Question about Mitsubishi Diamond Plus 73 17" CRT Monitor
Colour problem! My monitor suddenly went an off colour, and the problem still persists. things aren't quite the colour they are meant to be with white being slightly bluey/green, green being yellowy/blue etc! please help!!!! thanks! mangoman! x
0 characters
1 Points
Samsung syncmaster 2433bw , suddenly went out of colour. Tested it with a ps3 but I found a setting that shows me colour .. its the dynamic option under magic colour
Samsung Sync Master 2433BW has the brightness rectangule and monitor menu in one corner of my screen. How I disable/remove that rectangul?
Oct 21, 2010 | Samsung SyncMaster 910MP 19" LCD Monitor
Try getting anything that may have a magnetic field away from the LCD (speakers, phones, any electronic product), does the problem persist?
Jan 08, 2008 | Samsung SyncMaster 245BW Monitor
Only the blue coloured objects are seen perfect while other objects lose the colour. the problem persists for few minutes but then suddenly all colours appear fine .Plz give me a solution.thnx
If all the cables are correctly attached, sounds like your monitor is failing.
I have had a few monitores do this, usually give them a little tap, they come back on for a while, but its usually a sign to be looking for a new monitor, unless its under warantee
Jul 20, 2010 | Samsung Computer Monitors
The color on the monitor suddenly has a blue tint that I am not able to change.
have you removed any of the VGA connectors at all ? - have a look on the plugs for a bent pin - quite a common issue on VGA plugs - that even when bent they will still screw into the socket and depending on which pin you can get a colour shift
Apr 12, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Yellowish colour of the monitor
check the datad cable of monitor, if ok.then soldring may be dry ot the CRT neck
Jul 29, 2009 | Samsung 793S 17" CRT Monitor
My monitor colour has changed to yellowish
The first thing to try is to make sure the video connections both at the monitor and the PC are secure. A number of color image problems are just a loose connection. Make sure you remove the connectors and then reseat them when you do this.
Jul 28, 2009 | Samtron 76df 17" CRT Monitor
24" CRT HP A7217A Monitor stopped working
hello sir your vertical or horizal IC damaged.......... thats why its showing multi colour ...... just do one thing sir.......... fit your new IC
if your problem not solved..... type in comment
Apr 29, 2009 | HP A7217A (White) 24" CRT Monitor
Viewsonic E71f suddenly a change in colour as if a layer formed
there must be a loose contact between tracks of base on crt or may be dry solder remove it problem may be solved
Nov 21, 2008 | ViewSonic E70 17" CRT Monitor
Monitor displays only horizontal line
hey bro.
you try to re solder the vertical section and the color section.
Oct 16, 2007 | SAMTRON 55V 15" CRT Monitor
Monitor problem- colour changes to white appearance to yellow appearance
Mar 18, 2007 | SAMTRON 55V 15" CRT Monitor
Mitsubishi Diamond Plus 73 17" CRT Monitor Logo
20 people viewed this question
Top Mitsubishi Computer Monitors Experts
Matthew Spark
Matthew Spark
Shaukat Bhutto
Level 1 Expert
Are you a Mitsubishi Computer Monitor Expert? Answer questions, earn points and help others
