Question about TruTech PVS12701 Portable DVD Player
Battery won't charge
Product runs ok on a/c power
    President:
  • 2,110 Answers
Try to replace Battery..
Posted on Nov 30, 2008
I have a compaq nx7400 and the battery won't charge new battery and new charger.all it says is charging any ideas how to fix this
good day!
did you give it 24hrs to finish a charge?
the PC has a charging chip inside.
new battery from whom>?
the line pack is not a charger its line power pack,
it converts 120vac (or 240 outside usa) to 19vdc.(Or your spec)
the 19vdc runs the PC perfectly with no battery installed DOES IT>
that is the first test. the power pack must be the the correct pack
for:
voltage
current (never lower spec)
and watts.
if not the correct power pack it will now work correctly
the watts can be higher no problem,
if it runs ok on line power no battery
then we try the battery. (give it 24hrs for stubborn old batteries)
if the power pack is ok, it will charge, (spec pack as HP tells you)
if the battery is bad it will not.
if the charger chip in the PC is bad (MOBO BAD) then it will not
testing takes, skills and tools, one tool is a voltmeter
lacking that tool, one can only guess.
what not get your PC repaired by a TECH.???????
here is your HP page, its non trivial, no>?
see that they have 5 power packs used
that is BECAUSE they HAVE many power levels of CPU/GPU
faster rated CPU'GPU need more power.
https://support.hp.com/us-en/product/hp-compaq-nx7400-notebook-pc/1847094/how-to
you never once said
it runs perfectly on AC power only
not once
nor it does not overheat. nor if the fan works and vents all are free of lent.
Mar 29, 2017 | Compaq Computers & Internet
New battery HP g61 is fully charged but not working \
Maybe the AC Adapter Power Cord is not working. If you can't get on the laptop with the power cord then it is bad and the battery might be drained so you have no power source to power up the laptop.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 30, 2012 | HEWLETT-PACKARD HP G61A50US 156 AMD Athlon...
T will indicate charging but it won't charge actor
Apr 23, 2012 | HP Compaq nc6400 Notebook
How to test laptop output to the battery
Click Start Control Panel and go into the Power Options to check the Battery Meter. Batteries on last for so long. Maybe it's time you buy a new one.
Apr 20, 2012 | HP Pavilion Dv9910us Notebook PC
Batterie ne charge pas
Apr 02, 2012 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hi I have a Toshiba laptop model no.psl2xu-ookoof and it doesn't charge anymore so what do I do
If the laptop works only off the Power Cord and the battery is not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let the latop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in and remove the power cord. If it won't boot or shuts down then the battery is dead and needs to be replaced if the power cord is ok.
Mar 26, 2012 | Toshiba Computers & Internet
Laptop Battery Won T Charge on a laptop dell inspiron 1525
Battery could be dead and won't hold another charge. Batteries only last for so long until you have to replace them. If you laptop is ok with the AC Adapter & Power Cord meaning it boots and allows you to work in windows, then the battery is definitely dead.
Mar 19, 2012 | Dell Computers & Internet
TruTech PVS12701 Portable DVD Player Logo
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
