Question about Onkyo TX-SR605 Receiver
We cannot get a disc out of a DVD player Onkyo CP702?
Played movie and it will not exit.
  • Anonymous Jan 03, 2009
    I have two disks in a dvd player. How do I get them to come out?
    Problem Solver:
  • 6 Answers
What is the model number of your DVD player?
Posted on Dec 01, 2008
Have lost the remote control to onkyo dv cp702. Would like to access the random option.
You can get a substitute remote (the original remote is no longer available) at
http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13118717212490&smodel=DVCP702&brand_pn=ONKYO_DVCP702
Let me know if you have any other problems or questions.Please rate this solution. Thanks.
Jul 28, 2011 | Onkyo DV-CP702 DVD Player
Displaying an error message "mecha
http://www.fixya.com/support/t4093524-onkyo_dvd_changer_display_reads_mecha
http://www.fixya.com/support/t1119443-onkyo_dv0_cp702_error_mecha_err
These may help you.
May 07, 2011 | Onkyo DV-CP702 DVD Player
My onkyo dvd player is reading mechna err
This is usually caused by a broken tooth on one of the cam gears. While relatively inexpensive for the parts, the unit must be rebuilt in the correct order and alignment. This is not a DIY repair. It is possible that the unit is just confused and out of timing. Try unplugging it for 5-10 minutes. Plug it back in and see if it resets. While I doubt it will, it is worth a try. If not, then the unit should be serviced. Figure on $60-$75 for the repair.
Dan
Apr 16, 2010 | Onkyo DV-CP702 DVD Player
CANT GET COLOR ON ONKYO DVD PLAYER
set the video output on the dvd player to component and try this. if your using s-vid, one of the pins might be broken, check this also...lmk
Jun 19, 2009 | Onkyo DV-C601 Multi-disc DVD Player
I have an Onkyo DV-CP702 and it keeps saying I have a mechanical error. I thought a disc was stuck, so I followed your tips and took off the top and indeed, there were 2 discs stuck. I took them out, but...
The loading mechanism is out of timing and needs to be rebuilt. This is a fairly strightforward procedure if you have the manual as there is a sequence and alignment procedure for this. No parts are required in most cases. This unit should go to a service station. If you attempt this and are not aligned correctly, it is possible to damage the optics assembly.
Dan
Jul 02, 2008 | Onkyo Televison & Video
Plays MP3 files at high speed
Try newest firmware. It should work for all Onkyo DVD-players:
http://gamerlamers.com/Onkyo_DV-SP1000_firmware_update/
Regards
Svein
Oct 31, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
DVDs presumed stuck and the player won't eject
Hi, If you feel comfortable opening the unit, then you may remove the top cover normally held by 2 - 4 screws. The tray should be visible and most units have a locking bar right at the center to hold the discs down. Removing this (2 screws normally, 1 at each end of the bar) would expose fully the tray with the 2 discs on top. Remove the discs and put the locking bar back with the screws. You can test the unit without the top cover. Please be reminded about safety precaution when working with active/live units and laser equipment. Power it up and check if the "mech err" still shows. If not you're set to cover it up, otherwise, your probably better off seeking the services of a qualified technician. This is a generic method which normally should apply to most CD/DVD units. Good luck and kind regards.
Aug 19, 2007 | Onkyo DV-CP702 DVD Player
Onkyo DV-CP702 will not load any disks!
Look at page 46 of the manual for reset or initialzation.
Nov 17, 2006 | Onkyo DV-CP702 DVD Player
Onkyo TX-SR605 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
