Question about Refrigerators
Sears Kenmore Bottom Freezer Refrigerator Model #795.77562600 Serial #608KR00238 The control pad displays only Er CO. The control pad is locked up. The ice maker runs. It won't make ice. You can not change from water, ice to crushed ice. It won't dispence water I would appreciate and assistance on this matter. Thank You Len
3 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Kenmore Elite Bottom Freezer Refrigerator
This first thing I would do is remove the panel on the back of the fridge to access the control board. It should be about half way up on the left hand side if you are looking at the back of the fridge. There should be four 1/4" screws to remove. In the middle of that board there should be a reset button. Press that button then let me know if that worked.
Posted on Nov 30, 2008
blueextc3221
  • 15935 Answers
SOURCE: Control Pad displays Er CO.
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
Kenmore bottom freezer refrigerator showing ER on one side and DH on other on temperature control
Hello Mike,
It means that most likely that your Defrost Heater (DH) is not working and one of the following items could be bad;
Er dH Sensor did not get over 40 F Faulty fuse, heater, control board Controller assembly, defrost heater, relay on control board Here is the whole list for your refrigerator;
Kenmore Bottom Freezer Refrigerator Error Codes for 795 Models Sears...
Good Luck!
Rich Lilja
May 12, 2018 | Kenmore Refrigerators
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
What does Kenmore refrigerator error code er co mean?
I just did a google search. It seems that it is a communications error between the computer in the back of the refrigerator and the front panel display,. Some people have replaced the computer only to find that the problem stays. At least two have found that wires have broken in the front door.
The wires get flexed when the door is opened and closed.
Use your model number at the sears parts direct to see user manuals diagrams and parts lists. Link below.
http://www.searspartsdirect.com/
Sep 06, 2014 | Kenmore Elite 29 cu. ft. Grab-N-Go French...
On my Kenmore Elite Bottom Freezer Refrigerator, the display on the left door reads ErCo and the ice maker does not work . Its less than 2 years old
Dec 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Help....kenmore trio refrigerator, error message "er co"
Mar 19, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Control pad reads ER IF
er if means the ice fan is not running. it blows freezing air into the ice maker compartment from the freezer. unplug the refer for 24. these are susceptible to frost or ice forming in the blade of the fan and prevents it from spinning. unplugging it will let it thaw. ice is a big problem with this model.
Dec 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Bottom Freezer Refrigerator Model #795.77562600 Serial #608KR00238 The control pad is locked up, it dispalys Er CO. You can't change from water, ice to crushed ice. The ice maker runs. It...
Nov 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
