Question about Acer Aspire 3680 Laptop
Slow slow slow
Very slow start and runs slow did disk clean up and defraig and every thing else i can think of
  • gemakitty Nov 30, 2008
    tried it already thanks
  • 903 Answers
Have you tried turning off any background programs that you do not need running in the system tray... Check out your system tray and exit any programs that you do not need.
Posted on Nov 30, 2008
  • Debs
    Debs Nov 30, 2008
    have you thought about buying a software program to clean up the registry and make you computer faster? Uni-blue is a good program.
How to speed up my HP Pavilion windows 8 laptop
  • Linda, run your anti virus to check system,
  • run disk clean up
  • run defrag
  • running these 3 things could make a drastic improvement
  • press the helpful button and follow me on fixya for more tips and info.
Feb 14, 2016 | HP Pavilion Computers & Internet
I have a Toshiba laptop with a Windows 7 operating system, a few years old. It recently started randomly shutting down - after 10 minutes or so of use, it would just go dead. It's also extremely slow,...
Hi.
the first thing i would check is to make sure there is no dirt or dust stopping the fan from running because if the fan is not running it will heat up and shut down or if the fan is running slow it will shut down.
and for running slow i would do a good clean up get rid off stuff thats not needed anymore.like music,pictures,the more your harddrive has on it the longer it will take to load and run.
Oct 21, 2017 | Toshiba Satellite L455-S5975 Series Laptop...
The start up was loading and it is slow..and my friend said that the hard disk of my netbook is the problem..what will i do?
The slow start can be a caused by the processor speed, ram, graphics, bios, many things can cause it to load up slowly if your friend thinks its the hard drive without physically hearing the sounds it makes then its probably is, i would recommend you buy a new hard drive for your laptop and installing your operating system depending on how big you want the hard drive to be can be a bit expensive getting a hard drive with at-least 2-4 meg cache will greatly speed it up too.
Jun 29, 2011 | Computers & Internet
Too slow
Try: http://www.piriform.com/ccleaner
Mar 09, 2011 | Computers & Internet
My computer is very very slow.
Block the Startups and Services
When your computer is started up, there might be a number of programs and services running in the background. Some of them would be update checkers, error reporters and the rest are necessary tools like your antivirus etc.
The idea is to disable running the start-ups and service that you no longer need.
  1. Click Start ' Run.
  2. Type MsConfig and press ENTER.
  3. Disable the start-ups and services from the Startup and Services tabs respectively.
  4. Click OK button and restart the machine.
Defragment the Disks
My computer is slow to start up if the disks are too fragmented. Fragmentation refers to dividing a file into several parts which cause slow down in retrieving their contents.
The problem can be solved by defragmenting such fragmented disks using the Disk Defragmenter.
  1. Click Start ' All Programs ' Accessories ' System Tools ' Disk Defragmenter.
  2. Select all the drives.
  3. Click Defragment disks button.
Defragment your Registry
Registry is the database in your operating system containing significant configurations and information. Registry fragmentation too cause my computer is slow to start up issue.
Defragmenting the registry is too simple. You have to download a third party Registry Defragmenter software and install it o your system.
Set Up the System for Best Performance
Setting Windows for maximum performance rather than best appearance could fix the problem. Whenever my computer is slow to start up I perform the same task. The steps are provided below:
  1. Right click My Computer.
  2. Select Properties.
  3. Click Advanced System Settings link at the left hand side of the window.
  4. Click Advanced tab.
  5. In Performance frame, click Settings button.
  6. Select the option Adjust for best performance and click OK ' OK.
Disinfect the System
Sometimes computer is infected by a virus and I feel that my computer is slow to start up.. Change the existing antivirus software and download a good one. Update its virus definitions and conduct a full scan through it. Remove all the infected files that found.
Fix My Computer is Slow to Start Up Now
Feb 28, 2011 | Computers & Internet
We understand that your problem is: My desktop runs really loud and there is plenty of memory space available but it runs very slow. Its not consistent in the way it runs for example sometimes if I...
Format the Operating system and start fresh
Some useless programs or virus's may be slowing down your system
a reset will enable you to regain full speed of your pc again.
And don't forget even with loads of memory the CPU may be lacking to run most of today's programs all at once.
Sep 19, 2010 | Dell Dimension 4700 PC Desktop
Slow computer. Slow to boot. Runs slow most of the time. Running Windows XP on Dell Dimension B110. Verizon high speed access. Use Explorer. Plenty of disk space. I've run the cleanups, killed the...
First thing I would do is take the desktop outside and clean it out with two cans of compressed air.
HEAT can really slow a machine down. Let me know if that makes a difference (good to do either way) and we'll go from there.
Aug 14, 2010 | Dell Dimension 2400 PC Desktop
Dell pc to slow
Yes, you can get (any) help. You must run a Registry Cleaner. It will clean your Windows registry which seems to be having irrelevant entries. You can down load one free from www.download.com or you can search google for free registry cleaners. I had the same problem and my laptop used to take over 20 mins to boot. I cleaned it with one RC and now it gallops like a new laptop. I do not think that you have any hardware problem.
Nov 15, 2009 | Dell Dimension 2400 PC Desktop
My Laptop is suddenly taking 15 minutes to load up after turning
clean the pc up to speed it up a little, download ccleaner and install it, run the cleaner and delete all the files it finds, then clean the registry and fix the issues found, if it asks you to save the changes to the registry click yes and fix do this a couple of times so no issues are found.
If the pc is still slow after this clean then the issue is either memory or the operating system is degrading.
http://www.filehippo.com/download_ccleaner/
good luck
Jan 26, 2009 | Acer Aspire 5100 Notebook
Slow start-up
check if you have a CD left in the cdrom drive.
Lots of things can cause the start-up delay too:
- virus and spywares. Clean.
- bad sectors on hard disk (backup and plan for replacement)
- low physical memory. check in the Performace tab of the Taskbar (window$$$ only) PF should not be more than that of physical
Sep 24, 2008 | Dell Inspiron 6000 Notebook
Acer Aspire 3680 Laptop Logo
1,948 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
