Question about Altec Lansing 221 Computer Speakers
Crackling Sound From Subwoofer
When I play music loud with the bass up high the subwoofer starts to make crackyling/popping type of noise.
  • 537 Answers
Check any wiring coming or going to the subwoofer. It sounds like it could be a loose connection.  Is there a LFE or bass boost knob on your subwoofer? Does turning that up/down cause the crackling (if it exists). If so, you could use some tuner cleaner to clean the contacts on the potentiometer knob.
If the crackling is on the subwoofer only, it might be damaged from bottoming out.  See if you can remove the baffle or grille covering the woofer and inspect for visual problems. You can also try to lighly push in and out on the subwoofer to hear if it makes any scraping sounds. If so, it is definitely damaged and the driver will have to be replaced.
Mike
Posted on Oct 29, 2007
Which subwoofer will sound the loudest?
When you're looking for a loud subwoofer you'll need to consider sensitivity, enclosure type and available power. You'll need to start with a subwoofer with a high efficiency (sensitivity) rating housed in a ported or band pass box.
Power the sub with an amplifier that has a power output that is within your sub's recommended power range. You'll achieve the slam you're listening for. Using an amplifier with a bass boost control can also help.
Jul 29, 2012 | Furniture
My sony STR-DE475 has no bass. The bass just went out after running it for 6 hours.
Either the subwoofer speaker or its amplifier failed - they couldn't handle the extended use. Simple test to find out which: put the volume really low, connect another subwoofer (or a large normal speaker) to the bass output on the receiver and play some music. If you get sound then the original subwoofer is faulty, just get a new one. If you don't get sound then the amplifier for the subwoofer channel has failed. You could replace it yourself if you have enough electronics repair experience, otherwise it will be cheaper to just get another good sh low end receiver from a site like Ebay.
Sep 26, 2011 | Sony STR-DE475 Receiver
The pickup on my epiphone pr5 booms if i play loud, and if i tap the body anywhere it scratches and booms even with new battery
Sounds like you are using incorrect settings on the amp you are using. Try all tone controls at 12 o'clock as a start. Excess bass boost is a good way to have the problem occur. Also back off the volume control. "Handling" noise or scratching from handling the guitar is NORMAL for this type pickup. Back down the volume and DO NOT boost the highs or lows to help with the handling noise problem.
May 23, 2011 | Epiphone PR5-E Electro Acoustic Guitar...
Hi my creature 3 speakers were used at a party and the subwoofer dropped a couple times off about a 2 feet high table. now whenever i try to play music from my computer theres a loud buzzing noise in the...
A wire inside the cable has probably come loose, unless you (or a friend) have decent soldering skills to just replace the wire form the audio controller (most likely spot to have problems) to the PC they are probably just trash.
May 17, 2011 | JBL Creature III 2 Speakers
Hello. My mirage sub just started to make a fuzzy noise when playing the bass...it happened after a party that played music on the sub very loud. I don't know what to do....help!
You have damaged the sub by playing it too loud.
Its either the map or speaker that has gone.
You should send it off to get repaired.
Please dont forget to vote this answer was helpful
Many thanks
Feb 20, 2011 | Mirage OMNI S8 Speaker
When my KEF home theatre subwoofer is maxing out on bass, it often makes a loud popping noise. Should I be making some adjustments to reverb, volume, or something else?
Yes you should make adjustments.KEF makes very good products, however if you don't handle this you will have to replace or service it.
1 If the woofer is very close to you, relocate it further away. The reason being is that the lower the frequency the larger the wave form. The lowest waveforms will become louder.
2 Adjust the high frequency cut off to be at 80Hz. This should eliminate boom. Higher Sub frequency tend to muddy the sound.
3 The sub should have a subtle effect in music. So the relationship between it and the speakers it augments the sound of should be seamless.
4 If you are playing Rap or Reggie music and you like to play it loud. Add another sub into the system and locate it NEXT TO the KEF Sub. In this fashion the two subs will reinforce each other's energy. They will "couple" thus multiplying their energy considerably.
Hope this helps,
Best Regards,
Mark
Jan 04, 2011 | Audio Players & Recorders
I have a wharfedale svp15 passive loudspeaker. The subwoofer has started crackling and popping at low volumes and has no deep bass. At high volumes it sounds great as usual and can't tell if the crackling...
Information I find online says it an Active Subwoofer, so that introduces its own amp as a possible source of the symptom. If there is another version of this model that's passive, all the more reason to believe the amp is the problem because passive speakers don't spontaneously emit sounds.
If there was a physical reason for the crackling I would think more power would make it worse or blow it up.
A poor sub signal cable connection might explain low current anomalies if random noises are entering the signal path.
Make sure the signal, speaker and power cables are not aligned parallel and close to each other.
Feb 26, 2010 | Audio Players & Recorders
Boston BA790 Subwoofer Making Strange Noises
I just took my sub apart and found that the surround on the driver speaker inside the sub was totally crumbled and lying in pieces throughout the sub box.
I'm looking around now for specs on the sub speaker so I can find a replacement.
Feb 03, 2010 | Boston Acoustics BA790 Computer Speakers
Ive got a prob with my xplod subwoofers, Any info???
It's your amp. unplug the rca's and that should narrow it down for you.One at a time. If it sounds like a bass drumroll, then like i said, it's the amp.
Sep 05, 2009 | Sony Xplode P5 Turbo Subwoofers Car...
Altec Lansing 221 Computer Speakers Logo
1,384 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Don Hart
MegaByteMe
MegaByteMe
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
