Question about RCA P52926 52" Rear Projection Television
Model R52HW74 We have a R52WH74 that just started having problems. we turned it off and then when we went back to turn it on and the screen was black with about 4-5 lines red, blue and green when the picture comes up all the faces look 3 different shades and 3 faces. what should we do or is it worth fixing, it is still under warranty however since we can not find the receipt they will not fix it.
    Problem Solver:
  • 31 Answers
That is not fear they should have your info in their system, anyway, If i understand correctly the problem you have a convergence problem, this is a good hd tv you should fix it
Posted on Dec 02, 2008
Half of my tv screen went black. I just opened it and i turned it on, but the whole screen went black.
Hope it would be back light problem. you didn't mentioned anything about the brand and model number of the tv. Without knowing, is it an led lcd or LCD tv with ccfl back light its not possible give solution.
www.electro-medical.blogspot.com
Sep 07, 2015 | Televison & Video
Rca r52wh74 - no auto convergance
The model number of your TV probably falls under the ITC-222 chassis design. Do a search based on that criteria and it should point you in the right direction. If I remember right, you need to replace FL231 on the deflector board though. Good luck
Dave.
Jun 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA 52inch rear projection tv model No#R52wh74 when i turned on the set the screen went into some concave mode and the color is al distorted what do i need to fix this
DO you have convergence in the customer setup menu? if you do not then check out the article fl231 problem in the tips and tricks section
Apr 28, 2009 | RCA R52WH73 Projection Television
The convergence circuit is the problem. If you can solder and are comfortable working inside the set where there are potentially dangerous high voltages even when unplugged, you can fix this yourself. First locate the convergence ICs which are large black ICs attached to a heatsink that will be marked STKxxx. Try resoldering the pins on these ICs first. If that fails to resolve the problem, replace the ICs. Please note that there could be additional small parts that require replacement as well. Start with the ICs and let me know the results.
Dan
Jan 14, 2009 | Televison & Video
RCA 52 inch
three strikes and it's out... rca does this, it is just showing it has tried 3 times for you and untill it is unplugged it won't try again.. you need to provide model #.. could be a few different things
hissing usually meens you have high voltage...that's good but then what don't you have?
ctc 169 - 179 could be high voltage divider... need more info
Oct 17, 2008 | RCA R52WH73 Projection Television
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
TV screen went black, sound OK
check cold solder vertical circuit
Nov 21, 2006 | JVC AV-27530 27" TV
RCA P52926 52" Rear Projection Television Logo
105 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
