Question about Philips Magnavox MRD510/17 Theater System
Magnavox MRD-510- when I plug it in, it just makes a clicking noise and the power button keeps flashing. When I unplug this unit it continues to click for 5 seconds. Only owned for about 5 months and now not working. This unit was plugged into a surge protector and so was the tv but the tv still works. Any suggestions??
  • 1 more comment
  • Anonymous Feb 19, 2009
    when I plug it in it makes a clicking noise but will not power up.
  • scottmw Apr 08, 2009
    Same problem here....no solutions yet?
  • Anonymous May 21, 2009
    When I plug it in it makes a clicking sound and the power light flashes. when I unplug the unit it clicks and flashes, speeds up alittle and stops. Unpluging it for an hour does no good.
  • Philips Master
  • 19,396 Answers
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
Receiver worked last night. I turned it on this morning and it just clicks over and over. Never comes on. I have to unplug it just to make it stop clicking.
What is the model number of this receiver? It could be in Protection Mode. Is power button on the unit flashing red? If so, that's protection mode. It could be as simple as a speaker wire got crossed or cut but it could also be something internal.
Step 1: Label all wires plugged into the receiver so you know where to put them back.
Step 2: Unplug everything, including the power cable.
Step 3: Leave it unplugged for 10 minutes.
Step 4: Plug in *just the power cable*
Does it still click? If so, it's an internal component that's bad.
Does the clicking stop? If so, add one wire at a time, waiting 1 minute before plugging in another wire. Keep adding wires till the clicking comes back. Once the clicking comes back, unplug the last wire you plugged in. That wire has a problem. It could be the wire itself or the device connected to the wire. If it's a speaker wire, for example, it could be that the wire got chewed or cut, or it could be that the speaker got fried inside.
Mar 19, 2016 | Denon Audio Players & Recorders
My Magnavox plasma screen tv, model number: 42MF237S/37 makes a clicking sound when I try to turn it on. No sounds, no picture, just the clicking noise. Things I have tried so far: 1) Turning the TV off...
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Jan 03, 2010 | Philips Magnavox 27MS343S 27" TV
Blinking green light and clicking noise AFTER bulb replacement
do this. press and hold device and menu button on set for 5 seconds. this will retrieve a 2 digit error code .. the led will flash the first digit and pause the flash second digit. This unit is known to have capacitor problems on the power board. getting to these capacitors involves taking alot apart. let me know error codes and we can continue troubleshooting
Jan 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Protect mode shuts down the receiver
If this happens only when connecting the receiver, chech the receiver cable. If the cable is fine, receiver connector at the back of receiver is faulty.
Bad speaker wiring.
Internal fault.
Regards.
Dec 23, 2008 | Samsung HTZ-510 Theater System
Lost installation guide for Magnavox MRD 510 Home Theater System
Download MRD-210 User Manual as it might help you to hook up video cables properly. Connections between Tv and Homer theater is not proper in your case.
Sep 11, 2008 | Philips Magnavox MRD510/17 Theater System
DVD Player
1) Reset the DVD player by unplugging it from the wall outlet for 20-30 seconds. Hold in the power button and replug the dvd/vcr while continuing to hold the power button for an additional 20 seconds.
2) If that fails, run a DVD cleaner (if possible)
3) If the above two methods fail, call Philips to get unit replaced.
Lightning could easily have caused such a problem. DVD players have a pretty low life expectancy nowadays, even from reputable manufacturers like Philips and RCA.
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
My Sanyo HT28745 28" HDTV clicks but doesn't turn on
I have had a similar problem with my tv, it has something to do with the power supply.Try unplugging your tv from the AC outlet. While unplugged from the power supply hold down the - volume control and then plug the tv back in while holding down the - volume control. It should bring up the service screen. If the screen turns on and is blank then it may need to be brought in for repairs.
If the screen does turn on, either blank or with the service menu, turn off the tv and unplug it from the power supply again. With it still unplugged hold down the power button on the tv and then replug in the tv. continue to hold down the power button until the tv displays a video signal on screen.
Feb 02, 2008 | Sanyo HT28745 28" TV
Philips Magnavox MRD510/17 Theater System Logo
238 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
