My ford ranger doesn't drive when you put into drive nor reverse if you put it into reverse in order to put it into drive or reverse you have to put the gear inbetween Park and reverse and neutral and drive almost like everything is shifted over. IT still works and drives like put i have a fear more problem will arise been driving around with it like this for a half a year but only 1 mile too and from work.
As you are shifting you feel the lever snap into gear wich that is where that gear actualy is but you are seeing the indicator on the column is not on the chosen gear that means the indicator on the column needs some adjustment to match the indicator with the lever position
Try adjusting your throttle linkage
