Question about Maytag MMV5207A Microwave Oven
The entire door handle snapped off
While preparing to open the microwave door, the entire handle just broke off.
  • charlesberkl Nov 30, 2008
    The only thing broken is the plastic door handle at the point where it attaches to the door itself. The door does not appear to be damaged at all except for the loss of its handle. Is there a way to replace the handle without replacing the whole door?
I have the same problem- funny when we built we went all Maytag and got a bunch of lousy handles- the stove, micro, fridge, and freezer... I glued the pieces of the handle together and used plumber's putty to fix it. It's MightyPutty, but without the repackaging and cost. Just knead the putty until mixed, fill the cavity of the handle and press on the door where it was... No problem after six months so far.
Posted on Mar 30, 2009
    Sergeant:
    Champion:
  • 338 Answers
If the plastic on the door is broken or cracked then the whole dooe will need to be replaced. most mws you can take the vent grille off open the door all the way then lift and remove the door.
Posted on Nov 30, 2008
  • Robert Artiaco Dec 01, 2008
    yes the door comes apart. Do you have the model number?
The plastic door handle on our GE Spacemaker XL microwave oven (JVM1341WW 002) broke. I ordered and now have replacement handle and screws onhand. How do I gain access to inside of the door to replace...
I do not know your unit specifically but a lot of them you have to start by, slowly, from the inside of the door, lifting up on the choke that runs along the outer inside edge of the door. It looks like a plastic trim part about 3/4 of an inch wide. You slowly work around the whole door unit you get it popped out. a butter knife or steak knife works pretty well . I just use a small flat head screw driver The screws for the handle are behind that choke seal. Usually 2 Phillips head screws. The choke part just snaps in place and has no screws to put it back, just push back in place and you will hear it snap as you go. Be careful the plastic tabs are easy to break off
Aug 19, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Door handle broke off
bru the front internal cover snaps off. you need to stick a screw driver in the edges and pry it apart being very careful to not snap it or bend the outta metal frame undo the handles screws and replace as before but in reverse
good luck
Jul 12, 2010 | Hotpoint RVM1435 Microwave Oven
The door handle broke off my GE microwave
Actually the door handle CAN be replaced at a cost much less than pruchasing an entire new microwave oven. And, YOU can repair this yourself and save the cost of a service call. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
If the model number is correct, the part number is WB15X322. The cost is about $40. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you
Dec 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The door handle on my GE Spacemaker XL model JVM1330BW 003 broke off so I decided to replace the entire oven. Can you recommend a replacement that will fit into the same recess and have the exhaust vent...
If the outer door is not broken. All you have to do is replace the handle. You will need to access the door handle mounting screws and remove them to replace the door handle. To access the screws on MOST microwave ovens, you must remove the inner door panel that goes around the perimeter of the glass. This can be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. The part number for the door handle is WB15X10020. If the outer panel is damaged, you may have to replace the entire door. The part number is WB55X991. The cheapest web source I have found the handle listed is appliancepartspros.com for $47. The entire door, however, sells for $110 at pcappliancerepair.com.
The RF inside the cavity of a microwave oven is actually controlled by the RF shield in the glass. As long as the glass is intact and the inner door facing is not bowed, warped or cracked, you will not have to worry about RF leakage (even with the handle broken off).
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Nov 03, 2009 | Microwave Ovens
Handle broke off, model # khhs179Lss-4, wna to
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
If you have not purchased a new door handle yet, the part number is 8205431 (White), 8205433 (Black), 8205432 (Biscuit) or 8185456 (Stainless). A new one can be purchased at pcappliancerepair.com for about $40-46. Make sure you order using the correct part number to ensure you get the right color.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a small hinge pin that has to be removed in order to remove the door.
Sep 16, 2009 | Microwave Ovens
The handle broke on my microwave. How do I remove
Aug 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How to fix a broken handle?
This is not difficult. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
NOTE: If your microwave is the same model you have this listed under, I could only find one website that offers the handle as a separate replacement without purchasing the entire door (the entire door cost over $200!). The handle lists for about $51 at repairclinic.com. You can search around, but I have already tried the following sites:
searspartsdirect.com
repairclinic.com
Aug 12, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
Cannot remove handle to replace it.  The handle broke on top.
You must pry out the plastic strip that surrounds the window on the inside of the door to reach the top screw that holds on the handle. Be prepared to spend a pretty penny on the replacement handle as well.
Feb 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can get Samsung parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 18, 2008 | Samsung 1.8 Cu. Ft. Over-the-Range...
Maytag MMV5207A Microwave Oven Logo
313 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
