Question about Canon CanoScan 5000F Flatbed Scanner
Cannot scan for these reasons:
Installed MS XP then downloaded driver for 5000f photo/film scanner now i get this error
Normal 0 Cannot scan for these reasons:
-The original may not be set correctly.
-The Film Adaptor Unit Protectiv Sheet may be put in place.
- The lamp may not be warmed up.
(It needs a few minutes for adjusting lamp on low temperature.)
Scanner driver will be closed
Code:2,178,0
the negative is in the black tray and the white cover has been removed from the light
  • Anonymous Apr 13, 2009
    Same problem
  • grotti May 04, 2009
    exactely same problem.
    tried with original drivers on cd but also with newest drivers from canon
SOURCE: Error message when scanning
Seen this B4 ya scanner system board is borked... the power Supply failure is a symptom.. Probably ya port inerface/PSU ... so it's either shop it or ship it ... :)
Posted on Aug 24, 2007
SOURCE: Canon PIXMA MP160 problem
i need help getting this going
the error button keeps blinking htis is an new scanner printer
the alram button is blinking on and off
Posted on May 25, 2008
  • 111 Answers
SOURCE: how do i scan film on my scanner
You should be able to download the manual.
http://consumer.usa.canon.com/ir/controller?act=DownloadDetailAct&fcategoryid=351&modelid=10242
To scan film, you'll need to first remove the white cover on the underside of the scanner lid. That is where the backlight is. Also, you must be using the ScanGear driver and NOT the WIA driver. The WIA driver does not support film scanning. Locate your film guides. These are the templates that will hold the film and are placed on the scanner glass to be scanned. Lastly, there should be a Select Source option in the scanner driver that allows you to select Film as the source.
Hope this helps.
Posted on Jul 09, 2008
SOURCE: scanning negatives
I have the same scanner use this microsoft web page, it shows you how load the programs. http://windowshelp.microsoft.com/Windows/en-US/Help/bf416877-c83f-4476-a3da-8ec98dcf5f101033.mspx
Posted on Sep 06, 2008
  • 2692 Answers
SOURCE: Calibration cannot be performed Error
You stated that you tried to install it on a new computer correct? To install any hardware on a computer you need a driver which is compatable with the version of windows that you have. If you have an install disk , it may install but still be the wrong driver. Even if it is the correct driver. Drivrs are updated ongoingly because their are problems with communication for the device to the computer.
Download the latest drivers for your version of windows, aftwer deleting the software/driver that is installed now.
http://www.canon.com.au/products/scanners/scanners_low_medium_volume/canoscanlide50_support.aspx
Posted on Jan 08, 2009
My canoscan 5000f does not work with my os vista 32 bit, do you have a solution?
I have many years experience repairing Canon scanners so here is my suggestion for you.
My suggestion is this, I would google Canon Canoscan 500f drivers, just as I have written it to you. A page will pop up and download the latest drivers from Canon's official web site ( the drivers are dated). Before you install the drivers disconnect the cable from the scanner to the computer. Now install the drivers. Once they are installed reconnect the cable from the scanner to your computer with the scanner powered on. A window will pop up saying a new device or drivers are being installed.Once this is completed then reboot (restart) your computer and you should be able to scan again.
I hope this helps you out.
Mar 09, 2011 | Canon CanoScan 5000F Flatbed Scanner
Canon CanoScan 5000F Flatbed Scanner error 15. no manual.
Click on the link below to download the software, drivers, and owners manual for the Canon CanoScan 5000F Scanner:
http://www.cusa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_5000f
Oct 18, 2010 | Canon CanoScan 5000F Flatbed Scanner
Scanner will not scan an item into My Documents
try to uninstall then reinstall the driver. to do that go type device manager in run box in XP and start search in Vista/ Win 7, and look for the scanner. right click and uninstall. then load the driver from the website or from the cd that came with your device..
Mar 29, 2010 | Computers & Internet
Canon Scanner 5000F fails when adjusting lamp before scan.
Have the same problem. Suspect a lamp problem but cannot find any info/help to check lamp or to replace it
May 27, 2009 | Canon CanoScan 5000F Flatbed Scanner
Link Scanned Image - Error Message on Canon CanoScan 500F
"Link Scanned images to..." refers to the programme you want to open the file. Navigate to the .exe of your preferred viewer
Mar 25, 2009 | Canon CanoScan 5000F Flatbed Scanner
Can't use the ''Film selection on epson V700
Make sure the transparency light cable that comes from the lid is plugged in to the back of the scanner. If the cable is unplugged for any reason, the transparency/film options will not be available.
Nov 18, 2008 | Epson Perfection V700 PHOTO Flatbed...
Are there any other words along with the error?
Make sure the scanner is unlocked.
Does the scanner make any noise when you attempt to scan?
If possible, try the scanner on another computer.
Was the scanner working before?
What OS are you using?
Download the delete driver application and uninstall the drivers. Also, download the most current drivers and reinstall. You should also download and install the most current version of Toolbox.
Apr 19, 2008 | Canon CanoScan 5000F Flatbed Scanner
Scanning Film
Have you used this scanner on Leopard already? I didn't think this scanner was supported.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=8053
Do a search on "Leopard". The CanoScan 5000F is not supported in this OS.
Apr 05, 2008 | Canon CanoScan 5000F Flatbed Scanner
Canon CanoScan 5000F Flatbed Scanner Logo
570 people viewed this question
old marine
old marine
