Question about Kitchen Ranges
I recently dropped the lid from my 13 1/4 qt. round Le Creuset French oven and it has a small (4 inch) crack on the inside surface and a chip on top. I would like to replace the top for this pot. How do I do this? Shouldn't this be covered under warranty?
    Problem Solver:
  • 18 Answers
It won't be covered because you dropped it. maybe the shop where you bought it can order you a new lid.
Posted on Nov 30, 2008
13 inch round pan 2 inches deep =how many cubic inches
You can view this question as what is the surface area of the 13 inch round pan, and then with it being 2 inches deep, calculate the volume.
Surface area = pi * r ^ 2, where r is the radius of the pan
In this case, the diameter is 13 inches, so the radius will be 6.5 inches.
Putting it into the formula, we get surface area = pi * 6.5 ^ 2.
Because of BEDMAS, we have to do the square before we multiply.
Surface area = pi * (6.5 ^ 2)
= 132.7square inches.
To get the volume, we multiply this surface area by the depth of 2 inches.
Volume = surface area * height
Volume = 132.7 * 2
Volume = 265.4 cubic inches.
Good luck,
Paul
Nov 02, 2016 | Office Equipment & Supplies
What are the dimensions of t his dutch oven?
According to Amazon, the dimensions are as follows: 15 inches in length, by 13 inches in width, by 9 inches in height/depth. It also weights 13.8 pounds.
Feb 16, 2014 | Tramontina Gourmet Dutch Ovens: Enameled...
Le creuset enamel repair
If the chip is on the outside of the pot, it should still be okay to use. If its inside the pot-this is a useful posting
http://www.thekitchn.com/chipped-enamel-need-to-replace-86730
May 15, 2013 | Mario Batali 7-inch Chianti Enameled Cast...
What is a great casserole dish to invest in?
Well it all depends on how much you can spend and if you want to be able to use it on top of a stove burner as well as in an oven. If you don't have a lot to spend, then buy caserole dishes which don't have to work on a stove burner as well. You can always use pots instead. You want something that heats evenly with out burning. I like Corell ware as it is not too expensive. Get a set with at least a lasagna pan, a two quart and a three quart casserole. I would not get the clear glass dishes any more as I just had one break into three pieces on me as it was taken out of the fridge after defrosting. Dinner went on the floor along with the broken glass.
OR if you really want an investment peice, go to Homegoods and buy an imitation of the French dishes Le Creuset Le Creuset Stoneware Deep Covered Bake or buy a real Le Creuset at Williams Sonoma.
http://www.williams-sonoma.com/products
May 01, 2013 | Home
A heavy object was dropped on the lid of our whirlpool cabrio washing machine, and it is cracked throughout, like a windshield, though still encased and not broken through to the outer surfaces of the lid....
you can buy a new replacement lid from applianceparts pro.com part number AP4360341 for $159.50, if you do not have the money you could patch the crack from getting worse by covering the cracked surface with clear 2 inch wide carton tape so it would not be that noticeable of if you do not care of the appreance you could use duct tape, good luck mike
Nov 08, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I burned potato soup in my Le Creuset dutch oven.
Go buy a scraper for a ceramic hob and a can of barbeque or oven cleaner.
Spray the cleaner on and leave it for 15 minutes put on a pair of rubber gloves and use the scraper to break the surface of the burnt on stuff.
Make sure you keep the blade of the scraper as flat as possible to the surface of the pot.
Once you have scored some of the surface spry on some more cleaner and repeat the process
I clean off burnt casserole dishes using that method
Jun 20, 2009 | Le Creuset Q9500.67 Electric Kettle
My oval Le Creuset dutch oven is cracked on the side. Any way to fix it?
Yes there a foundation repair solution that should repair it sufficiently. Check at Home Depot or Lowes. Any hardware store should be able to help you out.
Sep 03, 2008 | Le Creuset Kone Electric Kettle
Kitchen Ranges Logo
91 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
