Cisco router 857
When i hit pause/break button rommon1> doesn't come up, instead i see TB_BB_Package
  • zaki imran May 11, 2010
    press windows + numlock key
techjuli
  • 157 Answers
SOURCE: i have cisco router 857
Hi!
You can access the user manual for your router by going to:  http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/857sg_bk.pdf
But simply put,  - You have to enable the web interface in Hyperterminal/Telnet/Terminal - To connect to your router this way, open your Terminal and type the following commands in order:
1) enable (enter password if necc.) 2.) config term 3.) ip http server (this command might also be set to "no ip http server") 4.) exit
After doing the above: 1.) Press Cntrl+Z 2.) Go to Copy, Run, Start 3.) Open your browser and go to "10.10.10.1"
Good luck! -TJ
Posted on Nov 30, 2008
techjuli
  • 157 Answers
SOURCE: cisco router 857
Hi Anthony-
The default username is "cisco" and the default password is "cisco" as well.
techjuli
  • 157 Answers
SOURCE: cisco 857 router
You might need to reset the password. In order to do this, follow these directions:
  1. Console into the router, then power cycle it. As its rebooting hit the "break | pause" button on your keyboard, and you get to the rommon1> prompt.
  2. Then type rommon1>confreg 2142 rommon2>reset
  3. The router comes back on as if it were new---answer no to the first question, and sometimes it asks a second question (do you want to terminate autoinstall, or something...)---answer yes to the secondquestion if it asks. Then hit enter and you get router> in a few seconds.
  4. Then router>en router#copy start run
create a new account:
  1. router#conf t
  2. router(config)#username bob priv 15 password bob
set register back:
  1. router(config)#confreg 0x2102
  2. router(config)#exit
  3. router#wr
  4. router#reboot
and that should let you login with bob/bob
  • 286 Answers
hey you are saying that you want to configure the router,, but rommon mode is for breaking the password....do u forget the password of the router......can you explain why u need to log in through rommon mode
Posted on Feb 11, 2009
SOURCE: I'm trying to set up
John,
Give this a try. Log into Admin on the DGL-4300. Click the Advanced tab at the top, then the Firewall tab on the left. In the Application Level Gateway (ALG) Configuration section at the bottom, you will see a check-box called IPSec (VPN). If you don't see this check-box, you will need to upgrade the firmware on your DGL-4300. If you have this box, it will almost surely be checked, which is the problem. Un-check it! It will say that it needs to reboot the router. Do it and that should fix your problem -- it did for me. Regards, Joe
Posted on May 26, 2009
Lost my pin
you have to reset the router by holding the reset button for about 30 secs since there is no way to recover the pin.
Oct 23, 2013 | Cisco 857 ADSL SOHO Router (DHCISCO857K9)
I cant connect with the router because i forgot the password
Default admin username, cisco. Default admin password, cisco
Jul 28, 2011 | Cisco (1841) Router (cisco1841)
Iam trying to connect my sony kdl hx 700 to wireless network and my ps3 but my router is a cisco 857 can it be done?
There are 2 models of the Cisco 857 router. You must have the the Cisco 857W in order to support 802.11b/g wireless. The 857 without the "W" will not support it.
Jan 08, 2011 | Cisco 857 Router (CISCO857K9)
How can i config my DSL acount in cisco 857
with a dialer interface:
interface Dialer0
description $FW_OUTSIDE$
ip unnumbered Ethernet0
ip access-group sdm_dialer0_in in
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
ppp authentication chap callin
 ppp chap hostname xxxxxxxxxxxxxxx
 ppp chap password xxxxxxxxxxxxxxxxxxx
Mar 10, 2010 | Cisco 857 Router (CISCO857K9)
Cisco router 857
Nov 30, 2008 | Cisco 857W (882658019555) Router
Cisco 857 router
  1. router#conf t
set register back:
  3. router#wr
  4. router#reboot
Nov 30, 2008 | Computers & Internet
Cisco router 857
Hi Anthony-
I have cisco router 857 and dont know how to configure
Hi!
Good luck! -TJ
Nov 30, 2008 | Cisco 857 Router (CISCO857K9)
Boot Loop
you may have to reload the OS of the router.
i dont suppose you can kick it into romon mode can you? (usually done by hitting the pause break button on boot.)
if you can you should be able to use Xmodem to reload the OS (as long as you have a copy of it located on your computer)
Mar 11, 2008 | Cisco 1603-R Router
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
