Could you tell me where i can look at an owners manual online for a peavey pa-300 amplifier with 4 channels?i cant even find it on peaveys site
I contacted peavey and they solved it for free
Posted on Nov 30, 2008
Speaker jack
Contact Peavey toll free at 877-732-8391 or by email at,
Mar 25, 2014 | Peavey Escort 3000 300 Watt Portable PA...
Peavey pa 120
No It wont, is this a new amp you installing or is it already been installed and was working?
Feb 08, 2014 | Peavey Car Audio & Video
Peavey 400B manual
go to Peavey website, select support, select owners manuals, click on archived owners manuals, select x for xr 400 b, select from the shown list.
Aug 11, 2012 | Peavey Xr600b Mixer Amplifier "last One"...
I want to no wat this parts number is Q4025p for a peavey cs 800
2 Channel Peavey CS-800 Amp (800 Watts) ... Peavey CS-800x 800 Watt PA Stereo power Amplifier. The Part in question Q4025P is an alternistor. Two SCRs back to back that may have shorted out if it is not working.
Apr 11, 2012 | Peavey Audio Players & Recorders
When the Peavey is turned on, the power LED and the 5 channel LEDs blink a number of times but other than that, nothing happens.
This MIGHT be a service manual for the amp portion of your unit:
Hopefully you can find a suitable service agency to repair this... If under warranty, take advantage of the warranty.
Mar 08, 2011 | Peavey Escort 3000 300 Watt Portable PA...
Peavey PV 8.5C DDT is activated on channel A even al low volume, channel B works fine. All 8 power transistors on both channels were found OK. Driver transistors and 15V zener diodes are all OK as well....
Check your speakers and Cables. I had some speakers that traveled in my small trailer and the vibrations of the trailer caused the diaphram to back off my horns. Once I got the speakers fixed the DDT light on my power amp stopped staying on so much.
Jan 07, 2010 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Peavey 1500 PA amplifier, no output from channel A
is amp configured correct
use same input and same speaker on both sides
check output fuse on A
if fuse ok then problem is inside unit
get tech to open and check all input and output wiring
Jan 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Peavey amp
You could also use speakers rated less than 400 RMS provided you dont crank the volume knobs all the way up.
I think the CS400 is 200 Watts RMS per channel into 8 ohms
400 watts bridged
Here's the manual. You'll need acrobat to open it.
Dec 05, 2008 | Peavey CS 1400 Amplifier
Ive bought a Peavey 1500 pa amplifier and would like to know are the a b knobs on the front treble and bass.If they are how would I take the outputs at the back of the amp to my Soundcraft mixer.
The Peavey A/B controls are output gain controls. Your mixers stereo output goes into the amps inputs, channels A & B. The Peavey is the output stage to your speaker system. If you you connect the outputs from a power amp to the inputs of a mixer you will blow the mixers input stage, amongst many other things and possibly damage the amplifier too. The bias (Bass, Mid, Treble controls) are on the mixer, not the amplifier. Unless you are using a mixer amp, which you are not. A PA system DOES NOT work in the same way as an intergrated hi fi amp.
Nov 07, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Peavey Compressor/Limiter and Peavey 3/4/5w Crossover
The correct order is Mixer>EQ>Compressor>Crossover>Amps>Speaker. Here is the link that helped me out. Scott's PA System Tutorial
Feb 13, 2008 | Peavey CROSSOVER, STEREO 2-WAY/MONO 3-WAY,...
73 people viewed this question
