Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Help needed with WG834g & usb adapter
I was on bt broadband with their adsl router. Purchased a Netgear WG834G with Netgear usb wireless adapter. Installed as directed by the disc, no connection. Tried re booting but to no avail. I am back on the old router now hoping someone can tell me where I have gone wrong. The signal strength is good but I cannot connect to the web. I cannot hard wire from the WG834g to my pc because my pc does not have an ethernet port. Any ideas please? Thanks
  • Roger Rhodes-Bangham Jan 21, 2007
    Thanks
    Will try this when I can get an intranet to usb cable
    Regards
Nice 1 sandrew worked well thankyou
Posted on Nov 08, 2007
    President:
  • 2,961 Answers
Sometimes a hard wire cable whether lan or usb is needed to set up the router first before going wireless. If not it maybe your pc needs a ip/dns flush from the last allocated numbers from your bt router. To clear this:- Click Start>Run, then type ipconfig /flushdns then press enter.
Posted on Jan 21, 2007
  • andrew pester
    andrew pester Jan 22, 2007
    No it will be a usb to power or a lan to lan end cable, look at the back of your modem it may not have a usb connector only some do.
I have a acer aspire 5735z and cannot connect to my new adsl modem, telstra ( internet provider) told me to ring acer, will the acer company tell me i need a new drive and will i have to pay for it??? this...
Is your Telstra/Bigpond ADSL modem has a built-in wireless router?
If the ADSL modem has a built-in wireless router and your laptop does not have a wireless card, then you have two options to connect your laptop to the ADSL wireless router/Internet -
1. Purchase a PCMCIA wireless adapter and insert it into the PCMCIA slot in your laptop. One of my favourites is made by Netgear.
or
2. Purchase a USB wireless adapter, the only disadvantage with this solution is, it uses a USB port and if your laptop has only one USB port. This is a problem if you need to connect other USB devices. Then you also need to purchase a 4 port USB hub to give you additional USB ports.
Aug 25, 2010 | Acer Computers & Internet
I use AOL as my ISP, with British Telecom supplying my telephone line rental. On Friday 2nd my internet connection kept dropping out, and then eventually stopped connecting altogether. My original router...
If BT tested the phone line is OK but did AOL test the connection to the Netgear router and get the IP address of your Netgear router.
The phone connection is OK but the ADSL connection from the telephone exchange may not be working, that is why you are not getting an ADSL light.
Jul 12, 2010 | NetGear DG834 Router
Have wireless broadband on home computer with Netgear dont have network key which I need to connect new laptop to wireless broadband Bt of no help and cannot give me a no fo Netgear either even though Bt...
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 19, 2009 | NetGear DG834G Router
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
Dec 07, 2008 | NetGear WGR614 Wireless Router
How do I install a netgear adsl modem router dg834gt
no you can't use the belkin usb 10/100 ethernet adapter CD to install the netgear adsl modem.
click here to download the installation manual for the netgear device
Sep 09, 2008 | NetGear DG834G Router
USB Modem V ADSL Router/Modem
Unplug the plug (from phoneline) on back of USB modem, plug into Zoom router. Plug one end of an ethernet cable into router and one end into your PC. Type http://10.0.0.2 into a web browser (eg. Firefox or Internet explorer) username/password is admin/zoomadsl go to basic setup and input your ISP username and password (the one given to you by your internet provider) under PPP. Click configure my connection. Save changes and then write to flash (both buttons on bottom of page)
Aug 12, 2008 | Zoom X6 Adsl Modem/router Rohs...
2wire router and usb adapter
first u need to connect a pc through wired on the w/l router and go to w/l part and configuge it
Oct 05, 2007 | 2wire (1000-400108-001) Router
Belkin wireless G USB adaptor 802 11g
Correct installation of this cheap little piece of kit from Belkin might be the worst thing you ever do! If you find that Windows XP is freezing 10 times per day, just remove the wirelss adaptor and you will find that the problem disappears... The conclusion will be as obvious to you as to many other users.
Jul 13, 2007 | D-Link AirPlus G DWL-G122 802.11g/b...
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
77 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
