Question about LG LRE30451 Electric Kitchen Range
Very simple I thought- Cleaning the inside of the glass on oven.
I have an LG LRE30451SB and some spill over went inside the vent by the handle and ran down the inside of the glass panel. I would like to clean this and thought it would be easy three screws at the bottom appearing to hold the glass in place. Remove them the glass will drop, I clean and replace. Not that easy apparently seems to be secured at the top as well and I can not seem to find the hidden secret.
Just want to clean the glass? Any help out there?
  • 1,543 Answers
Don't have one here at home to look at, but the best way to go about that would be to remove the door from the range to work on in on a table, allowing access to any screws at the bottom of the door for disassembly and easier reassembly. To remove door: open oven door. Use a small screwdriver to poke in the small rectangular hole on the hinge and flip down the little lever toward the door. It is mostly hidden at the top of the rectangular hinge opening in the range frame. (do both hinges) Now with the levers down (locking the door hinge) you can lift and pull the door a bit, removing the door and hinge in one unit from the range body. Sounds more difficult than it is. It really only takes 10 seconds. To replace the door, just reverse procedure, remembering to flip the little levers back up after attaching door to range frame.
Posted on Nov 30, 2008
We have a Kenmore double oven. Awhile back something spilled as it was being removed from the top oven, and spilled onto the door of the lower oven. Now the glass inside the lower oven door is streaked and...
Please follow the below steps
1)Open the door.
2)Check the hinges and let the door be opened in half way.
3)Use Philips screw head at hinges screws.
4)remove the door and take the inner part alone.
5)Just follow the picture for more help.
Clean it and place it again.
It is very simple you can easily clean it.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 07, 2011 | Ovens
Oven door window has streaks
you have to let the oven dry and clean and you should not put any oily foods on it..
Apr 11, 2010 | Frigidaire 27 in. Electric Double...
Frigidaire double oven - stove top oven had a spill. The spill went through the bottom oven's door vents and is now in between the glass and I cannot get to it to clean. How can I get this glass clean?
I had a similar problem with a spill running into the vent and between the glass. I had to take the door apart clean it and then put it back together. It sounds hard, but it was just a few screws and a little time.
Jun 27, 2009 | Kitchen Ranges
Exterior glass trim on Kenmore Electric Range 880-5981
While waiting for someone else to answer my question, I fiddled around with the door parts. I managed to reassemble them! Here's how:
1. start with the glass panel. Slide the glass panel into the slot at the bottom of the front door frame on the stove.
2. next attach the handle. There are slots on the bottom of the handle that fit into the top of the glass panel. Slide the handle slots into the top of the glass panel.
3. screw the handle onto the oven door using the predrilled holes on the inside face of the oven door.
4. last, attach each of the two side trim strips. Slide the top of each strip into the bottom of the handle on each side of the oven door. Then slightly bend the strip outwards so that they are short enough to fit into the bottom slot of the oven door frame on each side of the glass panel.
Jan 22, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
Cleaning Oven Door Glass inside face
First take the two inside screws out, (found at the top of the door) they will pop out when you have both sides off so make sure to take them all the way out so you dont lose a washer or one of the screws. The handle is actually secured by these 2 screws and will come off of the door when you remove them.. your metal door can bend slightly in this process, so be careful. as soon as the handle and screws are off you can clean inside of the 2 pieces of glass, also a good time to clean off the opposite side of the door behind the handle. only take the 2 screws off no need to remove the full door. I used a magic eraser to remove the grease and then I cleaned the glass with glass cleaner. I used a small vice to secure the door when putting the handle back on, but you could have someone to hold the piece togeather for you too. (I have a frigidaire stainless steel model)
Nov 09, 2008 | Dacor Epicure ERD36 Dual Fuel (Electric...
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Aug 19, 2008 | LG MV-1444Y Microwave Oven
Glass window cleaning!
You have to remove the inside skin of door, pull door up and off of hinges and lay on floor to make this easier. Then you remove clips or brackets that hold the glass to door and clean. Very simple, but time consuming, mainly lining skin back up on reassembley.
Jan 27, 2008 | Ovens
LG LRE30451 Electric Kitchen Range Logo
464 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
