Computer won't turn on.
It turns on and begins updates then suddenly restarts and goes through updates again. This same cycle continues and continues. Help me hughesy!!!
  • 2,110 Answers
Try boot in safe mode and disbale startup by type msconfig in Run...
Posted on Nov 30, 2008
Machine grinds and grinds but never brews
Want serial number and activation code of mavis beacon deluxe 17
Dec 09, 2013 | Saeco Vienna De Luxe Espresso Machine
When I turn on HP pavilion windows 8 os it says starting automatic repair and then goes to black screen
this is a commom issue with windows 8 on HPs. turn off your automatic updates then contact windows. the updates usually gets to 13% and then freezes.
Jul 27, 2013 | HP Pavilion Computers & Internet
My pc is normaly booting in OS but after a minute it will restart ang never boot boot it again i will turn off my powersupply and then turning on again my pc but the problem goes on again and...
Test your PSU or replace it
One bad lead can cause a computer to continue on a cycle
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Nov 17, 2010 | MSI 845GEM-L (MS-6714-020) Motherboard
Here's something to try, it's actually the drum reset and if it's the drum that needs replacing then this will get you going again. Just remember that if you reset this that eventually the drum will start having quality issues because you will be using it past its end of life cycle getting more use out of it then normal and it won't hurt the machine either... hope this helps and if so, please mark Fixya
1) Turn off the power using the switch on the back of the printer. Open the front door of the printer.
2) Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit.
3) Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
4) Wait till the printer completes the POST process. POST is complete when fan noise and rollers stop. After POST wait for 5 seconds
5) Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter.
6) Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit.
7) Cycle the power of the printer (turn it off and then back on).
Jun 25, 2010 | Dell 1720dn Laser Printer
HP Pavillion dv9000 fatal error
On the windows boot screen you should be getting choices for safe mode, safe mode with networking, etc ...
Select "Disable automatic restart on system failure'
And let me know what error message(s) you have ... write it all down
Jan 14, 2009 | HP Pavilion dv9000z Notebook
My emachine is stuck cycling at start up
no computer is trash when you are dealing with a software issue.
boot up and tap on the f8 key... when you get to that screen... choose safe mode... if it successfully boots.... go to start menu... and restart again... it should boot... if it wants to do the update let it.... if still nothing.... f8 again and choose last known good configuration
Jan 10, 2009 | E-Machines T2742 PC Desktop
Monitor image flashes off and on
Sounds like you've done all the trouble shooting. If you just need that extra nudge, I would agree... it sounds like you'll be needing to shop for a new monitor.
Jun 29, 2008 | Dell E153FP 15" LCD Monitor
Scanner comes on automatically at computer startup
I would suspect that you have something else attached to your computer that is causing the scanner to react.
Disconnect the USB cable from the scanner and restart the computer. After the computer has fully restarted, connect the USB cable to the scanner. The scanner may initialize at this point. If after 30 seconds the scanner continues to cycle as you described, the that is an indication that there is something that is actively pinging the USB ports causing the scanner to react. If the scanner doesn't continue cycling, then reboot the computer and see if it does it again upon bootup.
Assuming that the scanner continues recycling:
Disconnect all USB devices (except the scanner) from the computer and then restart. If the problem goes away, then one of those devices is the culprit. Connect them one at a time, rebooting each time, to determine which devices is causing the problem. Once you determine the cause, then you'll know where to go for help.
Hope this helps.
Jun 11, 2008 | Canon CanoScan 3000F Flatbed Scanner
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
