Question about Nikon Cameras
Hi there,can you help me with opening and processing RAW images taken on my D70s. I want to use photoshop to process the images - I have photoshop CS. It will not open my RAW(NEF) files even tough NEF is listed as an option on the "open with menu".so now I have loaded Nikon Picture Project. Picture project is doing some very strange things like opening images that have been deleted from the memory card and only opening one of the recently taken images. I saw in Photoshop Help that you can download plug ins to help with this sort of things but I cant find one and feel bamboozled by the whole thing. Anything of relevance to this problem would be appreciated.
    Problem Solver:
I am waiting for a solution. I have sent payment through paypal so hope it has got through to you OK
Posted on Nov 30, 2008
I bought a cannon camera EOS 70D, when i use PhotoShop Elements 10, i cannot open the image if the image was taken in RAW.
Hi found a manual for PhotoShop Elements 10 here:
http://help.adobe.com/en_US/photoshopelements/using/photoshopelements_10_help.pdf
It is a pdf file which can be saved to disk for future reference and contains (page 53) a paragraph below:
"Prefer Adobe Camera Raw For Supported Raw Files Ensures that all the supported raw files are opened with Adobe
Camera Raw instead of other software. Select this option if you have added other plug-ins to Plug-Ins folder"
It may be that you have to load the relevant plug-in in order to load these files, or load this plug-in before attempting to load the RAW file.
Hope this helps
Nov 17, 2014 | Cannon Cameras
When I try to take photos in RAW with my Digital Rebel, it says that no photos are found when I try to download them. Why?
Dear Ruby,
The answer is simple. Your computer cannot read RAW images straight up. You need an intermediate platform.
I suggest try the Adobe Lightroom. You can find loads of tutorials on youtube.
http://www.digital-photography-school.com/processing-raw-files-in-adobe-lightroom
This link will help you out.
So, solution. Try a intermediate software, like Lightroom, or Photoshop. It'll allow you to process, view, and edit, RAW images. Plus this tool will allow you to make your pictures look magical.
Best of luck.
Regards,
Rebel
Sep 13, 2011 | Canon Rebel XT / EOS 350D Digital Camera
PhotoShop CS3 Droplet automation
Try the following steps
  1. Choose File => Automate => Create Droplet.
  2. Specify where to save the droplet. Click Choose in the Save Droplet In section of the dialog box and navigate to the location.
  3. Select the Action Set, and then designate which action you intend to use within the Set and Action menus. (Select the action in the Actions palette before you open the dialog box to preselect these menus.
  4. Set Play options for the droplet:
    a. Override Action “Open” Commands Open commands in the action refer to the batched files, rather than to the file names specified in the action. Deselect Override Action “Open” Commands if the action was recorded to operate on open files or if the action contains Open commands for specific files that are required by the action.
    b. Include All Subfolders Processes files in subdirectories.
    c. Suppress Color Profile Warnings Turns off display of color profile messages.
    d. Suppress File Open Options Dialogs Hides File Open Options dialog boxes. This is useful when batching actions on camera raw image files. The default or previously specified settings will be used.
  5. Choose a destination for the processed files from the Destination menu:
    a. None Leaves the files open without saving changes (unless the action includes a Save command).
    b. Save And Close Saves the files in their current location, overwriting the original files.
    c. Folder Saves the processed files to another location. Click Choose to specify the destination folder.
    Note: You can record an action that saves using a specified file name and folder. If you do this and deselect Override Action “Save As” Commands, the same file is overwritten each time. If you record your Save As step in the action without specifying a file name, the droplet saves it to the same folder each time but uses the file name of the document being saved.
  6. If the action includes a Save As command, choose Override Action “Save As” Commands to make sure files are saved to the folder you specified (or to their original folder if you chose Save And Close.) To use this option, the action must contain a Save As command, whether or not it specifies a save location or file name; otherwise, no files are saved.
    Some save options are not available in the Batch command (such as JPEG compression or TIFF options). To use these options, record them in the action, then use the Override Action “Save As” Commands option to make sure that your files are saved where you specify in the Batch command.
