Question about Apple iPod touch
Itouch stuck on the playlist screen??
When i hit the "home" button on the itouch, a message appears showing the title of the song then close or music? It won't let me go back to the home screen.
  • Anonymous Dec 30, 2008
    i want to play music on my itouch and say i wanted to see my pictures i would have to press the button at the bottom of the itouch so i do and on the screen apears it says a song and close and music so i press close and again press the home button and it apears again and again and i dont know what to do?
  • Anonymous Feb 27, 2009
    it's me again with the same problem believe it or not, this time, I held the home button for as long as I can, and that close/music menu still appears and it won't go away.. help~
  • 395 Answers
Mine does this sometimes also, i'll be in a program and i hit the home button and the music/ close menu will pop up. i hit close or hold down home and it goes back. there was a new update to the unit so that might fix it also
Posted on Nov 30, 2008
I dont have any songs movies or podcasts but do have 4 and half pages of apps. it says that i have 5.11 gbs already used in the category of other, what is the problem.
You need to connect your touch to your pc open itunes ... click on the icon that is representing your touch on the left hand side of the screen. When this shows up on the main screen look at the tabs at the top the are labeled music movies podcast pictures etc etc ... you need to go into each on and select what you want on your touch.. if you want your complete library of music you would select that and then hit apply at the bottom of the page. The same goes for movies ... etc etc . if you want just certain songs from your library then go to your music make a new playlist from the (i believe) edit tab. Highlight the song you want and then right click select add to playlist. When you have selected the songs you want go back into your itouch ( using the icon on the left hand side of the screen) go the the music tab and select that playlist from the options there and sync....like wise with movies and podcasts. hope this helps
Oct 17, 2009 | Apple iPod touch
Tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 | Computers & Internet
How do I erase a song on an iTouch?
you can only erase or save tracks in itouch through itunes
Dont forget to rate
Sep 07, 2009 | Apple iPod touch
My itouch will not advance songs. I have to
Your music playback settings need to be looked into here. Follow these steps to determine and then get rid of the problem.
1. Open a song for playing. 2. Tap on the album art or the screen.
You should see the progress bar of the song along with 3 tap icons. The one on the left is for song playback. It is either repeat off (arrows are white), repeat all (arrows are blue) and repeat 1 song (arrows are blue and '1' appears on the icon)
3. Tap once to get out of repititive listening of the same song.
Also, I am assuming that you are not listening to a playlist with 1 song in it.
happy listening.
Jul 16, 2009 | Apple iPod touch
Cannont transfer podcasts to itouch from itunes
It could be a bad file. If you're resetting your device, and then adding you music and such back, there may be some bad song, or app that is corrupting your device. On my Mp3 player, it would get stuck on a song that wasn't really there, so I found some corrupt goofy Weird Al song, removed it, and it never happened again.
Jun 18, 2009 | Apple iPod touch
Will not sync
To get songs to sync from itunes,with itunes open and ipod connected click on name of your ipod on left side.When screen comes up showing your ipod click on music at top then put check in box to sync music,choose what to sync,click sync.
Jun 04, 2009 | Apple iPod touch
Music on Itouch shows up in Itunes but Itouch says No content add from Itunes
First you need to restart your itouch.
Then, plug it in to your computer and wait for iTunes to pop up.
Select a few songs from your library or some movies that you have and drag them to your iPod.
What I did was, dragged some movies on my itouch to the tv shows folder as soon as i did this everything popped back on to my screen
Sep 10, 2008 | Apple iPod touch
ITouch will not manually sync to iTunes
Hi Try this to fix the problem: (its from the Itunes help menu)
To add songs to iPod manually: step_1.gif Connect your iPod to your computer.
step_2.gif When the iPod icon appears in the iTunes window (under Devices), select it.
step_3.gif If the Summary pane is not showing, click the Summary tab.
step_4.gif Select "Manually manage music." (If you have an iPod that displays video, the checkbox says "Manually manage music and video.")
step_5.gif Click Music (below Library, on the left side of the iTunes window) and then drag songs and playlists to your iPod.
Jan 21, 2008 | Audio Players & Recorders
Apple iPod touch Logo
57 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
