Question about Magic Chef CMV1000B Microwave Oven
MCO160UW goes dead after 3 minutes
Just like the other reports, my Magic Chef goes dead after @ 3 minutes of popping popcorn. I went to alot of trouble installing it and we have only had it one day. I think the solution is to return it.
  • Anonymous Apr 14, 2009
    Our MCO160UW was also shutting down after we would pop microwave popcorn. It would boot back up eventually. But now it just died. No display or anything. We've had it for less than two years. Piece of junk. Magic chef-- never again!!!
I had the same problem with mine and called Magic Chef. You are likely overheating a thermal sensor. Somewhere in the manual fine print it tells you to heat things on a plate in the microwave. So, if you put a plate on top of the microwave glass tray and cook the popcorn on the plate, it should be OK.
Posted on Feb 03, 2009
I returned the item to Home Depot and they took it back no questions asked.
Posted on Dec 01, 2008
Shut's off after cooking popcorn, only popcorn, won't restart for 15 too30min.
Sounds like the magnetron is over heating. Try putting a 4 0z cup of water in the oven along side the popcorn bag. See if this helps. Usually, the oven only runs 2 to 2.5 minutes for a bag of popcorn. You may have to experiment with the slightly different cooking time...
Oct 29, 2013 | Magic Chef CMV1000B Microwave Oven
Have a magic chef mco160uw microwave. Had a recent
No! there is no reset, the power surge has more than likely damaged the keypad controller, and on the back is a circuit board that has the microprocessor with additional components that controls the vital areas of the microwave oven. If that is gone, it is cheaper to replace than to repair.
Feb 06, 2011 | Microwave Ovens
I arrived home from a week of traveling for work and all of a sudden my magic chef mco160uw doesn't work anymore!
thats life, if it can go wrong it will go wrong?
its just unlucky it went when it did most likly it was sat about and got cold and damp, you come home switched it on,,, it went pop! and died on you
its a comon thing with microwaves there very much like light bulbs,,, work for years then for no reson at all the just dont work any more,,,,,
my advice it check the fuses if all ok, bin the microwave,,, dont be temted to go inside of it as you may just kill your self doing it,,,there are 1000' of volts of power inside the thing and if you tuch the wrong part it fry's you the capacitor can hold its charge for a very long time and this charge will kill
have you ever seen a tazer working???
well this capacitor is its "very big brother!" and its not a case of,,, big deal, only 20.000 volts it realy is a big deal as its more likely to be 200.000 volts
please just bump it if its not a fuse in the plug,,,,,,,
be safe not dead
Oct 23, 2009 | Magic Chef CMV1000B Microwave Oven
Magic Chef Model #MCO160UW
Call 888-775-0202 Magic chef they will replace the part free of charge even if its not longer under warranty
Aug 14, 2009 | Magic Chef CMV1000B Microwave Oven
Shuts down for 5 minutes
I have the same problem with my new magic cheff over the stove microwave oven. I call magic chef and they gave me the 800 number for the service center (1-800-775-0202). When I described the problem they told me to just put a plate under the popper and this wouldn't happen anymore. I haven't tried it yet but here's hoping.
Jan 15, 2009 | Magic Chef MCD1311ST Microwave Oven
MICROWAVE WILL ONLY HEAT ON CERTAIN SETTINGS. how do i set the heating instructions?
I have a Magic Chef model MC0160UQ. Within 2-3 minutes of heating food it shuts off completely for about 5min. Also, when I select the low fan it does not work, however the high fan works. Please assist with these issues if possible. Am I able to fix or adjust the magnetron myself since it may be overheating? or what should i do?????
Jul 18, 2008 | Magic Chef CMV1000B Microwave Oven
Replacing the fuse of a MCO160UW
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 15, 2008 | Magic Chef CMV1000B Microwave Oven
Magic Chef MCO153UW
The cooling fan is a must!
Otherwise, the magnetron will be ruined, and that drives up the repair cost.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order parts here: https://www.mcappliance.com/partorder.aspx
To contact Magic Chef about getting an *authorized* servicer, see: http://www.mcappliance.com/contactus/contactus.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 06, 2008 | Magic Chef CMV1000B Microwave Oven
Magic Chef Microwave looses power when making popcorn
That does indeed sound like the mag is overheating and the thermostat is tripping, but it's probably not the steam.
Do you feel a good amount of air flowing through the vents?
If the cooling fan is not running or the air vents are blocked, that wil allow the magnetron to overheat.
If air flow is not a problem, then you may have a defective magnetron.
Assuming it's still under warranty, it would be best to let a Magic Chef-authorized servicer handle it.
For more help from Magic Chef / Ewave : http://www.mcappliance.com/ ; Contact page http://www.mcappliance.com/contactus/contactus.asp ; Order
parts https://www.mcappliance.com/orderpart
Sep 10, 2007 | Microwave Ovens
Magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Sep 02, 2007 | Microwave Ovens
Magic Chef CMV1000B Microwave Oven Logo
459 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
