Question about Hotpoint RGB745 Gas Kitchen Range
LP GAS ODOR WHEN USING OVEN
WE HAVE HAD A GE XL44 STOVE FOR ABOUT 12 YEARS AND HAVE ALWAYS HAD A PROBLEM WITH LP GAS ODOR WHEN USING THE OVEN. WE HAVE HAD TO USE THE EXHAUST FAN WHENEVER THE OVEN IS ON. WE HAD A REPAIR MAN LOOK AT IT AND HE COULD NOT TELL US WHAT THE PROBLEM IS.
THANK YOU FOR ANY ASSISTANCE,
BJ
  • Anonymous Dec 08, 2008
    I have the same oven and am having the same problem, I have been told when the LP tank is getting low it will start to stink. Mine comes and goes but more predominantly in the cooler seasons, I am going to have the propane company come up and look
  • 4pawglass Dec 25, 2008
    Same problem on a different oven. Brand new oven so also wondering... I know he changed out the orifice in each top burner, should it had been changed in the oven for propane also? The flame seems very yellow. Never had a gas range before so this is all new. We will try tightening the orifice down. Thanks for your help.
    Sergeant:
    Champion:
  • 338 Answers
Sounds like you need to take the drawer out and tiighten the orifice down. some say tighten it all the way down and back it off 2 turns. if you do that and still have a problem then you may have a problem with carbon build up in the bake burner, let me know if you need further assistance
Posted on Nov 30, 2008
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
Jan 25, 2011 | GE Ovens
My GE XL44 Gas Range (Model JGBP34 GEP 1A) control
If you like the stove and it in good shape otherwise, have it fixed. The parts are still available. The stove in good used condition (without leak) is probably worth $75.00. May cost that much to repair it. Will cost approximately $450.00 to replace it with equal range. If it's a standing pilot model (no electricity needed) they are unavailable and your new range will require power to use the oven. Hope this helps.
Dec 07, 2009 | GE Spectra JGBP35 Gas Kitchen Range
I have a GE xl44 gas oven/stove. I cleaned the
Change the Temp sencor for the self cleaning
Dec 05, 2009 | GE Kitchen Ranges
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
GE XL44 oven does not heat
12 years old? If it is a gas rnge yo need to get a gas technician out to fix it. I would probably say it s time for a new one. Hers is a couple of things to think of when getting a new stove. 1) Everyone wants a self clean. But 90% never self clean. can save up to $200 w/o that option. 2) 80% off people buy a stovebased on looks. A stove may not be pretty but work just as good as one that is.
Feb 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven burner makes a popping or whistling sound during baking cycl
STOP>>>>STOP{>>>STOP>>>
You have a gas leak in the oven.
Get this fixed immediately.
Feb 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 propane to natural gas conversion.
your going back to natural from LP??? of so tyhere is no new orifice , but hte "hood" on the end of the bake, needs to be adjusted out"loosened", LP the "hood" is secured snugged down,
Jan 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas Odor coming from oven
The reason you can't smell it when the oven is on is because the gas is being ignited. DO NOT USE YOUR STOVE until you get this fixed by a gas fitter. You have a gas leak, which is either a loose fitting or faulty valve or line.
Call your appliance dealer IMMEDIATELY or you could have an explosion!!!!
Sep 06, 2008 | Ovens
GE XL44 Gas Stove
Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Hotpoint RGB745 Gas Kitchen Range Logo
211 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
