Question about Garmin GPS
My garmin loses the satellite as soon as I turn on the engine.
  • layzahr Nov 30, 2008
    It just started doing this...I've not added or changed anything to the vehicle. I even went out and purchased a new unit and it still does the same thing. It works fine up until I turn the car on...It does not matter if it is plugged in or not..it still loses satellite the moment i turn on the car.
    Novelist:
  • 157 Answers
I have heard of this before and it is said to be a power surge issue. Unplug the Garmin unit before starting your car's engine. If this does not work, you may have interference from the EMF (Electro-Magnetic Field) produced when you turn on your car. If so, there is not much you can do rather than just wait until it finds the satellites again.
Posted on Nov 30, 2008
Tip
SLOW SATELLITE LOCK GARMIN NUVI GPS'S, ALL MODELS
IF YOUR GARMIN NUVI SERIES GPS IS SLOW TO PICK UP SATELLITE'S THEN THERE ARE TWO VERY EASY THING U CAN DO, 1ST GO TO WWW.MYGARMIN.COM AND REGISTER YOUR GPS WITH GARMIN, U WILL NEED A MINI USB CABLE FOR THIS AND A PC OR LAPTOP WITH INTERNET ACCESS, THEN CHECK FOR SOFTWARE UPDATES, THE ONE THAT HELPS SPEED UP LINK UP TO SATELLITES IS CALLED THE "HOTFIX" SOFTWARE ENHANCEMENT, INSTALL THAT SOFTWARE IF U HAVEN'T ALREADY DONE SO, 2ND THING IS TO LEAVE YOUR GARMIN ON A HOME CHARGER (AVAIL VERY CHEAP ON EBAY), WHEN U PLUG IT IN TO THE CHARGER THE GPS WILL COME ON, AS SOON AS IT DOES SLIDE THE POWER SWITCH TO THE LEFT, THIS WILL GIVE U A MESSAGE THAT "BATTERY IS CHARGING" LEAVE IT IN THE CONFIGURATION WHEN NOT IN USE, U WILL FIND WHEN U NEED TO USE THE GPS THE GPS WILL BE LINKED TO THE SATELLITE AS SOON AS U TURN IT ON, A SIDE BENEFIT OF THIS IS THAT BATTERY LIFE IS EXTENDED.
on Jan 05, 2010 | GPS
My new Garmin Nuvi 1450 lost satellite signal more than 30 times between Topeka Ks and KCI. Is this normal?
I have the same exact problem. Satellite detection outside of vehicle before starting out was full strength, as soon as you get into vehicle strength drops off to practically nothing. Now start driving and it continually loses satellite reception even on the open road with no hills and a clear day. It was mounted as far into the front windshield as I could get it and still crappy reception. Very disappointing as a cheaper Tom Tom my sister has works flawlessly. Also my daughters HTC desire Z cell phone GPS works flawlessly even from the back seats in the van. Maybe 1450LMT is just junk, and I should look for a refund.
Jul 17, 2010 | Garmin nuvi 1450 GPS Receiver
No satellite signal
Some vehicles have a coating in the windshield that can interfere with the GPS unit receiving the satellite signal. It is not the unit's fault. You may need to purchase an external antenna to allow your unit to work inside your vehicle. These are available at www.garmin.com or at your local GPS retailer.
Nov 29, 2009 | Garmin nuvi® 200 Car GPS Receiver
Frequently loses satellites.
I can help you fix the satellite problem with your Garmin Nuvi 265WT.
Poor satellite reception, loosing satellites, and taking a long time to acquire satellites are issues that have been addressed by Nuvi 265WT firmware updates.
There are three steps to take to get your Nuvi 265WT running better than new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265WT Manuals here.
Sep 20, 2009 | Garmin n?vi 265WT Car GPS Receiver
We cannot get our garmin c340 to acquire satellites.
turn it on and use it more ,even if going to grandmoms house ,for some reason they lose satelites when not in use.i found useing it or at least turning it on every day has cured the problem.hope this helps
Dec 28, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin 498 - trouble finding satellites
Push power/menu together or power/page together. the whoole unit will reset. you will lose all saved data but this may help
Nov 07, 2008 | Garmin GPSMAP 498
Garmin Forerunner 305 cannot locate satellites
Hey, I install Garmin GPS Chipset Type G and now it seems work well.
Mar 01, 2008 | Garmin Forerunner 305 GPS Receiver
Aquiring satellites
Are you outside with a clear view of the sky? It should find satellites once the unit is turned on. Does it say "Looking for satellites" or "Acquiring satellites"?
If it is "looking for satellites" then it means that the unit have lost all data (time, date, location). If it is "acquiring satellites" then it have date and time, but not location.
Looking for satellites require a longer setup time (could be as much as 15 minutes). Acquiring satellites is much faster (not more than 2 minutes).
Date and time is updated from satellites once the unit gets a satellite lock.
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
Losing Satellite signal
Latest software is 5.20, GPS sw 3.0
Go to the following link for more info on WAAS
http://www8.garmin.com/aboutGPS/waas.html
WAAS doesn't have anything to do with satellite reception.
Dec 26, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
62 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
