Question about Dryers
Belt on dryer
I have a kenmore dryer model # 96374210 I believe the belt broke on it but can't figure out how to get to belt to see it. Have taken back off but can't see inside. Dont know if top or side is suppose to come off to see belt.
  • 2 more comments
  • channalou Nov 30, 2008
    it is one with lint screen on top JR JR
    I removed lint screen and took out 2 screws but can't get it to slide at all. Even took out 2 screws on black pieces in back holding top to bottom. Tried to pull to front and back but wouldn't move.
    can't get to slide
  • Johnny Ramirez
    Johnny Ramirez May 11, 2010
    is this a dryer w/ lint screen on top,, or inside door in home appliance technician
  • 116 Answers
Remove lint screen first,, then there are 2 screws,phillip head,remove now w/ both hands grab top of dryer slide it towards u should come,,now u have 2 screws on each side 5/16 screws remove///// first before anything disconnect power please????thank you ///u have a wire connector possible white wires remove w/ small thin flat screw driver ,now u will see the belt pull if comes straight out replace aready have open belt cost about 35.00 // remember do not need to remove drum just slide the new belt and follow the steps of reassembly...
Posted on Nov 30, 2008
I have a kenmore gas dryer does not rotate believe the delt is the proublem. model #87870100
note Kenmore/Whirlpool same belt configuration:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to open dryer:
http://www.applianceaid.com/wpdryer_how-to.html
Mar 19, 2011 | Kenmore Dryers
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
I have an electric kenmore 600 dryer. The problem is the motor does not spin. The light comes on, the heating element gets hot and I checked the belt and it is not broke. I believe I have a bad motor I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 04, 2010 | Dryers
Dryer drum does not turn
Most likely the belt broke, replace the belt
Aug 14, 2009 | Dryers
I have a kenmore 90 series dryer, the drum belt broke, bought a new one, but cant figure out how to get it on, too much slack in the belt, not sure where it goes on
REMEMBER BELT GOES AROUND IDLER PULLEY AND ATTACHES TO MOTOR SHAFT ,PULL BELT W/ HANDRUN BETWEEN ROLLER, AND PULL BACK AND ATTACH ON MOTOR PULLEY AND THAT ITS
Jan 02, 2009 | Kenmore 64952 Electric Dryer
Kenmore elite quiet pac 9
unplug dryer, then take the top off and check your connections to door switch.i believe this model has a broke belt switch.open the bottom with the machine unplugged and reach inside and see if the belt is broke.if it is then replace the belt.
Nov 03, 2008 | Kenmore Elite HE4 Electric Dryer
Lse1000
The hard work is over! The old belt should pull out from the drum area if it is broken. There should be two ends to it now. Get a new belt and put it over the front of the tumbler. You should, (with a flashlight) be able to see where the old belt was running. Get the new belt close to that spot.. I believe your model ran with the smooth side of the belt to the drum.It will not look right to you, but the tensioner passes the belt through the pulley and motor pulley on the grooved side of the belt.Once the belt is on, reassemble the dryer front in reverse of disassembly.
Jun 13, 2008 | Maytag LSE7806A Top Load Stacked...
Kemore Dryer 11064602300 belt replacement
Go to repairclinic.com. Click on the "Repair Help" heading on the left-hand side of the screen. On the next page is a "Dryer Belt Diagrams" heading on the left hand side. Your dryer belt diagram will be either "H" or "K" listed under the Whirlpool section. Your Kenmore is manufactured by Whirlpool. I hope this helps you. Please post back if you need further assistance.
Jun 06, 2008 | Kenmore 62822 Electric Dryer
Dryers Logo
152 people viewed this question
Top Dryers Experts
