Question about Sony FD Trinitron KD-34XS955 34" TV
TV will not come on.
I have a Sony Trinitron HDTV KD 34 XS955, 4 years old. The TV will not come on. When you turn it on, it makes a clicking noise and nothing. The red light on the front of the TV flashes quickly, when this happens. I have unplugged, tried other outlets, nothing. Can you give me any ideas what might be the problem?
  • tamigibbs Nov 30, 2008
    not able to repair tv my self. have someone coming to check. thank you for the input.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it would appear that the Sony has gone into protective mode. This is to prevent any further escalation of electronic damages. The blinking is significant, the sequence and count of blinks would point to the probable area of fault. If you post back how many blinks, then we would be able to inform you where to start and probable curse of action. Additionally, pls confirm that you have a Sony KD-34XS955.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 30, 2008
    Genius:
  • 1,847 Answers
Blinking code for Sony is:
http://www.iwaynet.net/~nesda/SonyBlink.html
This site is for a specific chassis and it is only generally the right direction for other sets.
Sony KD-34XBR960 has no power; working perfect, on next start up the usual pop when powered on with remote, but failed to come on. No flashing lights, nothing. Unplugged, waited 24 hours, plugged into...
The problem is in the power supply, the most common cause is an open fuse and open capacitors, if the set is more than 10 years old consideration should given in replacing the tv especially if a professional gets involved.
May 15, 2011 | Sony FD Trinitron KD-34XBR960 34" TV
Tv wont turn on. red timer light blinking. i think our baby hit some magic button.
I have a Sony Trinitron KV-35S66 36" TV my Stand by/Timer Light keeps flashing, I have tried all fixes, it's 9 1/2 years old is is worth fixing/cost.......no money!!!!
Jan 02, 2011 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony KD-34XBR960....problem is that screen is black; LED light blinks 7 times in a row pauses and then starts blinking again. Have powered off and no improvement.
This tv have two power ICS left side of the FBT-The Flyback Transformer.The big black block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced those 2 power ICS,tv will solved this LED power light flashing,tv will have stable power again,tv will work.
Oct 23, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
I have a Sony KD-34XBR960 that sound like it is
phillips has the same problem but if your tv actually turns on it could be a short or just a fuse sonys a better tv than phillips should be an easy fix call a repir guy going price for that problem is 75.00 dont pay any more than that. the economy is bad everyone needs the work be smart. make sure if you say yes to the work that the repair guy will waive the consultaion cost of usually 35 to 75 dollars, if you chose to have the work done.
Jun 02, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
Sony trinitron xbr (9 years old) failing to power up
Turn it off u leave on to long ur CRT Tube will dies soner.Resolder the FBT,the flyback transformer, the big block of plastic with a red wire with a cap hook to the and the transistor beside it.This transformer is the HV to the CRT to get power.
Jan 15, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
Have enjoyed my KD-34XS955 for the past 5 years.
Maybe the degaussing coil is moved backward from the picture tube.
Jan 06, 2010 | Sony FD Trinitron KD-34XS955 34" TV
Random turn off
just soldering your color ic or your RGB ic
Jun 20, 2008 | Sony FD Trinitron WEGA KD-34XBR2 34" TV
Our set turns itself off by itself. Prior to this happening, it goes to a green screen. It usually happens after the set has been on for a couple of hours. We bought the set in April, 2004 and the warrantly has now expired. The longer we keep the set on, the more it turns itself off. Is this a tuner, on/off problem or the tube? Any estimates for repair?
Jun 15, 2008 | Sony FD Trinitron KD-34XBR960 34" TV
Connecting PS2 to an old TV
Plug the Red, Yellow, and White cords into their respective "IN" ports on the VCR. Run a coax line from the "out" port of the VCR to the coax port on TV. Some VCRs require you to tune to channel 3 or "LINE" which is typically the channel before 2 for this to work. To make things easier, you may want to purchase a modulator. This would allow you more easily set this up. The Mini-modulators aren't very expensive and can be purchased at virtually any electonics store.
Aug 11, 2005 | Sony FD Trinitron KD-34XBR960 34" TV
Sony FD Trinitron KD-34XS955 34" TV Logo
248 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
