Question about Onkyo TX-SR605 Receiver
We have a DVD disc that has disappeared in the player, how can we get it out?
    Problem Solver:
  • 6 Answers
You can try to reset the unit or power cycle it. What is the model number of your unit?
Posted on Dec 01, 2008
On the DVD player it is in the "progressive scan
Hi -
. Remove any disc from the unit and close the disc tray.
2. Wait for the "DISC message to appear on the display
3. Hold the "STOP" button on the front of the player for at least 5 seconds then release.
The video output should return to the normal setting and PSCAN should disappear from the display on the front of the player.
If you are still unable to switch P/SCAN off, please post back for further assistance.
Regards,
BElectric
Mar 29, 2011 | Zenith XBV443 DVD Player/VCR
No disc error even with DVD inside the player
I am sure that you have tried using another DVD.
Try putting a Music CD and see if it can read it.
In any case, even if the CD works, it looks that you have a faulty unit the laser on the drive is probably bad now but just in case it is just dirty, try to clean it with a Cleaning Disk and see if the problem disappear.
Dec 23, 2009 | Kaser Corporation Mambo BW MP3 Player
Samsung dvd-85k unlock code
Samsung DVD-V8500K
1. The player should be powered on, the tray closed without any disc inside, the logo "DVD Video Samsung" visble on screen and the message No Disc must have already appeared.
2. Press the "Subtitle" key on the remote - "No Disc" should disappear.
3. Using the remote control, key in the code
"5, 3, 8, 1, 4"
4. A number should appear - this is the player's region number that was last programmed.
5. Press the number of the region you require, or 9 for region-free.
6. Press the "Subtitle" key on the remote - region number should disappear.
7. Press Standby on the remote control.
NOTE:
Origin of this player is Region 5 so it`s a default setting
If code "5, 3, 8, 1, 4" doesnt work try this codes:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
please rate me. its most helpful
Nov 07, 2009 | Samsung DVD-V85K DVD Player / VCR Combo
I want the code to play Zone 2 DVDs on my DVD which is set for 4
1) Turn on the player with no disc in the tray
2) Press the Open/Close button to open the tray
3) Press the info button, the firmware version shows up (
4) After the version info disappears, close the tray again by pressing the Open/Close button
5) At this point, it will show "no disc" at the top. Press the Info button again, and this will disappear. If the "no disc" does not disappear then try again by using the REPEAT button
6) Now type the code that applies for your region (R2 is 57538). A '2' will briefly show up at the top left corner
7) Now press 9, and 9 will show up in the top left corner
8) Power off the player, and turn it on again. You'll have a multi region player
I've found the following codes at the 1080P7 hack:
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
This worked on my dvd1080p9 R2 DVD player
Oct 17, 2009 | Samsung DVD-1080P9 DVD Player
How to change region codes from only 4 to 2 & 4
3) Press the info button, the firmware version shows up (mine was 080220.13.B.1080PXKEG)
6) Now type the code that applies for your region (R4 is 76884). A '4' will briefly show up at the top left corner
Enjoy
Apr 18, 2009 | Samsung DVD-1080P8/XEU DVD Player
DVD disappeared in DVD Player after viewing movie
Get the dummy cd disc, put a blue tac on it. Insert it. Then after few seconds, eject it. Your dvd disc should stick with it when they came out. It worked for me and hope it will work for you.
Jan 31, 2009 | Kenwood DV-505 Multi-disc DVD Player
DVD powers up, reads disc, stops, then question mark shows in top right cornor.
The way i fix this, and mine does it quite often, is to either unplug it from the wall outlet and let it stand or a minute or two, or with the unit off, open the tray and close it, and it will recognise the disc then.
Aug 10, 2008 | Cyberhome CH-DVD 300 DVD Player
Region code
Turn the player on and make sure that there is "no disc"
1. Press "SETUP" on your remote
2. Press "3141590" there 0 is region 0 (region free)
Menu disappear and your player is now region free.
This should work.
Jul 20, 2008 | Harman Kardon DVD Player DVD-27
DVD player will not read any disc
The motor is on its way out - the H02 code indicates motor failure as in it cannot spin the disc. You can sometimes fix it but for how long is anyone's guess. Disconnect from the power, remove the three rear screws and two screws on each side (total 7) and lift off the outer cover. Now if you carefully reconnect the power BE VER YCAREFULLY NOT TO TOUCH ANY PARTS INSIDE THE CASE and put a DVD disc in as per normal, you'll will see that when the tray closes, the upper platen (a honeycomb disc) that sandwiches the DVD to the lower platen does not spin - it should. Give a gentle spin clockwise and it should spin up and the DVD will play. You may need to restart if you missed your chance first time. If you switch off and on, eject and close the tray, the spin should happen as normal. If it doesn't, your motor is knacked and not an economical repair. Buy a new player. If it spins time and time again, you may well have temporarily fixed it for a while.
Jun 17, 2008 | Panasonic DVD-RV31 DVD Player
DVD player not recognizing disc
i have the same problem, i cleaned the laser lens with camera lens cleaner and it made it much better, not perfect, but, better.
Apr 16, 2008 | Televison & Video
Onkyo TX-SR605 Receiver Logo
20 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