  7. If you chose Folder as the destination, specify a file-naming convention and select file compatibility options for the processed files:
    a. For File Naming, select elements from the pop‑up menus or enter text into the fields to be combined into the default names for all files. Elements include document name, serial number or letter, file creation date, and file extension. Starting Serial Number specifies the starting number for any serial number fields. Serial letter fields always start with the letter “A” for the first file.
    b. For Compatibility, choose Windows, Mac OS, and UNIX to make file names compatible with Windows, Mac OS, and UNIX operating systems.
  8. Select an option for error processing from the Errors pop‑up menu:
    a. Stop For Errors Suspends the process until you confirm the error message.
    b. Log Errors To File Records each error in a file without stopping the process. If errors are logged to a file, a message appears after processing. To review the error file, open it in a text editor after the Batch command runs.
Give it a try.........
Jul 30, 2009 | Computers & Internet
Camera RAW and PhotoShop CS3
To start, before building an action or a droplet to convert from Raw, you need at least either the RAW plugin, or the photoshop lightroom plugin, depending on the version of Photoshop. I assume you have the plugin installed on your Photoshop. See: Adobe - Adobe Photoshop CS4: Digital camera raw file support.
A better choice would be having the Nikon Capture NX , that give you the option to work on the native RAW format from Nikon.
Once you have installed a plugin to manage RAW format files you can record an action or droplet to automate the process. If youj want more automation, you set an action first, as a batch process to do action on a single file, then build a droplet on the action batch file. A droplet will give more automation, since droplets can be activated by dropping a folder of images onto that specific Droplet Process, and they will apply the batch process to all the files contained in the folder.
The way you build the batch action depends much on the version of Photoshop you are using and on the plugin used. Here an example using Adobe PS CS2 and camera Raw plugin: Raw Format Workflow with Adobe Bridge .
The action can be saved using the recorder, so that the procedure will de quite instinctive. See the tutorials below for step-by-step instructions.
See also:
Adobe - tutorial : Lights, camera, action!
Batch Processing Camera RAW images in Photoshop CS
Creating a Droplet : Adobe Photoshop Tutorial
Jul 28, 2009 | Computers & Internet
Opening RAW images from Nikon D70 on photoshop
A Photoshop Raw file is a Photoshop PSD file without a header. The header
information must be entered when the file is imported into Photoshop. The
raw format is used import and export bitmap data using a very simple,
uncompressed binary format.
Nov 30, 2008 | Nikon D70s Digital Camera
Clarity of Photos
Good results are usually possible with the trusty old D70s.
Obviously, run through your settings and ensure you have everything sorted for max quality: Set quality to Fine, size to large, ISO 200-400 (turn auto ISO to off).
Next check the JPEG processing settings. Make sure the sharpening and/smoothing are set to minimum or low. You could also try shooting on RAW which would help eliminate the JPEG processing settings as the problem. If your RAW files are still ****, your camera may be on the way out. If the RAW;'s are better, your JPEG settings need attention or the processor is having issues.
Assuming your settings are all fine and your lens is of reasonable quality the images should be pretty sharp. But at the end of the day the D70 is getting on a bit and with only 6.1mp zooming in heaps is never going to be pretty.
If the "blobs" of colour and pixelation are severe you may have a sensor or processing issue.
Jul 02, 2008 | Nikon D70s Digital Camera
Software to process RAW images
You could try picasa from google--they have limited RAW support and I think fz50's are on the list...
Jun 03, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Raw photos
Install microsoft XP and photoshop 9
Mar 10, 2008 | Nikon D70s Digital Camera
Does the camera come with software for processing RAW image files?
The Epson R-D1 ships with PhotoRAW processing software for Windows users and RAW Plug-In for Macintosh users. You can also download the latest Camera Raw 2.3 Update for Photoshop CS which provides support for the Epson R-D1.
Sep 13, 2005 | Epson R-D1 Digital Camera
Cameras Logo
119 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
