Question about GE WWRE5240D Top Load Washer
Washing machine My washing machine is leaking transmission fluid on the floor. Can it be fixed? The unit 13 years old, or should it be replaced?
    President:
  • 878 Answers
Deatsy, my advice would to buy a new washer. These GE's transmissions are not fun to replace. Taking the age in consideration the job could be compounded by rusting or corroded parts. Get a Whirlpool or Kenmore direct drive and it should give you years of service at a reasonable price. Information on the price of the transmission can be found here: http://www.repairclinic.com/0080.asp Catriver, post back.
Posted on Jan 22, 2007
SOURCE:
I have own my washing machine for 13 months , and it dos not work any longer , it's leaking oil . What should I do?
If it is fairly new ,you fix the oil seal in the gear box
If it is 15 years old ,get a new machine
Jun 30, 2011 | Roper Washing Machines
Grease blobs appear in wash, Maytag washer A211. How do I fix?
Searched for the model on the web and didn't find it. I am assuming that it is an older top load model. Front loaders I don't know about.
Is the grease appearing just in the drum or is there some on the floor underneath. Either way I would say you need to replace the transmission. If you have an old 12-15 yrs washer I would get a new one. The replacement trannys only last a couple of years at best and aren't worth the money to replace $200-300 if your machine is ready to **** out. The only places on a washer that have grease are the clothes you're washing and the transmission. The tranny will mostly leak onto the floor but can sometimes get into the drum.
Dec 30, 2009 | Maytag Washing Machines
Oil leaking on kenmore model 110
This is probably transmission fluid leaking out. You can fix it. Depending on the age of the unit and how much you are willing to spend on a unit that age. Call us for parts. 972-859-0929. We ship next day air and nationwide. Hope this helps you.
Aug 28, 2009 | Kenmore 24032\24036 Top Load Washer
Leaking water - water on floor? new inlet pipe mschine is 13 years old this the first and only problrm encountered
sometimes when you put too much in it, it leaks water. Dry up the water and try with less load
Aug 15, 2009 | Washing Machines
Oil leak in washing machine
Sounds like the transmission is leaking. These transmission don't need to be full of oil to function. But, if it's leaking a lot, like tablespoons, it should be checked. It's not the end of the line. Just may need a service call if it's a plentiful leak.
May 05, 2009 | Washing Machines
Washing machine is leaking from the bottom the washer is a whirlpool model LSR7233D
Check the pump, it's right up in front after you get the cover off. This unit is about 15-18 years old. The pump housing is plastic and eventually begins to leak around the input shaft. They're relatively cheap, about $30, and can give you another couple of years out of the machine if you want to try to fix it.While you're in there you might want to inspect/swap-out the flexible coupling betewen the motor and transmission. That's about $25 and it's pretty easy if you're handy.
Mar 26, 2009 | Whirlpool Washing Machines
Hotpoint washer top loading has oil dripping on the floor
The only place oil can be coming from is the transmission. If left as is, leaking oil will eventually result in full transmission failure. Yes, you can replace the transmission, but the repair is costly and moderately difficult. I'd save the expense and put the money toward a new machine. Please don't bother rating this solution as anything but a FixYa will drop my rating.
Oct 28, 2008 | Hotpoint Washing Machines
My AEG 6200 Digitronic washing machine is leaking from the front door seal down the front and onto the floor. Is this a common problem and can it be fixed? - for example by replacing the opening rubber...
Peace BeeSuit,
Happy to be of assistance,
You asked:
Your, AEG 6200 Digitronic washing machine is leaking from the front door seal down the front and onto the floor.
- for example by replacing the opening rubber seal?
Yes I believe that replacing the rubber seal is usually the answer.
How old is the unit? And is the washer working well other wise?
Is it draining and not smelling like mold in side?
Some times in an old machine the pump does not completely dran out and it could smell like moldy water! Then if it's aged. I would consider not fixing both of these to problems in a washer 10 years or older not to put good money in to bad!
But if the leak is the only problem, go for the seal!
Happy to of assisted and made a different s in your life!
Bless you,
Huuum
Please give me a good rating for my sound advice before you sigan off.
Thank You
huuum
Sep 12, 2008 | AEG Washing Machines
GE WWRE5240D Top Load Washer Logo
105 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
