a temperature controlled on and off valve. When the temperature rises to a predetermined temperature, the thermostat opens up to allow the engine coolant to flow through the cylinder block and the radiator. This flow is crucial to maintain optimum operating temperature for fuel efficiency, enhanced driveability, and engine protection. The coolant flow is reduced when the engine is cold, and the flow is increased when the engine is hot. Contrary to popular opinion, operating the vehicle without the thermostat doesn't make the engine run cooler. It will actually run hotter because there isn't a thermostat to slow the coolant flow. This means the coolant doesn't stay in the radiator long enough to dissipate its heat.
All the best
Ben
May 24, 2011 | 1993 Cadillac DeVille
Frig stops cooling. freezer on bottom. frig is running just not cooling. made in 2008. we clean it let it set for 24 hr it cools again. is there a defrost heater that we can turn on, to solve this problem.
Hi, this model i believe has a calrod heater, and those usually dont go bad very often, its more than likely a bad defrost thermostat or control board, the thermostat is located in the freezer behind the back panel on the evaporator, the control board if it has one is going to be up in the control panel by the the thermostat, if it doesnt have a control board it will have a timer, I would change the timer and the thermostat in that case. It is also possible you have a bad heater which is also located in the freezer behind the back panel, under the evaporator, If you know how to use a meter you check this heater with an ohm meter. Let me know if you need further assistance.
Sean
Mar 26, 2011 | Whirlpool Refrigerators
Car not heating changed thermostat flushed and no heat ??
Hi, You could have a bad temperature sensor or sending unit. I would lean more towards the sensor. The sensor controls when the thermostat opens and closes by reading the temp of the engine. The sensor is located somewhere around your thermostat or thermo housing.
Jan 25, 2011 | 2002 Ford Taurus
Refrigerator is freezing food . temp set 40 model:rb195bssw samsung
Hi, this problem is going to be with the running thermostat2.gif. (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 18, 2009 | Samsung 18.8 Cu. Ft. Bottom-Mount...
My side by side refrig. keeps freezing everything. It is turned lowest setting. Model GLRS2677AW6
Hi, this problem is going to be with the running thermostat2.gif (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge2.gif to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 09, 2009 | Frigidaire Refrigerators
The fridge is frozen - the temperature guage says 6 degress celsius but everything in the fridge is frozen solid!!
Hi, this problem is going to be with the running thermostat (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Sep 30, 2009 | Refrigerators
My fridge is freezing my fresh food what do i do????
Sep 28, 2009 | GE Refrigerators
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
123 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
