Question about Coleman Heating & Cooling
Coleman Evcon no fan when in heating mode
I have a Coleman Evcon Model BFU05012AX The cold air mode works fine, But, while in heating mode I get flame only for a few seconds and the main blower does not come on and the flame goes out. It cycles through this three times and then shuts off.
  • gordonmm Nov 30, 2008
    I will try that and post results. Thank you very much
    Matt
    With 4 successful demand tests it worked every time after cleaning the flame proving device. I am sure that it will work tonight when it gets chilly. Thank you for your assistance.
    May God Bless you and your service.
    Matt
  • 306 Answers
Sounds like your flame proving device is not proving the flame. It is located on the last burner looks like a piece of thick wire sitting right beside the last burner. To Save you about 50 bucks service call take some steel wool and very gently clean the carbon that has built up on the surface of the device. Should only take 4 or 5 strokes.
Main blower will delay when in heating mode as to allow the heat chamber to build up enough heat to trigger the fan switch.
Posted on Nov 30, 2008
My Coleman Evcon furnace Model EB 12B will start out blowing warm air and then before it reaches the temp set on thermostat starts blowing cold air. We had the thermostat changed over the summer and the...
look at the furnace and turn it on to see if the flames come on. Watch and see if they stay on for a period of time. If they come on then go out you may have a dirty flame sensor, if it goes out and then relights it may be a high limit switch getting weak. hope this helps.
Oct 25, 2013 | Heating & Cooling
My Coleman Evcon heating and air unit will not blow air
bad blower motor. recommend a new blower motor and capacitor.
May 28, 2010 | Coleman Heating & Cooling
I have a coleman evcon model dgat070bdf furnace. As soon as the furnace fan kicks on the burner shuts off. Any ideas?
Hi check the flame sensor is clean also check out the pressure switch , and check air filter is clean
Feb 05, 2010 | Coleman Propane Forced Air Heater...
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
177 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
