Question about KitchenAid KERS807SSS Electric Kitchen Range
My KERS 807 SSS Stove works fine but not oven
My stove (i.e. ceramic cook top) works fine. But my oven and the entire control panel suddenly stopped working and seem to be completely de-energized. If I push any of the buttons, I receive no response. Also, lights inside the oven are dead. This problem occurred today, and my range is about 14 months old.
  • gkirzhner Nov 30, 2008
    thank you, I'll try
    President:
  • KitchenAid Master
  • 2,651 Answers
Sonds like a bad hightemo thermostat, loacted on the back wall behind the rear panel, common issie for ovens ,espessially after going through a self-cleaning,part number 9759242, part is about $50 turn off power before attempting to change, LIVE WIRES!!!!
Posted on Nov 30, 2008
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
I have KitcheAid KERS 807, electric stove/oven range. Left lower part of ceramic stove top that has single/dual heater sizes is malfunctioning. Single one is still working but from recent dual does not.I...
Either the knob has gone out or the burner element. I would test the knob first to see if there is current when turned to the large zone. If the knob is working, next would be to test the burner to see if the outer ring has burned out. I would guess more likely the control has gone out. Burners have less failure (typically).
Apr 14, 2014 | KitchenAid KERS807SSS Electric Kitchen...
I had new countertops put in and they took they drop in stove out. When complete tegy put the stove back in and everything worked fine. Within 5 minutes the control panel went off. Oven light works and...
The control panel must be on and in manual mode for the oven to work. Turn the power off for a moment and then back on. If the panel starts to flash, set the time and set it to manual and the oven should work. If the panel does not light up it is faulty and requires replacement.
Feb 26, 2011 | Frigidaire Cooktops
Oven won't work - digital display/control stopped working
probably a bad control board chekc out www.appliancepartssolutions.com
cheep parts...good luck
Jan 17, 2010 | Kitchen Ranges
Stove control panel not working
You do not have a fuse or overload button on a Maytag cook-top. If you heard a pop, it was the touch pad on your control board blowing out.
Oct 22, 2009 | Kitchen Ranges
Frigidaire Smooth Top Range/Oven stopped working
for all others with this problem: I had the stove serviced. Repairman reported a loose wire to the elemets (tightened and did not fix the problem) followed by a stuck relay, and after some banging on the back of the control panel, the elements now work fine. He said if it happened again the only solution would be to replace the relay/control panel, a part of about $160, but I'll get credit for the price of the service call already paid. Compare to the price of the stove, I'll accept the $125 for the service call.
so tapping on the back of the control panel is worth a try if your stove is pulling this trick.
Jan 20, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
KitchenAid KERS807SSS Electric Kitchen Range Logo
1,053 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
