Question about Maytag Dryers
Smoked timer The timer woulld not shut off the machine so I replaced it. Problem solved for 9 months. Now this timer won't shut off the machine. Is there something with the machine that is making to timer break? Is there a better timer I can buy, that last more than 9 months? Did I just get unluckey twice with timers? Thanks for your help.
  • Maytag Master
  • 3,463 Answers
Probably just unlucky, however check the connections to the timer, as a bad connection will eventually cause problems,
If in doubt remake the connection.
Good luck.
Please leave feedback.
Thanks.,
Posted on Nov 30, 2008
My mtd yard machine (leaf blower) started billowing white smoke. I shut it off and now it won't start again.
First check the oil level. If its overfilled correct it. Then remove the spark plug and turn the engine over. Replace the spark plug.
Start the engine. Use a prime ( squirt carb cleaner into carb) if you need to. It may start smoking again. Thats OK as long as you know there is oil in it and you dont hear any strange noises. Let the unit run for about 5-10 minutes and see if the smoke clears up. Once it quits smoking stop it and check the oil.
Nov 11, 2012 | Garden
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
At first my maytag rsd2400 refrigerator would not defrost. i replaced defrost heater. all was fine. now four months later it wont defrost again. i have tried to trouble shoot the three most common...
timer pt # 68233-2 tell it when to defrost and the terminator lets it defrost and the heaters do the defrost . so I would repl the defrost thermo next and then the timer in that order . hope this hepled mm
Oct 15, 2010 | Refrigerators
Ge wwsr3090t2ww wont agitateor spin
This is a pop off type. and The timer seems to have gone bad as long as the motor is turning and the belt is not stretched.
Feb 10, 2009 | GE WDSR2080D Top Load Washer
Wont agitateor spin
Yes, to remove the agitator part you just pull on it, it is just the pop off type. Sounds like it might be the timer also, but make sure that the belt is also the right tension
GE WASHER, REPLACED TIMER THEN BIG SMOKE
Be sure you are using the EXACT replacement part. The wiring may be different if it is a "close" match.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 20, 2009 | Washing Machines
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Indesit washing machine wi101
I have the same issue, have just returned from a 9 month break and now the washer does the click thing, but if you open and close the door a few times and set to program 4 is seems to work after about 10 minutes! It was perfect when I left, not 18 months old either. Can see it being the timer either, maybe a pickup of some type not detecting a level? Peter
Feb 08, 2007 | Indesit WA 115 Front Load Washer
Dryers Logo
48 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
