Hifonics BX1000D Car Audio Amplifier Logo
Andy Jones Posted on Jan 21, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No output I have a hifonics bx1000d. problem is little to zero output at the speakers. the amp is used and the previous owner swears it was working when he shipped it out. he has offered to refund my money but that's not the issue here. the amp will power up and stay powered up, no protect light. just the green power led. the protect does come on for a split second then goes off. the amp does not blow fuses or act strange in any other ways just very little output. I'm running a Kenwood headunit and an audio control eqx for the input. I have tried turining the eqx up till clipping and still nothing. I then tried bypassing the eqx and running the input straight off the sub output rca's from the headunit. still nothing. I then re-installed my old school Orion 2150sx and everything works like it should. one other question on my Orion the bolt thru the board got hot an d melted the nylock nut causing the amp to get really hot and the power trace lifted off the board do you think I can epoxy the trace down? I have put a new bolt thru it and it is working pretty good now for a 14 yr old amp...lol thanks andyj
  • Andy Jones Feb 17, 2007
    found out what's wrong with it.
    first off I sent the amp to a shop. the guy did a burn on it and found nothing wrong I called him and told him the symptoms he did another burn and still found nothing he said it was fine.
    I got it back hooked it up and problem was still there. I checked and rechecked the wiring, voltage on everything was within specs (13.5v)ground was good even checked the impediance on the subs (one of which had a broken lead but didn't cause problem) I went so far as to wire every sub to the amp by itself problem still existed I was ready to send the amp back to the seller when I figured I would have one more look at it.
    I pulled the back cover off and started looking it over even started checking everything I could with the meter. when I suddenly noticed a sheared leg on the inside one of the twin coils it was hard to spot at first because it was still over the soldier spot on the board but I took a test lead you could move it aside and see it had sheared off probably during shipping it was not burned in half it had sheared the box looked like it took a good hit during shipment!!! I pulled the board from the heatsink un soldiered the offending coil cleared the broken leg out of the board and was able to get enough slack on the coil leg to re soldier it to the board put it all back together put it in the truck the next day and violla!!!! it works perfect!!!!!
    thought I would post my find on here just in case someone else has a similar problem....
    thanks guys for your help
Mike Duncan
Level 2:
Novelist:
Champion:
  • Expert 219 Answers
  • Posted on Jan 22, 2007
Mike Duncan
Expert
Level 2:
Novelist:
Champion:
Answers
219
Questions
0
Helped
80411
Points
229
Have you tried turning up the vol/gain control? Are all the switches on the amp set for full spectrum output? Are you sure you are using the RCA input and not the RCA output jacks (if it has such)? Check all the switches to be sure they are in the "most default" position. Something you might try, is to make a jumper wire to temporarily jump from the audio input ground to the power supply (chassis of car) ground. If this makes it work then you have a input ground problem in the amp. Good luck. P.S. As for epoxying the trace down on your other amp. If the foil is still in good condition then it should be ok to epoxy it down. If it needs some "help" then do that first, then epoxy.
My stereo when I turn it up my capacitor starts beeping zero
Capacitors are static semiconductors, they don't beep and they don't display zero.
You're overworking the system or you have bad connections. Contact the maker direct under warranty.
https://www.google.com/search?q=Brutus+Hifonics
I have a hifonics brutus 1700. I burned one of my subs out the other seems to be okay, but now I have no sound. The protect light doesn't come on and it looks all normal. What can the problem be??
Here's a few things you can do to find out what's wrong ,first make sure you have 12volt on your batt lead and your remote turn on and make sure you have good ground.Take an ohm meter or a 9volt battery and put across/momentary the voice coil on your good sub should read somewhere between 2-8 ohms,if using a battery speaker should pop.if ohms check out or speaker pops your good connect it to your amps output.Next make sure you have a signal to the amp,if you have multiple amps use the rca cable from amp that's working for testing purpose.if all that checks out you'll need to have your amp check by professional
If i hook up for 2 ohm do i use one speaker wire off amp bridged
Just use both speaker outputs, no need to bridge them,
1helpful
I have 2 12 inch jl audio w7's with a kicker crossover and a powerbass equalizer 5 bands. i wanted to know if add a hifonics brutus 2100 d class amp to my subs at 1 ohm would it over power my subs. please...
Short answer: NOPE!
The Hifonics Brutus 2100 is stated to produce 2100 watts RMS @ 1ohm load. Most amplifier manufacturers overstate their claims. The 2100 watt output is most likely at 14.4 volts and not the 12.6 volts your car will actually be providing the amp.
But, even if the actual output was 2100 watts that would be 1050 watts to each 12w7. The 12w7's are rated at 1000watts RMS and 2000watts peak. As a MECP certified installer, any system I have done using 12w7's have had a MINIMUM of 1000 watts being provided to each speaker. My personal preference is to run 1500 watts each and keep the gains adjusted lower on the amp. Thus allowing the amp to run cooler and allow the additional headroom for those "show-off" moments!
No sound from subwoofer Solo Baric L7
check the resistance of the sub with a digital multi meter, make sure you dissconect the sub from everything before you check the resistance, if your sub is supposed to be 4 ohms than it should be between 3-5 ohms, if it is under 1 that the sub is blown, while the sub is dissconected from the amp, turn the system on, does it still go into protection?
2answers
Hifonics brutus bxi 2008 amp. no power output
MAKE SURE SUBWOOFER OUTPUT ON YOUR RADIO IS ON IF NOT THAT COULD BE BAD INPUTS ON YOUR AMP
XX- ZEUS MONO D- CLASS / 1600 WATTS RMS
It's likely that the amplifier has shorted output transistors. If that's the case, they will have to be replaced. If you have zero experience with electronic repair, you should pay someone to repair it instead of trying to repair it yourself.
Let me know if you have any other questions.
2answers
Hifonics Taurus circuit diagra???
You need to measure the voltages at the output transistors. The previous "driver" stage may have a problem. These outputs use .6V as the bias differential. Check for DC voltage on the inputs to the transistors. These are standard designs. I'd check for DC anywhere along the signal path.
Dan
4answers
No sound in my Hifonics Brutus BXi 1206D amp
Have you confirmed that you have a good signal feeding the amp?
Have you confirmed that the speakers are in good working order and don't have any breaks in the wiring?
Problem with hifonics 1505 class d mono
The positives are connected together and the negatives are connected together. The two pairs of terminals are for convenience. You'd connect one speaker to a pair of positive/negative terminals and you'd connect the other speaker to the remaining pair of positive/negative terminals.
You need to confirm that you have a good signal feeding the amp. If you have another amp in the vehicle, swap the RCA cables between the amps to see if it makes a difference.
You also need to confirm that the speaker are working properly and that there are no broken connections in the wires. If you disconnect the speaker wires from the amp and touch the wires across a D-cell battery (for a fraction of a second), the speaker should pop. if it doesn't, check the wiring to determine why.
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ADMIN Andrew
ADMIN Andrew
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
