Question about Fujitsu Siemens AMILO Pro V2000 Notebook
Amilo Pro V Fuitsu/Siemens Problem
I start my Laptop and there is no display on LCD, I also attached external Monitor and it is no help either. What should be the possible cause?
  • 3 more comments
  • Dan Nad
    Dan Nad Jan 21, 2007
    Actually I used F8 but i cannot see anything on the screen(LCD), thats why i also used external monitor, it doesnt show anything either.
  • Dan Nad
    ..the LCD is completely blank, i used torch too, is there a way to fetch Hard disk data.
  • Dan Nad
    Dan Nad Jan 22, 2007
    I used Windows XP recovery CD. Buy the way, I have Dual boot from HDD , Linux (default) and WinXP (optional). But since i cant see anything I am blind to take any action.
    Do you think USB-to-IDE Adapter (3.5") should work even though i cant access the screen?
  • Anonymous Nov 15, 2007
    blank screen power on
  • Anonymous Nov 16, 2007
    exactly same problem - no light on laptop screen - tried torch, don't have new enough external monitor to try it with, Siemens have offered to collect and repair - so this could be to do with a back light (sorry not that IT literate!!)
    Karen
    President:
  • 2,961 Answers
It may be the lcd or windows, press F8 on start up and see if you get a safe mode screen, if so highlight start windows with last known good configuration and allow a re-boot. If it is the lcd you can shine a torch at the screen to see if you can see the startup screen, if so the back light may be damaged and in need of a professional repairer
Posted on Jan 21, 2007
  • 2 more comments
  • andrew pester
    andrew pester Jan 21, 2007
    the external monitor needs to be set up on your desktop, it wont just come on by connecting it.
    Sounds like a backlight fault, try the torch to see if the desktop is there.
  • andrew pester
    andrew pester Jan 22, 2007
    Last thing before that, have you tried booting with a windows cd or is the restore/installation on a hard drive partition?
    It sounds like a processor or memory fault.
    The hard drive data can be retreived by means of usb to 3.5" adapter cable which can be read as a seperate drive; which you can purchase
  • andrew pester
    Sorry i was assuming it was a no go boot and not a screen problem.
  • andrew pester
    the usb to ide wouldnt work as it's not IDE it is 3.5" which is different to normal hardrives, but you should get an adapter with the kit.
    See this site for what i mean
    http://www.directusbstore.com/cnb/shop/d...
External monitor has no input signal
You can't just attach an external monitor to most running laptops. Nothing will happen. You must attach the monitor when the laptop is off, then start the laptop and it will recognize the external monitor and send the video to it.
Feb 13, 2014 | Compaq Presario CQ56-115DX Laptop
Toshiba m35x starts /stops intermittently with no power to display monitor
By whom Kathleen? You?
I ask because there are two ways to answer this;
1) You performed the procedure, and less for me to post.
2) You did not perform the procedure, and I need to explain from the beginning; using a diagnostic flowchart, pictorial guidance, and guidance from me.
While I wait for your reply, suggest perform this simple test first;
Laptop OFF, monitor OFF, attach an external monitor;
1) VGA monitor to RGB (VGA) port on left side of laptop.
Can use a CRT type of monitor (Looks like a small TV), or flat LCD screen monitor if it has a VGA cable.
http://en.wikipedia.org/wiki/VGA_Connector
OR;
2) S-Video port on left side of laptop for TV, or external video display device
http://en.wikipedia.org/wiki/S-Video
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external monitor. (Display device)
If not there are 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external monitor
3) External monitor ONLY
Press, and hold the Fn key down, and at the SAME time tap once on the F5 key.
The F5 key is the Display Toggle-Over key.
Still no?
Hold the Fn key down again, and tap once more on the F5 key.
Display on external monitor means there is a problem with;
A) Video Cable
B) screen Inverter
C) LCD screen
Which means if computer display was working correctly before;
1) Whoever repaired it could have used the external display option, and it needs to be set back to internal
2) The Video Cable connections are not tight, not correct.
Loose at motherboard, screen Inverter, or LCD screen.
3) Anti-Static Procedures were NOT followed, and laptop is now an expensive paperweight.
Post back in a Comment.
Regards,
joecoolvette
Apr 05, 2013 | Toshiba Computers & Internet
My acer laptop show white sceern only?
What can you do if the laptop LCD screen turned completely white? 1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard). Here's an example of a laptop with white screen. When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It's possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop. In some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you'll have to take apart the display panel because the connector is located on the back side of the LCD screen.
These laptop service manuals and disassembly instructions may be useful. Always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard. The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. you will need to connect to another monitor or your television to your computer with the vga lead monitor connection click start control panel display change display settings adjust resolution this may vary depending on your operating system you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes if you can get an extended desktop your monitor is faulty if you cant get an exended desktop Hope it helps
Jan 23, 2013 | Computers & Internet
MSI Laptop have no disply only white screen
hope it helps
Oct 14, 2012 | MSI WIND10 N450 1.66G 1GB 250GB SYSTWIFI...
No display,only bright wihite colour screen
which brand of laptop ?
hope it helps
Sep 23, 2012 | Computers & Internet
E248WFP (external) Monitor Won't Power Off when Laptop Screen does!
this is not a pc problem... this is because the connection loss between pc and monitor... not all pc's have sleep mode in externa vga connection.... it just cuts power off... u can configure monitor of possible to do that..
Jul 09, 2012 | Dell UltraSharp E248WFP 24" LCD Monitor
Hi, I started to have an issue with a display of my Tecra M5. The laptop is 2 years old and there has been no problems with it before.. Last week I attached a 32" LG LCD TV to my Tecra as an...
the 32 inch LCD may have a lower display resolution that the LCD on your system. Ensure that the display settings for the LC are at the MAX resolution and 60 htz
Jul 31, 2011 | Toshiba Tecra M5-S433 Notebook
Good day, May I inquire how to fix Acer Aspire 4520G there is no display on the monitor, but i heard the fun running. What are the possible cause of this, is it video card, CPU or motherboard. I'd tried...
to help isolate it, try to connect an external monitor to it. If display works on the external display, problem would be the laptop LCD. If you can remove and reconnect the LCD cable to the motherboard, that may help. If no display on both display, try to test the hard drive to another laptop if you can, or you can try reinstalling Windows. If no display at all, chances are, it is the video card.
Nov 13, 2010 | Acer Aspire 4520-5141 Notebook
Lap top ok but cant see anything on screen
2 possible problem, bad LCD or bad CFL. attach an external monitor and start your laptop. if you see a display, you need to bring your laptop to a professional repair center because fixing CFL needs special tool. if you are capable of removing parts of your laptop, you can find LCD assembly on ebay.
Oct 14, 2009 | Acer Computers & Internet
How to undo the sleep mode
actually in these case laptop does'nt display due to many causes some might be in vga chips, inverter, and LCD etc. but in these side first check if light indicators normal all. then check the inverter.
Jun 10, 2009 | Fujitsu LifeBook A1110 Notebook
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
341 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
