Question about LG L1730S 17" LCD Monitor
I am using LG 1730s moniter. I have one problem on it. When I turn on the power, it has not any signal on it and power indicator is not work. Is there any way to use the hard reset on my monitor?
4 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: i have lg lcd flatron l173os monitor,it has a
First place to check will be the caps in the power supply section, but please read below and look at my pictures so you will understand and know what to look for inside the monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 08, 2010
SOURCE: LG Studiowork, CRT Moniter, picture not display on screen
http://www.eserviceinfo.com/index.php?what=search2&searchstring=studioworks+700s+(cb777f)
Service and repair manual above.
Posted on May 23, 2010
sentsignal7
  • 186 Answers
SOURCE: how to use lg 1730s
You can't use it as a touch screen. Only for viewing purposes.
Posted on Oct 24, 2010
On power up, why does it indicate 'use genuine battery', then shuts off?
If your phone does not indicate it is charging, the 'use genuine battery' message may its way of telling you the battery is defective.
Nov 23, 2015 | LG VX8350 Cellular Phone
LG Flatron E2042. Brand new. New CPU. Windows 7. I plugged in my new monitor today. Does not turn on automatically. But when I do turn it on I get an error message. D SUB POWER SAVING MODE and tur
Your new moniter may not be compatible with your computer. I have an Emachines that won't take a flat screen. I have to use a big bulky moniter because it says not connected even thought the hookup fits the back of the tower. That might be your problem. Did your old moniter work correctly?
Nov 15, 2012 | Computers & Internet
How to use lg 1730s lcd monitor as touch sreen for my desk top
Oct 24, 2010 | LG L1730SF 17" LCD Monitor
Lg Flatron 17" monitor turns on you see the green light then
it's prb.. your video card not the moniter if a moniter goes from green to yellow " standby" it's prb the computer not the moniter
Dec 27, 2009 | LG Flatron L1715S 17" LCD Monitor
Can't get monitor to power on
I have a similar switch on mine, although mine is a Gateway. So my solution is going to assume the same indicators and functionality.
On mine, a blue-violet power switch indicates it is off, red indicates standby mode, and blue to indicate it is on and/or searching for a signal. When turned on (blue), the monitor will go to standby mode (red) after 3 to 4 seconds if it does not detect a source signal. So if you toggle the power switch to blue and it soon changes to red, you'll need to check your signal, cable, or possibly for a bad source connection on the monitor.
Oct 12, 2009 | LG L206WTY-BF Monitor
NO Signal
I suspect that your power supply may have overheated if its fan is not working properly try another power supply
Aug 06, 2008 | Sparkle Power 400-Watt Power Supply
LG L1730S 17" LCD Monitor Logo
284 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
